查看: 7097|回復(fù): 7
STC15W408AS單片機(jī)+MAX6675+TM1637,K型熱電偶測(cè)溫程序
ID:562627 發(fā)表于 2021-1-4 14:58 | 顯示全部樓層 |閱讀模式
制作出來的實(shí)物圖如下:
51hei圖片_20210104144757.jpg 51hei圖片_202101041447571.jpg 51hei圖片_202101041447573.jpg 51hei圖片_202101041447572.jpg 51hei圖片_202101041447574.jpg
  1. #include "stc15.h"  //reg51.h
  2. #include "intrins.h"
  3. #include  "TM1637.h"
  4. typedef unsigned char u8;
  5. typedef unsigned int u16;
  6. sbit    SO            = P3^6;
  7. sbit    SCK           = P1^0;
  8. sbit    CS            = P3^7;
  9. /*------定義驅(qū)動(dòng)數(shù)碼管的片選表和斷碼表---------------*/
  10. /***************************數(shù)碼管段選表*************************/
  11. unsigned char code SEGData[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x73,0x40,0x00,0x39};
  12.                    //  0    1    2    3    4    5    6    7    8    9    P     -   滅    C
  13. unsigned char code SEGDataDp[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};
  14.                    //有小數(shù)點(diǎn)只用于地址0xc1
  15. u16 temp,temp_1,t;
  16. u8  Flag_connect;
  17. bit flag;
  18. /******************定時(shí)器相關(guān)程序**********************/
  19. void time2_init(void) //定時(shí)器2初始化
  20. {
  21.    AUXR |= 0x04;    //使用模式1,16位定時(shí)器,使用"|"符號(hào)可以在使用多個(gè)定時(shí)器時(shí)不受影響
  22.    T2L = 0xCD;                  //設(shè)置定時(shí)初值
  23.    T2H = 0xD4;                  //設(shè)置定時(shí)初值
  24.    AUXR |= 0x10;    //定時(shí)器2開始計(jì)時(shí)
  25.    IE2 |= 0x04;     //開定時(shí)器2中斷
  26. }
  27. void timer2 (void) interrupt 12         //Timer2 1ms中斷函數(shù)
  28. {
  29.         static u16 num;
  30.         T2L = 0xCD;                 //設(shè)置定時(shí)初值
  31.         T2H = 0xD4;                 //設(shè)置定時(shí)初值
  32.     num++;
  33.     if(num==170)
  34.     {
  35.           num=0;
  36.                   flag =1;
  37.     }
  38.
  39. }
  40. void display( void )
  41. {
  42.      if(Flag_connect==0)                          //Flag_connect為0 表示熱電偶已連接,這時(shí)顯示溫度
  43.         {
  44.                         TM1637_writeCammand(0x44);
  45.                         TM1637_writeData(0xc3, SEGData[temp%10]);
  46.                     TM1637_writeData(0xc2, SEGData[temp%100/10]);
  47.                         TM1637_writeData(0xc1, SEGData[temp%1000/100]);
  48.                         TM1637_writeData(0xc0, SEGData[temp/1000]);
  49.                         TM1637_writeCammand(0x8f);
  50.         }
  51.         else
  52.         {
  53.                         TM1637_writeCammand(0x44);
  54.                         TM1637_writeData(0xc0, SEGData[16]);
  55.                     TM1637_writeData(0xc1, SEGData[16]);
  56.                         TM1637_writeData(0xc2, SEGData[16]);
  57.                         TM1637_writeData(0xc3, SEGData[16]);
  58.                         TM1637_writeCammand(0x8f);
  59.         }
  60. }
原理圖: 無
仿真: 無
代碼: 測(cè)溫.rar (763.18 KB, 下載次數(shù): 302)
ID:872598 發(fā)表于 2021-1-13 14:23 | 顯示全部樓層
外圍元件少,占用資源小,實(shí)用性好。
ID:234836 發(fā)表于 2021-1-18 18:17 | 顯示全部樓層
這個(gè)資料非常不錯(cuò)!
ID:444215 發(fā)表于 2023-8-26 10:03 | 顯示全部樓層
很好,沒看到原理圖呢?
ID:1111014 發(fā)表于 2024-2-26 12:44 | 顯示全部樓層
我用MAX6675制作了4路測(cè)溫器,發(fā)現(xiàn)不同通道之間(繼電器切換熱電偶)誤差較大,可以到1~3攝氏度;在立創(chuàng)重新買了6675后,還是誤差大,沒有找到原因。不知樓主或者各位朋友是否遇到過這現(xiàn)象?謝謝!
ID:1112603 發(fā)表于 2024-3-21 08:53 | 顯示全部樓層
正在學(xué)習(xí)測(cè)溫電路,做一個(gè)溫控控制器,下載學(xué)習(xí)。
ID:71233 發(fā)表于 2024-3-21 21:39 | 顯示全部樓層
測(cè)溫不困難,困難的是控溫。
ID:961114 發(fā)表于 2024-3-22 17:00 | 顯示全部樓層
我想到了這個(gè)
第62期-ADC模數(shù)轉(zhuǎn)換-NTC測(cè)溫-經(jīng)驗(yàn)公式法、查表法、Steinhart-Hart方程法-STC32G12K128系列視頻_嗶哩嗶哩_bilibili
