查看: 3129|回復(fù): 2
stm32一線串口WT588S語(yǔ)音芯片驅(qū)動(dòng)程序
ID:368635 發(fā)表于 2021-1-15 16:30 | 顯示全部樓層 |閱讀模式
  1. #include "wt588s16s.h"
  2. #include "delay.h"
  3. /**************************************************************************************************
  4. * @fn             Initialize_wt588s16s_pins
  5. *
  6. * @brief   初始化芯片引腳,BUSY、DATA
  7. *
  8. * @param   none
  9. *
  10. * @return  None
  11. **************************************************************************************************/
  12. void Initialize_wt588s16s_pins(void)
  13. {
  14.                 GPIO_InitTypeDef  GPIO_InitStructure;
  15.
  16.                 RCC_APB2PeriphClockCmd(WT588S16S_DATA_PERIPH,ENABLE);
  17.                 RCC_APB2PeriphClockCmd(WT588S16S_BUSY_PERIPH,ENABLE);
  18.                 GPIO_InitStructure.GPIO_Pin  = WT588S16S_DATA;
  19.                 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  20.                 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  21.                 GPIO_Init(WT588S16S_DATA_GPIO, &GPIO_InitStructure);
  22.                 GPIO_InitStructure.GPIO_Pin  = WT588S16S_BUSY;
  23.                 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  24.                 GPIO_Init(WT588S16S_BUSY_GPIO, &GPIO_InitStructure);
  25.
  26.                 GPIO_SetBits(WT588S16S_DATA_GPIO,  WT588S16S_DATA);
  27. }
  28. /**************************************************************************************************
  29. * @fn             Line_send_one_byte
  30. *
  31. * @brief   發(fā)送一個(gè)字節(jié)數(shù)據(jù)
  32. *
  33. * @param   none
  34. *
  35. * @return  None
  36. **************************************************************************************************/
  37. void Line_send_one_byte(unsigned char data)
  38. {
  39.                 unsigned char i;
  40.                 unsigned char data_temp = 0;
  41.                 for( i=0; i<8; i++){
  42.                         GPIO_SetBits(WT588S16S_DATA_GPIO,  WT588S16S_DATA);        //拉高發(fā)送數(shù)據(jù)
  43.
  44.                         data_temp = (data>>i)&0x01;
  45.
  46.                         if(data_temp == 0){
  47.                                         delay_us(200); //200us
  48.                                         GPIO_ResetBits(WT588S16S_DATA_GPIO,  WT588S16S_DATA);
  49.                                         delay_us(600); //600us
  50.                         }else{
  51.                                         delay_us(600); //600us
  52.                                         GPIO_ResetBits(WT588S16S_DATA_GPIO,  WT588S16S_DATA);
  53.                                         delay_us(200); //200us
  54.                         }
  55.                 }
  56. }
  57. /**************************************************************************************************
  58. * @fn             Line_send_stop
  59. *
  60. * @brief   發(fā)送結(jié)束標(biāo)志
  61. *
  62. * @param   none
  63. *
  64. * @return  None
  65. **************************************************************************************************/
  66. void Line_send_stop(void)
  67. {
  68.                 //地址數(shù)據(jù)連接符
  69.                 GPIO_SetBits(WT588S16S_DATA_GPIO,  WT588S16S_DATA);
  70.                 delay_us(2000); //2MS
  71.                 GPIO_ResetBits(WT588S16S_DATA_GPIO,  WT588S16S_DATA);
  72.                 delay_us(5000); //5MS
  73. }
  74. /**************************************************************************************************
  75. * @fn             WT588S_play_music
  76. *
  77. * @brief   播放音樂(lè)
  78. *
  79. * @param   data:控制命令
  80. *
  81. * @return  None
  82. **************************************************************************************************/
  83. void WT588S_play_music(unsigned short data)
  84. {
  85.                 unsigned char data_temp_1,data_temp_2;
  86.
  87.                 data_temp_2 = (unsigned char)(data>>8);
  88.                 data_temp_1 = (unsigned char)(data&0x00ff);
  89.
  90.                 Line_send_stop();
  91.                 Line_send_one_byte(data_temp_1);
  92.                 Line_send_stop();
  93.                 Line_send_one_byte(data_temp_2);
  94. }
所有程序51hei提供下載:
wt588s16s.zip (1.33 KB, 下載次數(shù): 32)
ID:958310 發(fā)表于 2021-10-27 09:11 | 顯示全部樓層
那個(gè)SPI是語(yǔ)音芯片接SD卡的吧,不是接MCU的
ID:88060 發(fā)表于 2021-7-28 13:53 | 顯示全部樓層
還要SPI呢,接口太多了
