查看: 1457|回復(fù): 3
為什么不顯示距離,是我沒有在keyboard引腳上插開關(guān)么 求指教
ID:843327 發(fā)表于 2021-1-2 22:07 來自觸屏版 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <AT89x51.H>                //器件配置文件#include <intrins.h>#define  RX  P3_6#define  TX  P3_7#define LCM_RW  P2_3 //定義LCD引腳#define LCM_RS  P2_4#define LCM_E   P2_2#define LCM_Data  P1#define Key_Data P3_3 //定義Keyboard引腳#define Key_CLK  P3_2#define Busy    0x80 //用于檢測LCM狀態(tài)字中的Busy標(biāo)識void LCMInit(void);void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);void Delay5Ms(void);void Delay400Ms(void);void Decode(unsigned char ScanCode);void WriteDataLCM(unsigned char WDLCM);void WriteCommandLCM(unsigned char WCLCM,BuysC);unsigned char ReadDataLCM(void);unsigned char ReadStatusLCM(void);unsigned char code mcustudio[] ={"==Range Finder=="};unsigned char code email[] =    {"xxxxxx "};unsigned char code Cls[] =      {"                "};unsigned char code ASCII[15] =    {'0','1','2','3','4','5','6','7','8','9','.','-','M'};static unsigned char DisNum = 0; //顯示用指針                                         unsigned int  time=0;           unsigned long S=0;           bit      flag =0;           unsigned char disbuff[4]           ={ 0,0,0,0,};//寫數(shù)據(jù)void WriteDataLCM(unsigned char WDLCM) {        ReadStatusLCM(); //檢測忙        LCM_Data = WDLCM;        LCM_RS = 1;        LCM_RW = 0;        LCM_E = 0; //若晶振速度太高可以在這后加小的延時        LCM_E = 0; //延時        LCM_E = 1;}//寫指令void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時忽略忙檢測{        if (BuysC) ReadStatusLCM(); //根據(jù)需要檢測忙        LCM_Data = WCLCM;        LCM_RS = 0;        LCM_RW = 0;                LCM_E = 0;        LCM_E = 0;        LCM_E = 1;        }//讀數(shù)據(jù)unsigned char ReadDataLCM(void){        LCM_RS = 1;         LCM_RW = 1;        LCM_E = 0;        LCM_E = 0;        LCM_E = 1;        return(LCM_Data);}//讀狀態(tài)unsigned char ReadStatusLCM(void){        LCM_Data = 0xFF;         LCM_RS = 0;        LCM_RW = 1;        LCM_E = 0;        LCM_E = 0;        LCM_E = 1;        while (LCM_Data & Busy); //檢測忙信號        return(LCM_Data);}void LCMInit(void) //LCM初始化{        LCM_Data = 0;        WriteCommandLCM(0x38,0); //三次顯示模式設(shè)置,不檢測忙信號        Delay5Ms();         WriteCommandLCM(0x38,0);        Delay5Ms();         WriteCommandLCM(0x38,0);        Delay5Ms();         WriteCommandLCM(0x38,1); //顯示模式設(shè)置,開始要求每次檢測忙信號        WriteCommandLCM(0x08,1); //關(guān)閉顯示        WriteCommandLCM(0x01,1); //顯示清屏        WriteCommandLCM(0x06,1); // 顯示光標(biāo)移動設(shè)置        WriteCommandLCM(0x0F,1); // 顯示開及光標(biāo)設(shè)置}//按指定位置顯示一個字符void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData){        Y &= 0x1;        X &= 0xF; //限制X不能大于15,Y不能大于1        if (Y) X |= 0x40; //當(dāng)要顯示第二行時地址碼+0x40;        X |= 0x80; //算出指令碼        WriteCommandLCM(X, 1); //發(fā)命令字        WriteDataLCM(DData); //發(fā)數(shù)據(jù)}//按指定位置顯示一串字符void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData){        unsigned char ListLength;  ListLength = 0;        Y &= 0x1;        X &= 0xF; //限制X不能大于15,Y不能大于1        while (DData[ListLength]>0x19) //若到達字串尾則退出                {                        if (X <= 0xF) //X坐標(biāo)應(yīng)小于0xF                                {                                        DisplayOneChar(X, Y, DData[ListLength]); //顯示單個字符                                        ListLength++;                                        X++;                                }                }}//5ms延時void Delay5Ms(void){        unsigned int TempCyc = 5552;        while(TempCyc--);}//400ms延時void Delay400Ms(void){        unsigned char TempCycA = 5;        unsigned int TempCycB;        while(TempCycA--)                {                        TempCycB=7269;                        while(TempCycB--);                };}/********************************************************/    void Conut(void)        {         time=TH0*256+TL0;         TH0=0;         TL0=0;                 S=(time*1.8)/10;     //算出來是MM         if((S>=7000)||flag==1) //超出測量范圍顯示“-”         {                   flag=0;                   DisplayOneChar(0, 1, ASCII[11]);          DisplayOneChar(1, 1, ASCII[10]);        //顯示點          DisplayOneChar(2, 1, ASCII[11]);          DisplayOneChar(3, 1, ASCII[11]);          DisplayOneChar(4, 1, ASCII[11]);          DisplayOneChar(5, 1, ASCII[12]);        //顯示M         }         else         {          disbuff[0]=S/1000;          disbuff[1]=S/100%10;          disbuff[2]=S/10%10;          disbuff[3]=S%10;          DisplayOneChar(0, 1, ASCII[disbuff[0]]);          DisplayOneChar(1, 1, ASCII[10]);        //顯示點          DisplayOneChar(2, 1, ASCII[disbuff[1]]);          DisplayOneChar(3, 1, ASCII[disbuff[2]]);          DisplayOneChar(4, 1, ASCII[disbuff[3]]);          DisplayOneChar(5, 1, ASCII[12]);        //顯示M         }        }/********************************************************/     void zd0() interrupt 1                  //T0中斷用來計數(shù)器溢出,超過測距范圍  {    flag=1;                                                         //中斷溢出標(biāo)志        RX=0;  }/********************************************************/     void  StartModule()                          //啟動模塊  {          TX=1;                                             //啟動一次模塊          _nop_();           _nop_();           _nop_();           _nop_();           _nop_();           _nop_();           _nop_();           _nop_();           _nop_();           _nop_();           _nop_();           _nop_();           _nop_();           _nop_();           _nop_();           _nop_();           _nop_();          _nop_();           _nop_();           _nop_();           _nop_();          TX=0;  }void Timer_Count(void){                 TR0=1;                            //開啟計數(shù)             while(RX);                        //當(dāng)RX為1計數(shù)并等待             TR0=0;                                //關(guān)閉計數(shù)         Conut();                        //計算}/********************************************************/ void delayms(unsigned int ms){        unsigned char i=100,j;        for(;ms;ms--)        {                while(--i)                {                        j=10;                        while(--j);                }        }}/*********************************************************/void main(void){    unsigned int valA;        unsigned char TempCyc;        Delay400Ms(); //啟動等待,等LCM講入工作狀態(tài)        LCMInit(); //LCM初始化        Delay5Ms(); //延時片刻(可不要)        DisplayListChar(0, 0, mcustudio);        DisplayListChar(0, 1, email);        ReadDataLCM();//測試用句無意義        for (TempCyc=0; TempCyc<10; TempCyc++)        Delay400Ms(); //延時        DisplayListChar(0, 1, Cls);                 TMOD=0x01;                   //設(shè)T0為方式1,GATE=1;         TH0=0;         TL0=0;                   ET0=1;             //允許T0中斷         EA=1;                           //開啟總中斷                                         while(1)          {                                delayms(60);                RX=1;            StartModule();        for(valA=7510;valA>0;valA--)            {                                  if(RX==1)                   {           Timer_Count();                   }             }          }}
ID:328014 發(fā)表于 2021-1-2 22:53 | 只看該作者
用電腦版的論壇重新編輯一下代碼吧,這個格式我估計沒有一個人能看明白的
ID:342822 發(fā)表于 2021-1-2 23:03 | 只看該作者
比亂碼還要亂
ID:143767 發(fā)表于 2021-1-3 11:09 | 只看該作者
亂碼都沒它亂
