查看: 1576|回復(fù): 0
矩陣鍵盤(pán)模擬洗衣機(jī) stc89c52
ID:812531 發(fā)表于 2021-1-19 18:39 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <reg52.h>
typedef unsigned char uchar;
typedef unsigned int uint;
sbit key1=P3^5;
sbit RS = P1^0;
sbit RW = P1^1;
sbit EN = P2^5;
sbit led=P1^5;
sbit led1=P1^6;
sbit led2=P1^4;
unsigned char KeyPro();
unsigned char num1,c,e;
unsigned char d=6;
unsigned char time,clock;
unsigned char temp,num;//???????
bit flag=0;
      unsigned char num,a,b,d,e;
unsigned char i;
void delayms(unsigned int xms)
   unsigned i,j;
        for(i=xms;i>0;i--)
           for(j=110;j>0;j--);
void Read_Busy()
        uchar busy;
        P0 = 0xff;
        RS = 0;
        RW = 1;
        do
                EN = 1;
                busy = P0;
                EN = 0;
        }while(busy & 0x80);
//?LCD1602??????
void Write_Cmd(uchar cmd)
        Read_Busy();//???
        RS = 0;
        RW = 0;
        P0 = cmd;
        EN = 1;
        EN = 0;
void Write_Dat(uchar dat)
        Read_Busy();
        RS = 1;
        RW = 0;
        P0 = dat;
        EN = 1;
        EN = 0;
void charter(unsigned char x,unsigned char y,unsigned char dat)
if(y==0)
Write_Cmd(0x80+x);
Write_Cmd(0xc0+x);
Write_Dat( dat);
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
Write_Cmd(0x80 + x);
Write_Cmd(0xC0 + x);
while (*s)
Write_Dat( *s);
s ++;
void lcdinit()
   Write_Cmd(0x38);
   Write_Cmd(0x08);    /*????*/
   Write_Cmd(0x01);    /*????*/
   Write_Cmd(0x06);    /*????????*/
   Write_Cmd(0x0C);    /*????????*/
void Timer0Init(void)                //50??@11.0592MHz
        TMOD = 0x01;                //???????
        TL0 = 0x00;                //??????
        TH0 = 0x4C;                //??????
                ET0=1;
        EA=1;
        TR0 = 0;                //???0????
lcdinit();
Timer0Init();
        LCD_Write_String(4,0,"welcome");
LCD_Write_String(0,1,"count:");
KeyPro();
        a=num1/10;
        b=num1%10;
charter(6,1,'0'+a);
charter(7,1,'0'+b);
if(flag==1)
        led1=~led1;
num1--;
                        d=num1/10;
        e=num1%10;
charter(6,1,'0'+a);
charter(7,1,'0'+b);
flag=0;
        if(num1==0)
        TR0=0;
unsigned char KeyScan(void)  //??????,?????????
P3=0x0f;            //??????0
temp=P3&0x0f;     //?????
if(temp!=0x0f)    //?????????
  delayms(10);        //??
  if((P3&0x0f)!=0x0f)
    P3=temp|0xf0;  //???????
    num=P3&0xf0;  //?????
    while((P3&0xf0)!=0xf0);//???????
    return(temp+num);//????????
unsigned char KeyPro(void)
switch(KeyScan())
  case 0x7e:TR0=1;break;//0 ??????????????
  case 0x7d:num1=10;break;//1
  case 0x7b:num1=15;break;//2
  case 0x77:num1=20;break;//3
  case 0xbe:num1++;break;//4
  case 0xbd:num1--;break;//5
  case 0xbb:d=6;break;//6
  case 0xb7:d=7;break;//7
  case 0xde:d=8;break;//8
  case 0xdd:num1=9;break;//9
  default:return 0xff;break;
void timer() interrupt 1
        time++;
        if(time==20)
        flag=1;
                led=~led;
                time=0;
