查看: 2187|回復(fù): 9
C51單片機(jī)注解處的書(shū)寫(xiě)合理不?
ID:483865 發(fā)表于 2021-1-17 19:48 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
sbit ADDR2 = P1^2;
sbit ADDR1 = P1^1;
sbit ADDR0 = P1^0;
bit flag500ms = 0;
unsigned char T0RH = 0;
unsigned char T0RL = 0;
void ConfigTimer0(unsigned int ms);
        unsigned char i = 0;
        unsigned char LedBuf[8] = {0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F};
        EA = 1;
        ConfigTimer0(10);
        ENLED = 0;
        ADDR3 = 1;
        ADDR2 = 1;
        ADDR1 = 1;
        ADDR0 = 0;
                if(flag500ms == 1)
                        flag500ms = 0;
                        P0 = LedBuf[i++];        //這里合理不?
        unsigned long tmp;
        tmp = 11059200/12;
        tmp = (tmp * ms)/1000;
        tmp = 65536 - tmp;
        tmp = tmp + 12;
        T0RH = (unsigned char)(tmp >> 4);
        T0RL = (unsigned char)tmp;
        TMOD &= 0xF0;
        TMOD |= 0x01;
        TH0 = T0RL;
        TL0 = T0RL;
        ET0 = 1;
        TR0 = 1;
void interruptTimer0() interrupt 1
        static unsigned char tmr500ms = 0;
        TH0 = T0RH;
        TL0 = T0RL;
        tmr500ms++;
        if(tmr500ms >= 50)
                tmr500ms = 0;
                flag500ms = 1;
ID:68468 發(fā)表于 2021-1-17 20:23 | 顯示全部樓層
注解處問(wèn)題不大吧,但LedBuf[]數(shù)組只有8個(gè),i累加超過(guò)7以后就.......
參與人數(shù) 1黑幣 +20 收起 理由
ID:483865 發(fā)表于 2021-1-17 20:35 | 顯示全部樓層
wysh_2004 發(fā)表于 2021-1-17 20:23
代碼是我參考師傅的代碼編的,在開(kāi)發(fā)板上跑正常。讓我自己懷疑這個(gè)i值,要不要加歸零的語(yǔ)句。
ID:415064 發(fā)表于 2021-1-17 21:30 | 顯示全部樓層
這個(gè)EA是什么我沒(méi)看懂啊,可以看下內(nèi)存EA 或者ENLED 的地址,大概率LedBuf后面的地址是ENLED或者是沒(méi)有用賦過(guò)初值的。也就是i到7之后就去了LedBuf[8],而LedBuf[8]在內(nèi)存的值恰好是0.所以說(shuō)此時(shí)i=0;也就解釋了為什么程序可以正常運(yùn)行
如果你在 unsigned char LedBuf[8] = {0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F}后,EA = 1前加一句 unsigned char j = 7;這樣就會(huì)一直為L(zhǎng)edBuf[7],但是程序沒(méi)有卡死的
ID:483865 發(fā)表于 2021-1-18 08:03 | 顯示全部樓層
謝謝你的回復(fù),這樣改代碼能跑是巧合。我改用數(shù)碼管顯示,發(fā)現(xiàn)這樣的錯(cuò)誤了。
ID:592807 發(fā)表于 2021-1-18 08:55 | 顯示全部樓層
你的  i 是哪來(lái)的?聲明了沒(méi)有?哪種類型?超出數(shù)組范圍怎么處理?
ID:367934 發(fā)表于 2021-1-18 09:09 | 顯示全部樓層
要是循環(huán)必須歸零,否則會(huì)超出數(shù)組范圍?梢栽谂袛嗄睦锛右粋(gè)條件,
ID:483865 發(fā)表于 2021-1-18 14:46 | 顯示全部樓層
適得府君書(shū) 發(fā)表于 2021-1-18 09:09
要是循環(huán)必須歸零,否則會(huì)超出數(shù)組范圍。可以在判斷哪里加一個(gè)條件,
嗯,明白了。謝謝。
ID:872416 發(fā)表于 2021-1-18 14:55 來(lái)自手機(jī) | 顯示全部樓層
i循環(huán)8次后重新賦值0
ID:878845 發(fā)表于 2021-1-19 13:44 | 顯示全部樓層
只是書(shū)寫(xiě)規(guī)范問(wèn)題,實(shí)際這里運(yùn)行沒(méi)問(wèn)題,但寫(xiě)軟件來(lái)說(shuō)防呆是必要的,否則以后出什么事還是要回來(lái)找的
