查看: 3517|回復(fù): 8
再幫我看看這個(gè)超聲波測(cè)距程序,太感謝了!
ID:50469 發(fā)表于 2013-7-23 19:13 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#include<intrins.h>
#define uint  unsigned int
#define NOP() {_nop_();_nop_();_nop_();_nop_();}
//------LCD引腳-----
sbit LCD_RS=P4^5;
sbit LCD_RW=P5^5;
sbit LCD_EN=P5^4;
//------超聲波引腳---
sbit Tx=P1^0; //觸發(fā)控制信號(hào)輸入
sbit Rx=P3^2;  //回響信號(hào)輸出
uchar code table[]="Distance:"; //LCD第一行顯示
uchar temp_dis[]="000.0cm"; //LCD第二行
uint t,distance;
uchar cache[4]={0,0,0,0};
//--------延時(shí)-------
void delay(uint ms)
uint t;
while(ms--)
  for(t=0;t<120;t++);
//----------LCD寫指令----------
void lcd_write_com(uchar com)
LCD_RS=0;
LCD_RW=0;
P0=com;
LCD_EN=1;
   delay(5);
LCD_EN=0;
//----------LCD寫數(shù)據(jù)----------
void lcd_write_data(uchar dat)
LCD_RS=1;
LCD_RW=0;
P0=dat;
LCD_EN=1;
delay(5);
LCD_EN=0;
//-------LCD初始化-------
void lcd_init()
LCD_EN=0;
lcd_write_com(0x38); //LCD顯示模式設(shè)置
lcd_write_com(0x0c); //LCD顯示開/關(guān)及光標(biāo)設(shè)置
lcd_write_com(0x06); //當(dāng)寫一個(gè)字符后地址指針加1,且光標(biāo)加1
lcd_write_com(0x01);  //顯示清屏
//---------液晶顯示程序----------
void lcd_print( )
uint num=0;
lcd_write_com(0x80);
while(table[num]!='\0')
  lcd_write_data(table[num]);
  num++;
  delay(5);
num=0;
lcd_write_com(0xc0);
while(temp_dis[num]!='\0')
  lcd_write_data(temp_dis[num]);
  num++;
  delay(5);
void hcsr04_Init()
delay(60);
Tx=1;//觸發(fā)脈沖
NOP();NOP();NOP();
Tx=0;
distance=1.7*t/100;   //距離計(jì)算cm
void distance_convert( uint dat)
cache[0]=dat/100;
cache[1]=dat%100/10;
cache[2]=dat%10;
cache[3]=dat*10%10;
temp_dis[0]=cache[0]+'0';
temp_dis[1]=cache[1]+'0';
temp_dis[2]=cache[2]+'0';
temp_dis[4]=cache[3]+'0';
//------------主程序-----------
lcd_init();
delay(5);
TMOD=0x09;
EA=1;   //開總中斷
TR0=1;  //啟動(dòng)定時(shí)器
EX0=1;  //開外部中斷
// ET0=1; //開定時(shí)器中斷
IT0=1;  //設(shè)置為下降沿中斷方式
  hcsr04_Init();
  lcd_print();
  distance_convert(distance);
//外部中斷0
void int0() interrupt 0
t=TH0*256+TL0; //計(jì)算高電平持續(xù)的時(shí)間,上升沿到來時(shí)候開始計(jì)時(shí),
TH0=0;    //下降沿到來進(jìn)入外部中斷,關(guān)閉計(jì)時(shí)器,停止計(jì)時(shí)
TL0=0;
ID:1 發(fā)表于 2013-7-25 00:18 | 顯示全部樓層
這個(gè)程序什么問題?
ID:52115 發(fā)表于 2013-7-27 19:17 | 顯示全部樓層
我記得我用的超聲波模塊觸發(fā)信號(hào)要10us的高電平(30us最佳)
ID:52115 發(fā)表于 2013-7-27 19:19 | 顯示全部樓層
你的觸發(fā)信號(hào)好像不行
ID:52343 發(fā)表于 2013-7-27 22:49 | 顯示全部樓層
ID:50469 發(fā)表于 2013-8-6 11:17 | 顯示全部樓層
admin 發(fā)表于 2013-7-25 00:18
這個(gè)程序什么問題?
奇怪了,好像確實(shí)沒什么問題了,但前兩天寫出來不能用啊,還是謝了,呵呵
ID:50469 發(fā)表于 2013-8-6 11:18 | 顯示全部樓層
不過不是很準(zhǔn)確,總是差那么2.3厘米
ID:159841 發(fā)表于 2017-1-4 23:22 | 顯示全部樓層
這個(gè)程序是錯(cuò)的吧  你試國(guó)沒有
ID:160258 發(fā)表于 2017-1-5 22:32 | 顯示全部樓層
程序看不懂
