查看: 1285|回復(fù): 0
單片機(jī)呼吸燈加交通燈
ID:864715 發(fā)表于 2020-12-29 09:32 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
呼吸燈加交通燈
J9跳線帽不能拔掉
#include <reg52.h>
sbit Red = P1^0;
sbit Yellow = P1^1;
sbit Green = P1^2;
sbit DU  = P2^6;   //數(shù)碼管段選
sbit WE  = P2^7;   //數(shù)碼管位選
unsigned char const discode[] ={ 0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F,0x6F,0x40,0x00/*-*/};
unsigned char const positon[2]={ 0xfe,0xfd};
unsigned char disbuff[2]           ={ 0,0};
unsigned char pwm_left_val = 0;//
unsigned char pwm_t;//周期
unsigned char posit=0;
unsigned int Dbuf;//
bit flag = 0;
//毫秒級延時
void delay(unsigned int z)
        unsigned int x,y;
        for(x = z; x > 0; x--)
                for(y = 114; y > 0 ; y--);
void Display(void)                                 //掃描數(shù)碼管
        DU = 0;
        if(posit==0)
        {P0=(discode[disbuff[posit]]);}
        {P0=discode[disbuff[posit]];}
        DU = 1;
        DU = 0;
        WE = 0;
        P0=positon[posit];
        WE=1;
        WE=0;
        if(++posit>=2)
        posit=0;
//定時器0中斷
void timer0() interrupt 1
        pwm_t++;
        if(pwm_t == 255)
                pwm_t = P1 = 0;
        if(pwm_left_val == pwm_t)
                        P1 = 0XFF;
void  timer1()  interrupt 3                  //T1中斷用來掃描數(shù)碼管和計2MS啟動模塊
        TH1=0xf8; //2ms
        TL1=0xCC;
        if(flag == 0)
                disbuff[0]=Dbuf % 100 / 10;
                disbuff[1]=Dbuf % 10;
        Display();
        EA        = 1;//總中斷允許
                unsigned char i, delay_sec;
                TMOD |= 0x02;//T0 8位自動重裝模塊
                TH0 = 225;
                TL0 = 225;//11.0592M晶振下占空比最大比值是256,輸出100HZ
                TR0 = 1;//啟動定時器0
                ET0 = 1;//允許定時器0中?
                for(i=0; i < 4; i++)
                        while(pwm_left_val != 255)
                                ++pwm_left_val;
                                delay(1);
                        while(pwm_left_val != 0)
                                --pwm_left_val;
                                delay(1);
                ET0 = 0;
                TR0 = 0;
                P1 = 0XFF;
                delay(2000);
                TMOD |= 0x10;//T1 16位定時
                TH1=0xf8; //2ms
                TL1=0xCC;
                ET1=1;                           //允許T1中斷
                TR1=1;                           //開啟定時器1
                        delay_sec = 10;
                        Red = 0;
                        do{
                                Dbuf = delay_sec;
                                delay(1000);
                        }while(--delay_sec);
                        Red = 1;
                        delay_sec = 10;//10sec
                        Green = 0;
                        do{
                                if(delay_sec <= 3)//綠燈閃爍
                                        Green = 0;
                                        Dbuf = delay_sec;
                                        delay(500);
                                        flag = 1;
                                        disbuff[0] = 11;
                                        disbuff[1] = 11;
                                        Green = 1;
                                        delay(500);
                                        flag = 0;
                                        Dbuf = delay_sec;
                                        delay(1000);
                        Green = 1;
                        delay_sec = 3;//
                        Yellow = 0;
                        do{
                                Dbuf = delay_sec;
                                delay(1000);
                        Yellow = 1;
