查看: 2312|回復(fù): 6
stc12c5a60s2制作電子時(shí)鐘,實(shí)現(xiàn)不了1s,我的代碼哪錯(cuò)了,求大佬指教
ID:871301 發(fā)表于 2020-12-31 02:32 來(lái)自手機(jī) | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<stc12c5a60s2.h>
sbit led=P2^1;
unsigned char code qdm[]={0x03,0x9f,0x25,0x0d,0x99,0x49,0x41,0x1f,0x01,0x09,0xff};
unsigned char code wei[]={0x08,0x04,0x02,0x01};
unsigned char sj[]={0,0,0,0};           //
unsigned char zt=0;
unsigned char c;
unsigned char ss;
unsigned char mm;
unsigned char hh;
void timer0init(void);
void timer1init(void);
void int0init(void);
void int1init(void);
void xianshi(void);
void xsm(void);
void xsh(void);
void delay(unsigned int i)                         //軟件延時(shí)
        unsigned int j;
        while(i--)
                for(j=600;j>0;j--);
void main(void)
        int0init();
        int1init();
        timer0init();
        timer1init();
        EA=1;
                switch(zt)
                        case 0:TR0=1;xianshi();break;         //正常時(shí)鐘狀態(tài)
                        case 1:xsm();break;         //調(diào)分
                        case 2:xsh();break;         //調(diào)時(shí)
                        default:break;
void display()
        unsigned char i;
        for(i=0;i<4;i++)
                P0=wei[i];
                P1=qdm[sj[i]];
                delay(1);
void xianshi(void)
        sj[0]=hh/10;
        sj[1]=hh%10;
        sj[2]=mm/10;
        sj[3]=mm%10;
void xsm(void)
        sj[0]=10;
        sj[1]=10;
        sj[2]=mm/10;
        sj[3]=mm%10;
void xsh(void)
        sj[0]=hh/10;
        sj[1]=hh%10;
        sj[2]=10;
        sj[3]=10;
void int0init(void)
        IT0=1;
        EX0=1;
void int1init(void)
        IT1=1;
        EX1=1;
void timer0init(void)                    //50毫秒定時(shí)計(jì)數(shù)器0初始化
        TMOD=0x01;                            //設(shè)置定時(shí)器模式
        TL0=(65536-50000)%256;                //設(shè)置定時(shí)初值
        TH0=(65536-50000)/256;                //設(shè)置定時(shí)初值
        TF0=0;                                                //打開中斷
        ET0=1;                                                //定時(shí)計(jì)數(shù)器0的中斷開關(guān)
void timer1init(void)                    //1毫秒定時(shí)計(jì)數(shù)器1初始化
        TMOD=0x10;                            //設(shè)置定時(shí)器模式
        TL1=(65536-1000)%256;                //設(shè)置定時(shí)初值
        TH1=(65536-1000)/256;                //設(shè)置定時(shí)初值
        TF1=0;                                            //清除TF1標(biāo)志
        ET1=1;                                //定時(shí)計(jì)數(shù)器1的中斷開關(guān)
        TR1=1;                                //定時(shí)器1開始計(jì)時(shí)
void timer0(void) interrupt 1
        c++;
        if(c==20)                                        //累加20次50ms,1s時(shí)間到
                c=0;                                        //清零,方便下一次計(jì)數(shù)
                led=~led;
                ss++;
                if(ss==60)                                //累加60次1s,1分鐘時(shí)間到
                        ss=0;
                        mm++;
                        if(mm==60)                        //累加60次1分鐘,1小時(shí)時(shí)間到
                                mm=0;
                                hh++;
                                hh%=24;                        //累加到23清零
void timer1(void) interrupt 3//中斷向量號(hào)一一對(duì)應(yīng)
        TR1=0;
        display();
        TR1=1;
void int0(void) interrupt 0
        TR0=0;
        zt++;
        if(zt==3)zt=0;
void int1(void) interrupt 2
        switch(zt)
                case 0:break;
                case 1:mm++;if(mm==60)mm=0;break;
                case 2:hh++;if(hh==24)hh=0;break;
                default:break;
ID:282439 發(fā)表于 2020-12-31 17:36 | 只看該作者
你的延時(shí)調(diào)用消耗了時(shí)間。所以不準(zhǔn)。你需要仿真一下延時(shí)程序。如果你有顯示屏的話,看一下實(shí)際的延時(shí)時(shí)間是多少。
ID:814525 發(fā)表于 2020-12-31 19:05 | 只看該作者
你使用了4個(gè)中斷,時(shí)間基準(zhǔn)用的T0。那你把T0的中斷優(yōu)先級(jí)設(shè)到最高,其他中斷優(yōu)先級(jí)設(shè)低。這樣就不至于影響T0中斷。
ID:517466 發(fā)表于 2020-12-31 20:43 | 只看該作者
這兩個(gè)函數(shù)int0init();        int1init();都被吊用,同時(shí)在這兩個(gè)函數(shù)中都是用了TMOD。那么問題就來(lái)了。TMOD是同時(shí)控制i兩個(gè)計(jì)數(shù)器的,低四位定義定時(shí)器/計(jì)數(shù)器T0,高四位定義定時(shí)器/計(jì)數(shù)器T1。
你先賦值TMOD=0x01,表示讓T0工作于工作方式1,16為基數(shù)模式;T1工作于方式0、13位計(jì)數(shù)器。
然后后面又再次賦值TMOD=0x10,表示讓T1工作于工作方式1,16為計(jì)數(shù)模式;T0方式0、13位計(jì)數(shù)器。
按照?qǐng)?zhí)行順序,最后只有T1工作于模式1、16位計(jì)數(shù)模式,而T0工作于模式0、13位計(jì)數(shù)模式,這是你想要的結(jié)果嗎?你如果想讓T0、T1同事工作,可以在第二次賦值時(shí),使用或的方式:TMOD |=0x10;
這樣才能保證T0,T1都工作于模式1、16位計(jì)數(shù)模式。
另外因?yàn)榇嬖谥袛嗲短椎膯栴},需要指定中斷的優(yōu)先級(jí)。程序中注意合理使用禁中斷、開中斷處理,防止互相干擾,導(dǎo)致程序異常。
參與人數(shù) 1黑幣 +20 收起 理由
ID:213173 發(fā)表于 2020-12-31 21:11 | 只看該作者
定時(shí)器設(shè)置不當(dāng),按鍵、顯示程序欠妥。給你一個(gè)示例參考。 長(zhǎng)短按鍵8位數(shù)碼管鬧鐘 仿真.zip (142.86 KB, 下載次數(shù): 7)
ID:871301 發(fā)表于 2020-12-31 22:24 來(lái)自手機(jī) | 只看該作者
張?zhí)鞄?發(fā)表于 2020-12-31 19:05
你使用了4個(gè)中斷,時(shí)間基準(zhǔn)用的T0。那你把T0的中斷優(yōu)先級(jí)設(shè)到最高,其他中斷優(yōu)先級(jí)設(shè)低。這樣就不至于影響T ...
請(qǐng)問怎么設(shè)置優(yōu)先級(jí)呀
ID:814525 發(fā)表于 2021-1-1 09:37 | 只看該作者
luyaoaif 發(fā)表于 2020-12-31 22:24
PT0=1;  PT1=0;  PX0=0;  PX1=0;
