- 模塊名稱:st7920 并行方式驅動12864液晶驅動
- 功能概要:st7920顯示驅動
- CPU: stc89c58 主頻:11.0592M
- 液晶型號: 生產廠家: 驅動芯片:st7920
- #include <reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- #define x1 0x80
- #define x2 0x88
- #define y 0x80
- #define comm 0
- #define dat 1
- sbit RS = P2^1; //H=data; L=command;
- sbit RW = P2^2; //H=read; L=write;
- sbit E = P2^4; //input enable;
- sbit PSB= P2^5; //H=并口; L=串口;
- sbit RST= P2^3; //Reset Signal 低電平有效
- sbit busy=P0^7; //lcd busy bit
- void wr_lcd (uchar dat_comm,uchar content);
- void chk_busy (void);
- void delay (uint us);
- uchar code tab1[]={
- "本系列中文模塊內"
- "任意位置反白顯示"
- "置二級字庫,可在"
- "使用更方便更靈活"
- uchar code tab31[]={
- "金鵬科技有限公司"
- "Golden Palm TECH"
- uchar code tab32[]={
- /*-- 調入了一幅圖像:F:\梁\畫圖\HOCO12832.bmp --*/
- /*-- 寬度x高度=128x32 --*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x1E,0x00,0x00,0x00,0x00,0x00,0x07,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x7F,0x80,0x00,0x00,0x00,0x00,0x18,0x0C,0x00,0x00,0x01,0x00,0x00,0x00,0x00,
- 0x01,0xFF,0x80,0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x13,0x10,0x03,0xFE,0x00,
- 0x03,0xFF,0xC0,0x00,0x00,0x00,0x00,0x58,0x00,0x00,0x00,0x3F,0x30,0x1F,0xFF,0xC0,
- 0x03,0xFF,0xE0,0x00,0x00,0x00,0x00,0x8C,0x03,0xF0,0x00,0x7F,0xE0,0x7C,0x01,0xE0,
- 0x03,0xFF,0xF0,0x00,0x00,0x00,0x01,0x36,0x06,0xC0,0x00,0x5F,0xC0,0xFF,0xFC,0x60,
- 0x01,0xFF,0xF0,0x00,0x00,0x00,0x02,0x1B,0x0F,0x80,0x00,0xFF,0x01,0xFE,0x0F,0x30,
- 0x00,0xEF,0xF0,0x00,0x00,0x00,0x02,0x6D,0x9F,0x00,0x00,0x3E,0x03,0xFF,0xF1,0x90,
- 0x00,0xFF,0xF8,0x00,0x00,0x00,0x04,0x36,0xFE,0x00,0x01,0xFF,0x07,0xFF,0xFC,0x90,
- 0x00,0xEF,0xFF,0xFF,0x80,0x00,0x04,0xDB,0x7E,0x00,0x03,0xFF,0x87,0xFF,0xFC,0xD0,
- 0x00,0x0F,0xFF,0xFF,0xC0,0x00,0x04,0x6D,0xFC,0x00,0x07,0xFF,0x8F,0xFF,0xFE,0x50,
- 0x00,0x0F,0xFF,0xFF,0xE0,0x00,0x04,0x36,0xFC,0x10,0x07,0xFF,0x8F,0xFF,0xFE,0x90,
- 0x00,0x0F,0xFF,0xFF,0xE0,0x00,0x04,0x1B,0xF8,0x10,0x07,0xFF,0xCF,0xFF,0xFE,0x80,
- 0x00,0x0F,0xFF,0xFF,0xF0,0x00,0x04,0x0F,0xF8,0x10,0x07,0xFF,0xFF,0xFF,0xFA,0x00,
- 0x00,0x07,0xFF,0xFF,0xF0,0x00,0x04,0x07,0xF0,0x10,0x07,0xFF,0xFF,0xFF,0xFA,0x00,
- 0x00,0xFF,0xFF,0xFF,0xF8,0x00,0x02,0x03,0xF0,0x20,0x07,0xFF,0xFF,0xFF,0xBA,0x00,
- 0x00,0xFD,0xFF,0xFF,0xFC,0x00,0x02,0x03,0xF0,0x20,0x03,0xFF,0xFF,0xDF,0xB8,0x00,
- 0x00,0xC1,0xC0,0x3F,0xFC,0x00,0x01,0x01,0xE0,0x40,0x00,0xFF,0xFF,0xDF,0xB0,0x00,
- 0x00,0x81,0xC0,0x3F,0xCE,0x00,0x00,0x81,0xE0,0x80,0x00,0x7F,0xFF,0xDF,0xA0,0x00,
- 0x00,0x81,0x80,0x1D,0xCF,0x00,0x00,0x41,0xE1,0x00,0x00,0x3F,0xFF,0x9B,0x00,0x00,
- 0x01,0x83,0x80,0x1F,0xC7,0x80,0x00,0x21,0xE2,0x00,0x00,0x1F,0xFD,0xB6,0x00,0x00,
- 0x01,0xC3,0x00,0x0E,0xE6,0x80,0x00,0x19,0xEC,0x00,0x00,0x07,0xFE,0x20,0x00,0x00,
- 0x00,0xC3,0x00,0x07,0x67,0x40,0x00,0x07,0xF0,0x00,0x00,0x03,0x3E,0x00,0x00,0x00,
- 0x00,0x02,0x00,0x03,0xE7,0xA0,0x00,0x00,0x00,0x00,0x00,0x02,0x8E,0x00,0x00,0x00,
- 0x00,0x06,0x00,0x03,0x83,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x03,0x00,0x00,0x00,
- 0x00,0x06,0x00,0x07,0x03,0x00,0x77,0x46,0x74,0x24,0x80,0x06,0x04,0x00,0x00,0x00,
- 0x00,0x1C,0x00,0x06,0x00,0x00,0x55,0x45,0x54,0x57,0x80,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x1C,0x00,0x0E,0x00,0x00,0x45,0x45,0x74,0x57,0x80,0x08,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x1C,0x00,0x00,0x55,0x45,0x44,0x74,0x80,0xF0,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x38,0x00,0x00,0x77,0x76,0x47,0x54,0x80,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
- uchar code tab5[]={
- /*-- 調入了一幅圖像:F:\梁\畫圖\COCK.bmp --*/
- /*-- 寬度x高度=128x64 --*/
