查看: 3209|回復(fù): 4
51單片機(jī)溫度計(jì)2.0版ds18b20+0.96寸OLED IIC顯示
ID:862583 發(fā)表于 2021-1-4 15:10 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
51單片機(jī)溫度計(jì)LCD1602顯示成功,于是又挑戰(zhàn)了OLED顯示
main.c
#include"oled.h"
#include"ds18b20_1.h"
void Timer0Init(void);
//void Gao_Wen(void);
//void GaoDiInit(void);
sbit Deng=P1^0;                           //LED燈
sbit FengMing=P1^1;                       //蜂鳴器
sbit GD=P3^0;                             //兩個(gè)功能:高限溫減小,關(guān)閉LED燈
sbit GF=P3^1;                             //兩個(gè)功能:低限溫增加,關(guān)閉蜂鳴器
sbit GW=P3^2;                             //高限溫增加
sbit DW=P3^3;                             //低限溫減小
//unsigned char GaoWen_Y[]={"GW:"};         //高限溫顯示
//unsigned char DiWen_Y[]={"DW:"};          //低限溫顯示
int GaoWen=40;                  //高限溫
int DiWen=-20;                  //低限溫
char flag=0;                    //一秒標(biāo)志位
char b=0;                       //定時(shí)器內(nèi)部標(biāo)志位;
/*******************************主程序區(qū)域********************************/
int main()
        bit ack;
        bit k=1;                      //決定超出限溫后,關(guān)閉燈和蜂鳴器后不再響,而低于限溫后再次超出限溫后,依然能響標(biāo)志位;
        int Zhen=0,Xiao=0;
        unsigned char temp[10];
        char len=0;
        int wenDu=0;                  //接收溫度
//        LCD_Init();
        Deng=0;                   //LCD初始化
        OLED_Init();
        Start18B20();                 //溫度傳感器初始化
        Timer0Init();                 //T0定時(shí)器初始化
        Delay10ms();
//        LCD_WeiZhi(1,0);
//        LCD_XianShi(GaoWen_Y);
//        LCD_WeiZhi(1,9);
//        LCD_XianShi(DiWen_Y);
//        GaoDiInit();
        OLED_ShowChinese(0,0,10,16);
        OLED_ShowChinese(18,0,13,16);
        OLED_ShowChar(36,0,':',16);
        OLED_ShowChinese(0,2,8,16);
        OLED_ShowChinese(18,2,10,16);
        OLED_ShowChinese(36,2,11,16);
        OLED_ShowChinese(54,2,12,16);
        OLED_ShowChar(70,2,':',16);
        OLED_ShowChinese(0,4,9,16);
        OLED_ShowChinese(18,4,10,16);
        OLED_ShowChinese(36,4,11,16);
        OLED_ShowChinese(54,4,12,16);
        OLED_ShowChar(70,4,':',16);
//        OLED_ShowString(0,2,"GW:",16);
//        OLED_ShowString(64,2,"DW:",16);
        OLED_Num(78,2,GaoWen,3,16);
        OLED_Num(78,4,DiWen,3,16);
                if(flag==1)                 //1秒刷新溫度
                        flag=0;
                        ack=Read18B20(&wenDu);
                  if(ack)
                                Zhen=wenDu>>4;
                                Xiao=wenDu&0x0f;
                                len=OLED_Xian_Zheng(Zhen,temp);
                                temp[len++]='.';
                                Xiao=(Xiao*100)*0.0625;
                                temp[len++]=Xiao/10+'0';
//                                temp[len++]=Xiao%10+'0';
                                while(len<5)
                                        temp[len++]=' ';
                                temp[len]='\0';
//                                LCD_WeiZhi(0,0);
//                                LCD_XianShi(temp);
                                OLED_ShowString(44,0,temp,16);
                        Start18B20();
                if((Zhen>=GaoWen||Zhen<=DiWen)&&k)
                        Deng=1;
                        FengMing=0;
                if(Zhen>DiWen&&Zhen<GaoWen)
                        Deng=0;
                        FengMing=1;
                        k=1;
                if(GD==0)
                        Delay10ms();
                        if(GD==0)
                                if(Deng==0)
                                        GaoWen--;
//                                        Delay400ms();
//                                        GaoDiInit();
//                                        OLED_Num(20,2,GaoWen,3,16);
//                                        Delay400ms();
                                        Deng=0;
                                        k=0;
                if(GF==0)
                        Delay10ms();
                        if(GF==0)
                                if(FengMing==1)
                                        DiWen++;
//                                        Delay400ms();
//                                        GaoDiInit();
//                                        OLED_Num(84,2,DiWen,3,16);
//                                        Delay400ms();
                                        FengMing=1;
                                        k=0;
/********************************定時(shí)器初始化******************************/
        void Timer0Init(void)                //50毫秒@12.000MHz
        EA=1;
        ET0=1;
        EX0=1;
        EX1=1;
        IT0=1;
        IT1=1;
  IP=0;
        PT0=1;
        TMOD &= 0xF0;                //設(shè)置定時(shí)器模式
        TMOD |= 0x01;                //設(shè)置定時(shí)器模式
        TL0 = 0x00;                //設(shè)置定時(shí)初值
        TH0 = 0x4C;                //設(shè)置定時(shí)初值
        TF0 = 0;                //清除TF0標(biāo)志
        TR0 = 1;                //定時(shí)器0開始計(jì)時(shí)
/******************************T0中斷**********************************/
void IT0_1(void) interrupt 1
        b++;
        if(b>=20)
                b=0;
                flag=1;
/***************************高限溫增加*************************************/
void Gao(void) interrupt 0
        GaoWen++;
        if(GaoWen>128)
                GaoWen=128;
                FengMing=0;
                Delay100ms();
                FengMing=1;
//        GaoDiInit();
/*******************************低限溫減小********************************/
void Di(void) interrupt 2
        DiWen--;
        if(DiWen<-55)
                DiWen=-55;
                FengMing=0;
                Delay100ms();
                FengMing=1;
//                GaoDiInit();
//        OLED_Num(84,2,GaoWen,3,16);
程序.zip
145.76 KB, 下載次數(shù): 149, 下載積分: 黑幣 -5
收藏收藏2 分享淘帖 頂 踩
ID:856401 發(fā)表于 2021-1-12 22:15 | 只看該作者
這么好的資料,竟然沒(méi)人回復(fù)
ID:877000 發(fā)表于 2021-1-13 00:30 來(lái)自觸屏版 | 只看該作者
在嗎,我想讓你看看我的怎么弄
ID:877149 發(fā)表于 2021-1-13 14:23 | 只看該作者
為什么我的報(bào)錯(cuò)46個(gè)
ID:250631 發(fā)表于 2021-1-13 18:38 | 只看該作者
編譯通過(guò),改天有空試試。感謝樓主無(wú)私分享
