可以模擬正弦波、方波、鋸齒波和三角波四種波形。
2021-1-3 16:50 上傳
- #include<reg52.h> //包含頭文件
- #include<intrins.h>
- #define uchar unsigned char //宏定義
- #define uint unsigned int
- /**************定義按鍵的接口*************/
- sbit s1=P3^5; //KEY2 頻率加
- sbit s2=P3^6; //KEY3 頻率減
- sbit s3=P3^7; //KEY1 波形選擇
- sbit s4=P3^4; //KEY4 步進(jìn)值
- sbit led0=P3^0; //正弦波指示燈
- sbit led1=P3^1; //方波指示燈
- sbit led2=P3^2; //三角波指示燈
- sbit led3=P3^3; //鋸齒波指示燈
- sbit lcdrs=P2^7;//液晶讀數(shù)據(jù)引腳,還有一個(gè)控制腳是RW(讀),因?yàn)槲覀冎恍枰蛞壕Ю飳憯?shù)據(jù)系那是就好了,所以,我們直接將RW引腳接地
- sbit lcden=P2^6;//使能端
- char num,boxing,u; //定義全局變量
- int pinlv=100,bujin=1,bujin1=1; //定義pinlv(頻率)的初始值為10hz,可以根據(jù)實(shí)際情況修改 bujin表示增減頻率按鍵按下一次的增減值 初始值為0.1
- uchar code table[]="0123456789"; //定義顯示頻率的數(shù)組
- uchar code table1[]="Fout= Wave form:"; //Fout后面顯示頻率值;Wave form后面顯示模擬波形
- unsigned long int m;
- int a,b,h,num1; //a b為定時(shí)器初始值變量
- /************自定義字符 用于顯示當(dāng)前示波器顯示波形的模擬波形 字符集可通過取模軟件獲取****************/
- uchar code zifu[]={
- 0x0e,0x11,0x11,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x11,0x11,0x0e,0x00, //正弦波0 1兩行
- 0x00,0x07,0x04,0x04,0x04,0x04,0x1c,0x00,
- 0x00,0x1c,0x04,0x04,0x04,0x04,0x07,0x00, //矩形波2 3兩行
- 0x00,0x01,0x02,0x04,0x08,0x10,0x00,0x00,
- 0x00,0x10,0x08,0x04,0x02,0x01,0x00,0x00, //三角波4 5兩行
- 0x00,0x01,0x03,0x05,0x09,0x11,0x00,0x00, //鋸齒波6一行
- uchar code sin[64]={
- 135,145,158,167,176,188,199,209,218,226,234,240,245,249,252,254,254,253,251,247,243,237,230,222,213,204,193,182,170,158,
- 146,133,121,108,96,84,72,61,50,41,32,24,17,11,7,3,1,0,0,2,5,9,14,20,28,36,45,55,66,78,90,102,114,128
- }; //正弦波取碼,此數(shù)組內(nèi)的數(shù)據(jù)為,da輸出對(duì)應(yīng)電壓值對(duì)應(yīng)的數(shù)字量,0是0V,255是5V
- uchar code juxing[64]={
- 255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,
- 255,255,255,255,255,255,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
- }; //矩形波取碼 一個(gè)周期是采樣64個(gè)點(diǎn), 所以數(shù)組內(nèi)是64個(gè)數(shù)據(jù)
- uchar code sanjiao[64]={
- 0,8,16,24,32,40,48,56,64,72,80,88,96,104,112,120,128,136,144,152,160,168,176,184,192,200,208,216,224,232,240,248,
- 248,240,232,224,216,208,200,192,184,176,168,160,152,144,136,128,120,112,104,96,88,80,72,64,56,48,40,32,24,16,8,0
- }; //三角波取碼
- uchar code juchi[64]={
