查看: 2943|回復(fù): 2
倒計(jì)時(shí)5秒六路搶答器改成倒計(jì)時(shí)10秒或者9秒的八路搶答器
ID:872134 發(fā)表于 2021-1-4 14:48 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
10黑幣
倒計(jì)時(shí)5秒的六路搶答器
#include<reg51.h>
sbit dula=P2^6;
sbit wela=P2^7;
sbit beep=P2^3;
uchar key,j,k,temp,daojishi=5,wei;
bit begin,end,clear,fangui;
uchar a0,b0=16;c0=16;d0=16;e0=16;f0=5;
unsigned int pp;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
                        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00};
void delay(unsigned char i)
  for(j=i;j>0;j--)
    for(k=125;k>0;k--);
void display(uchar a,uchar b,uchar c,uchar d,uchar e,uchar f)
   dula=0;
   P0=table[a];
   dula=1;
   dula=0;
   wela=0;
   P0=0xfe;
   wela=1;
   wela=0;
   delay(5);
   P0=table[b];
   dula=1;
   dula=0;
   P0=0xfd;
   wela=1;
   wela=0;
   delay(5);
   P0=table[c];
   dula=1;
   dula=0;
   P0=0xfb;
   wela=1;
   wela=0;
   delay(5);
   P0=table[d];
   dula=1;
   dula=0;
   P0=0xf7;
   wela=1;
   wela=0;
   delay(5);
   P0=table[e];
   dula=1;
   dula=0;
   P0=0xef;
   wela=1;
   wela=0;
   delay(5);
   P0=table[f];
   dula=1;
   dula=0;
   P0=0xdf;
   wela=1;
   wela=0;
   delay(5);
void keyscan()
        P3=0xfe;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xee:
               key=1;
                           wei++;
               break;
          case 0xde:
               key=2;
                           wei++;
               break;
          case 0xbe:
               key=3;
                           wei++;
               break;
          case 0x7e:
               key=4;
                           wei++;
               break;
         while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
    P3=0xfd;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xed:
               key=5;
                           wei++;
               break;
          case 0xdd:
               key=6;
                           wei++;
               break;
          case 0xbd:
               clear=1;
                           //key=7;
               break;
          case 0x7d:
                             begin=1;
               //key=8;
               break;
         while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
        TMOD=0x01;
        TH0=(65536-46080)/256;// óéóú¾§ÕñÎa11.0592,1êËù¼Ç′Îêyó|Îa46080£¬¼Æê±Æ÷ÿ¸ô50000΢Ãë·¢Æeò»′ÎÖD¶Ï¡£
        TL0=(65536-46080)%256;//46080μÄà′àú£¬Îa50000*11.0592/12
        ET0=1;
        EA=1;
                keyscan();
                if(begin)
                        if(!end)
                                TR0=1;
                                //if(!daojishi)        daojishi=5;
                                //begin=0;
                                //daojishi=5;
                                if(pp==20)
                                        pp=0;
                                        daojishi--;
                        f0=daojishi;
                        if(key!=0)
                        a0=key;
                //        a1=a0;
                        //if(a0!=0)        end=1;
                        if(!daojishi|a0)
                                end=1;
                                TR0=0;
                                //daojishi=5;
                        //        begin=0;
                                pp=0;
                        if(key!=0)
                        switch(wei)
                                case 1: a0=key;break;
                                case 2: b0=key;break;
                                case 3: c0=key;break;
                                case 4: d0=key;break;
                                case 5: e0=key;break;
                        //if(!fangui)
                                fangui=1;
                                beep=0;
        if(clear)
                a0=0;key=0;begin=0;end=0;fangui=0;beep=1;daojishi=5;f0=5;clear=0;
                b0=16;c0=16;d0=16;e0=16;wei=0; P1=0xff;
        display(a0,b0,c0,d0,e0,f0);
        if(fangui)
                beep=0;
                P1=0x00;;
void time0() interrupt 1
{        TH0=(65536-46080)/256;
        pp++;
ID:328014 發(fā)表于 2021-1-4 15:11 | 只看該作者
謝謝分享 沒有原理圖?
ID:872134 發(fā)表于 2021-1-4 15:20 | 只看該作者
能幫忙改一下或者幫忙注釋一下這段程序嗎?