- 0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x80,0x00,0x0F,0xFF,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x0C,0x43,0x01,0x80,0x00,0x7F,0xFF,0xF0,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x19,0xFF,0x07,0x00,0x07,0xFF,0xFF,0xFE,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x01,0x3F,0xFC,0x1E,0x00,0x1F,0xFF,0xFF,0xFF,0x80,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x01,0xBF,0xFF,0xFC,0x00,0x7F,0xFC,0x00,0x7F,0xC0,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x01,0xFF,0xFF,0xF0,0x00,0xFF,0xC0,0x00,0x0F,0xE0,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x01,0xFF,0xFF,0xE0,0x03,0xFF,0xFF,0xFC,0x01,0xF0,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x01,0xDF,0xFF,0xC0,0x07,0xFF,0xFF,0xFF,0x80,0xF0,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x03,0xFF,0xFF,0x00,0x0F,0xFF,0xFF,0xFF,0xE0,0x38,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x07,0xFF,0xF8,0x00,0x1F,0xFF,0xF0,0x03,0xF8,0x38,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x07,0xFF,0xE0,0x00,0x3F,0xFF,0xFF,0xC0,0x7C,0x18,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x04,0x7F,0xF0,0x00,0x3F,0xFF,0xFF,0xF8,0x1E,0x08,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x01,0xFF,0xF8,0x00,0x7F,0xFF,0xFF,0xFE,0x0F,0x08,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x0F,0xFF,0xFC,0x00,0xFF,0xFF,0xFF,0xFF,0x87,0x08,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x1F,0xFF,0xFE,0x00,0xFF,0xFF,0xFF,0xFF,0x83,0x88,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x3F,0xFF,0xFE,0x01,0xFF,0xFF,0xFF,0xFF,0xC3,0x88,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x7F,0xFF,0xFE,0x01,0xFF,0xFF,0xFF,0xFF,0xE1,0x88,0x00,0x00,0x00,
- 0x00,0x00,0x00,0xFF,0xFF,0xFE,0x03,0xFF,0xFF,0xFF,0xFF,0xE1,0x88,0x00,0x00,0x00,
- 0x00,0x00,0x01,0xFF,0xFF,0xFE,0x03,0xFF,0xFF,0xFF,0xFF,0xF1,0x88,0x00,0x00,0x00,
- 0x00,0x00,0x01,0xFF,0xFF,0xFE,0x03,0xFF,0xFF,0xFF,0xFF,0xF3,0x08,0x00,0x00,0x00,
- 0x00,0x00,0x01,0xFF,0xFF,0xFF,0x07,0xFF,0xFF,0xFF,0xFF,0xF2,0x10,0x00,0x00,0x00,
- 0x00,0x00,0x01,0xFF,0xFF,0xFF,0x8F,0xFF,0xFF,0xFF,0xFF,0xF0,0x20,0x00,0x00,0x00,
- 0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x70,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0x70,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0xFF,0x7F,0x20,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xBF,0xFF,0x7F,0x20,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0x7E,0x20,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0x3E,0x40,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xCF,0xFF,0x3C,0x40,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xCF,0xFE,0x38,0x40,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0x8F,0xFE,0x38,0x40,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0x8F,0xFE,0x30,0x40,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0x1F,0x7C,0x20,0x40,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFE,0x1E,0x78,0x00,0x40,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFE,0x1E,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xDA,0x3C,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xF2,0x30,0x80,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xF1,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0xFE,0x7F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x7C,0x3F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x78,0x1F,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x72,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x70,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0xC0,0x03,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x01,0x40,0x04,0xD8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x01,0x00,0x01,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x02,0x0C,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x02,0x40,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x0C,0x48,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x38,0x41,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x0F,0xE2,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- * 函數(shù)名稱 :