- 0,4,8,12,16,20,24,28,32,36,40,45,49,53,57,61,65,69,73,77,81,85,89,93,97,101,105,109,113,117,121,125,130,134,138,142,
- 146,150,154,158,162,166,170,174,178,182,186,190,194,198,202,206,210,215,219,223,227,231,235,239,243,247,251,255
- }; //鋸齒波取碼
- void delay(uint xms) //延時(shí)函數(shù) 具體延時(shí)時(shí)間根據(jù)傳遞的x變量決定
- int a,b;
- for(a=xms;a>0;a--)
- for(b=110;b>0;b--);
- /**********寫入指令函數(shù)**********/
- void write_com(uchar com)
- lcdrs=0; //讀端置0
- P0=com; //往P0口寫入指令 即lcd地址
- delay(1); //延時(shí)
- lcden=1; //使能端從1變化到0 lcd執(zhí)行一次讀命令
- delay(1);//延時(shí)
- lcden=0; //使能端置0
- /***********寫入數(shù)據(jù)函數(shù)*********/
- void write_date(uchar date)
- lcdrs=1;//讀端口置為1
- P0=date; //數(shù)據(jù)送入P0口,寫入LCD顯示
- lcden=1; //同上
- delay(1);
- lcden=0;
- /************自定義字符集 LCD顯示模擬波形**********/
- void Lcd_ram()
- uint i,j,k=0;
- uint temp=0x40;//temp為顯示起始地址
- for(i=0;i<7;i++) //將字符集寫入
- for(j=0;j<8;j++) //寫入8個(gè)字節(jié)的字符 即zifu[]的一行數(shù)據(jù)
- write_com(temp+j);
- write_date(zifu[k]);
- k++;
- temp=temp+8; //下一個(gè)字符的起始地址
- /**********液晶初始化函數(shù)************/
- void init_lcd()
- uchar i;
- lcden=0; //默認(rèn)開始狀態(tài)為關(guān)使能端,見lcd液晶時(shí)序圖
- Lcd_ram(); // 寫入字符集
- write_com(0x0f); //
- write_com(0x38); //顯示模式設(shè)置,默認(rèn)為0x38,不用變。
- write_com(0x01); //顯示清屏,將上次的內(nèi)容清除,默認(rèn)為0x01.
- write_com(0x0c); //顯示功能設(shè)置0x0f為開顯示,顯示光標(biāo),光標(biāo)閃爍;0x0c為開顯示,不顯光標(biāo),光標(biāo)不閃
- write_com(0x06); //設(shè)置光標(biāo)狀態(tài)默認(rèn)0x06,為讀一個(gè)字符光標(biāo)加1.
- write_com(0x80); //液晶的第一行首地址
- for(i=10;i<20;i++) //將table1的wave form:顯示在第一行
- write_date(table1[i]);
- write_com(0x80+0x40); // 液晶第二行的起始地址
- for(i=0;i<9;i++) //顯示初始化 從table1的第1個(gè)字符顯示,將table1的Fout顯示在第二行
- write_com(0x80+10); //初始為正弦波 在wave form后面顯示模擬波形
- write_date(0);
- write_date(1);
- write_date(0);
- write_date(1);
- write_date(0);
- write_date(1);
- write_com(0x80+0x40+0x09); //設(shè)置初始頻率為10hz
- write_date(' ');
- write_date('1');
- write_date('0');
- write_date('.');
- write_date('0');
- write_date('H');
- write_date('z');
- /**********定時(shí)器初始化**********/
- void initclock()
- TMOD=0x01; //定時(shí)器工作方式1
- TH0=a; //賦初值
- TL0=b;
- EA=1; //打開總中斷
- ET0=1; //打開T0中斷
- TR0=1; //啟動(dòng)定時(shí)器
- /**********顯示函數(shù)(顯示模擬波形和頻率以及控制提示小燈)**********/
- void display()
- uchar qian,bai,shi,ge; //只是將頻率分成千位,百位,十位,個(gè)位四位顯示,實(shí)際并不是1000的格式
- qian=pinlv/1000; //將頻率值拆成一位的數(shù)據(jù),將數(shù)據(jù)除以1000,得到的商是一位數(shù),賦值給qian
- bai=pinlv%1000/100; //將頻率除以1000的余數(shù)再除以100就得到了頻率的百位,賦值給bai
- shi=pinlv%1000%100/10; //得到頻率的十位
- ge=pinlv%1000%100%10; //得到頻率的個(gè)位
- write_com(0x80+0x40+0x09);//顯示頻率數(shù)字起始地址 第二行第九個(gè)位置
- if(qian==0) //千位為0
- write_date(' '); //顯示空格
- else
- write_date(table[qian]);//查數(shù)組顯示千位數(shù)字
- if(qian==0&&bai==0) //千位和百位都為0
- write_date(' '); //百位不顯示
- else
- write_date(table[bai]); //顯示百位數(shù)
- write_date(table[shi]); //顯示十位數(shù)
- write_date('.'); //顯示小數(shù)點(diǎn)
- write_date(table[ge]); //顯示個(gè)位
- write_date('H');
- write_date('z');
- if(boxing==0) //正弦波
- write_com(0x80+10);//wave form:后面的地址 顯示正弦波模擬波形
- write_date(0);
- write_date(1);
- write_date(0);
- write_date(1);
- write_date(0);
- write_date(1);
- led3=1;
- led0=0; //led0小燈亮 提示正弦波
- if(boxing==1) // 方波
- write_com(0x80+10); //顯示方波模擬波形
- write_date(2);
- write_date(3);
- write_date(2);
- write_date(3);
- write_date(2);
- write_date(3);
- led0=1;
- led1=0; //led1小燈亮 提示方波
- if(boxing==2) //三角波
- write_com(0x80+10); //顯示三角波模擬波形
- write_date(4);
- write_date(5);
- write_date(4);
- write_date(5);
- write_date(4);
- write_date(5);
- led1=1;
- led2=0; //led2小燈亮 提示三角波
- if(boxing==3) //鋸齒波
- write_com(0x80+10); //顯示鋸齒波模擬波形
- write_date(6);
- write_date(6);
- write_date(6);
- write_date(6);
- write_date(6);
- write_date(6);
- led2=1;
- led3=0; //led小燈亮 提示鋸齒波
- /*********鍵盤檢測(cè)函數(shù)************/
- void keyscan()
- if(s1==0) //頻率加按鍵
- EA=0; //關(guān)閉定時(shí)器總中斷
- delay(2); //延時(shí)消除鍵盤抖動(dòng)
- if(s1==0)
- while(!s1); //等待按鍵松開
- pinlv+=bujin; //根據(jù)步進(jìn)值增加頻率
- if(pinlv>1000) //頻率值如果大于100 則重新賦值為100
- pinlv=100;
- display();
- m=65536-(150000/pinlv);/*頻率值最小是10Hz,pinlv的值是100(因?yàn)橐@示小數(shù)點(diǎn)后一位),150000/100=1500,這個(gè)1500就是定時(shí)器需要計(jì)時(shí)的,單位是us,65536-1500得到的是定時(shí)器的初值,
- 先不管初值,先看定時(shí)時(shí)間,1500us,一個(gè)波形的周期是由64個(gè)定時(shí)(前面四個(gè)波形數(shù)組)組成的,所以,一個(gè)波形周期就是64*1500us=96000,也就是96ms,約等
- 于100ms,也就是10Hz的頻率*/
- a=m/256; //將定時(shí)器的初值賦值給變量
- b=m%256;
- EA=1; //開啟總中斷
- if(s2==0) //頻率減按鍵
- delay(5); //延時(shí)消抖