- * 功能描述 :
- * 參數(shù) : 參數(shù)名稱: 輸入/輸出? 類型 描述
- * 返回值 :
- * 作者 :
- * 創(chuàng)建日期 :2006-12-19
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- *----------------------------------------修改歷史------------------------------------------
- * 當前版本 : 修改人: 修改日期:
- * 修改說明 :
- void init_lcd (void)
- RST = 1;
- PSB = 1;
- wr_lcd(comm,0x30); /*30---基本指令動作*/
- wr_lcd(comm,0x01); /*清屏,地址指針指向00H*/
- wr_lcd(comm,0x06); /*光標的移動方向*/
- wr_lcd(comm,0x0c); /*開顯示,關游標*/
- * 函數(shù)名稱 :chn_disp
- * 功能描述 : 顯示漢字或字符
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- void chn_disp(uchar code *chn)
- uchar i,j;
- wr_lcd(comm,0x80);
- for(j=0;j<4;j++)
- for(i=0;i<16;i++)
- wr_lcd(dat,chn[j*16+i]);
- * 函數(shù)名稱 :chn_disp1
- * 功能描述 : 上半屏顯示漢字或字符
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- void chn_disp1(uchar code *chn)
- uchar i,j;
- j=0;
- for(i=0;i<16;i++)
- wr_lcd(comm,0x90);
- j=1;
- for(i=0;i<16;i++)
- * 函數(shù)名稱 :img_disp
- * 功能描述 : 顯示圖形
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- void img_disp(uchar code *img)
- uchar i,j;
- for(j=0;j<32;j++)
- for(i=0;i<8;i++)
- wr_lcd(comm,0x34);
- wr_lcd(comm,y+j);
- wr_lcd(comm,x1+i);
- wr_lcd(dat,img[j*16+i*2]);
- wr_lcd(dat,img[j*16+i*2+1]);
- for(j=32;j<64;j++)
- for(i=0;i<8;i++)
- wr_lcd(comm,y+j-32);
- wr_lcd(comm,x2+i);
- wr_lcd (comm,0x36);
- * 函數(shù)名稱 :img_disp1
- * 功能描述 : 下半屏顯示圖形
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- void img_disp1(uchar code *img)
- uchar i,j;
- for(j=0;j<32;j++)
- for(i=0;i<8;i++)
- wr_lcd(comm,y+j);
- wr_lcd(comm,0x36);
- * 函數(shù)名稱 :lat_disp
- * 功能描述 : 顯示點陣
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- void lat_disp(uchar data1,uchar data2)
- uchar i,j,k,x;
- x=x1;
- for(k=0;k<2;k++)
- for(j=0;j<16;j++)
- for(i=0;i<8;i++)
- wr_lcd(comm,y+j*2);
- wr_lcd(comm,x+i);
- wr_lcd(dat,data1);
- for(i=0;i<8;i++)
- wr_lcd(comm,y+j*2+1);
- wr_lcd(comm,x+i);
- wr_lcd(dat,data2);
- x=x2;
- * 函數(shù)名稱 :con_disp
- * 功能描述 : 當data1=0xff,data2=0xff時,在x0,y0處反白顯示16xl*yl
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- void con_disp(uchar data1,uchar data2,uchar x0,uchar y0,uchar xl,uchar yl)
- uchar i,j;
- for(j=0;j<yl;j++)
- for(i=0;i<xl;i++)
- wr_lcd(comm,y0+j);
- wr_lcd(comm,x0+i);
- * 函數(shù)名稱 :clrram
- * 功能描述 : 清DDRAM
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- void clrram(void)
- * 函數(shù)名稱 :wr_lcd
- * 功能描述 :
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- void wr_lcd(uchar dat_comm,uchar content)
- chk_busy ();
- if(dat_comm)
- RS = 1; //data
- RW = 0; //write
- else
- RS = 0; //command
- RW = 0; //write
- P0=content; //output data or comm
- E = 1;
- E = 0;
- * 函數(shù)名稱 :chk_busy
- * 功能描述 :
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- void chk_busy(void)
- P0 = 0xff;
- RS = 0;
- RW = 1;
- E = 1;
- while(busy==1);
- E = 0;
- * 函數(shù)名稱 :
- * 功能描述 :
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- void delay(uint us) //delay time
- while(us--);
- * 函數(shù)名稱 :
- * 功能描述 :
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- void delay1(uint ms)
- uint i,j;
- for(i=0;i<ms;i++)
- for(j=0;j<15;j++)
- delay(1);
- * 函數(shù)名稱 :
- * 功能描述 :
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- void main()
- SP=0x5f;
- init_lcd();
- while(1)
- lat_disp(0x00,0x00);
- chn_disp(tab1);
- con_disp(0xff,0xff,0x8c,0x80,2,16);
- delay1(8000);
- clrram();
- lat_disp(0xcc,0xcc);
- delay1(8000);
- chn_disp1(tab31);
- img_disp1(tab32);
- delay1 (8000);
- clrram();
- lat_disp (0xff,0x00);
- delay1(8000);
- img_disp(tab5);
- delay1(8000);
復制代碼 |