- if(s2==0)
- EA=0;
- while(!s2);
- pinlv-=bujin; //根據(jù)步進(jìn)值減頻率
- if(pinlv<100)
- pinlv=1000;
- display();
- m=65536-(150000/pinlv); //同上
- a=m/256;
- b=m%256;
- EA=1;
- if(s3==0) //調(diào)換波形按鍵
- delay(5);
- if(s3==0)
- EA=0;
- while(!s3);
- boxing++;
- if(boxing>=4)
- boxing=0;
- display();
- EA=1;
- /*********步進(jìn)值設(shè)置界面顯示函數(shù)*********/
- void bujindisplay()
- uint bai,shi,ge; //將步進(jìn)值分百位,十位,個(gè)位顯示,但是并不是100的形式
- bai=bujin1/100; //將步進(jìn)值除以100得到百位,也就是頻率值的十位,因?yàn)橛幸粋(gè)小數(shù)位
- shi=bujin1%100/10;//將步進(jìn)值除以100的余數(shù)除以十得到十位
- ge=bujin1%100%10; //取余10后得到個(gè)位,也就是頻率步進(jìn)值的小數(shù)點(diǎn)后一位
- write_com(0x80+11);//選中液晶第一行第十一列
- if(bai==0) //百位是否為0
- write_date(' ');//百位不顯示 空格
- else //百位不為0
- write_date(table[bai]); //顯示百位數(shù)據(jù)
- write_date(table[shi]); //顯示十位數(shù)據(jù)
- write_date(table[ge]); //顯示個(gè)位,也就是小數(shù)點(diǎn)后一位
- /**********步進(jìn)設(shè)置按鍵************/
- void bujinjiance()
- if(s4==0) //步進(jìn)設(shè)置按鍵按下
- delay(5); //延時(shí)去抖
- if(s4==0) //再次判斷按鍵
- while(!s4); //按鍵釋放,按鍵松開才繼續(xù)向下執(zhí)行
- h++; //變量加
- if(h==1) //進(jìn)入設(shè)置狀態(tài)時(shí)
- write_com(0x01); //液晶清屏
- write_com(0x80); //初始化顯示步進(jìn)設(shè)置界面
- write_date('S');delay(1); //step value(步進(jìn)值)
- write_date('t');delay(1);
- write_date('e');delay(1);
- write_date('p');delay(1);
- write_date(' ');delay(1);
- write_date('v');delay(1);
- write_date('a');delay(1);
- write_date('l');delay(1);
- write_date('u');delay(1);
- write_date(':');delay(1);
- bujin1=bujin; //步進(jìn)值賦值給臨時(shí)變量
- bujindisplay();//顯示步進(jìn)值
- if(h==2) //退出設(shè)置
- h=0;
- bujin=bujin1; //設(shè)置好的臨時(shí)步進(jìn)值賦值給步進(jìn)變量
- init_lcd(); //初始化液晶顯示
- initclock(); //定時(shí)器初始化
- display(); //調(diào)用顯示程序
- if(h==1) //設(shè)置步進(jìn)值時(shí)
- if(s1==0) //加按鍵按下(此時(shí)是加步進(jìn)值不是加頻率)
- if(s1==0) //再次判斷
- while(!s1); //按鍵釋放
- bujin1++; //步進(jìn)值加1
- if(bujin1>=101) //步進(jìn)值最大100,也就是10.0Hz
- bujin1=1; //超過最大值就恢復(fù)到0.1Hz
- bujindisplay(); //步進(jìn)值顯示
- if(s2==0) //減按鍵(減步進(jìn)值),注釋與上面同理
- delay(5);
- if(s2==0)
- while(!s2);
- bujin1--;
- if(bujin1<=0)
- bujin1=100;
2021-1-3 18:15 上傳
簡(jiǎn)易波形發(fā)生器.zip
(109.45 KB, 下載次數(shù): 201)
2021-1-3 16:49 上傳
點(diǎn)擊文件名下載附件
可模擬四種波形 下載積分: 黑幣 -5
