查看: 1385|回復: 0
通過I2C通信實現(xiàn)AT024的儲存讀取利用51單片機C語言完成
ID:864860 發(fā)表于 2021-1-25 15:28 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#include<intrins.h>
sbit  duan=P2^6;
sbit  wei=P2^7 ;
sbit  SDA=P2^0;
sbit  SCL=P2^1;
bit   flag;
int   index=0;
uchar s;
uchar code duanS[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar code weiS[]={0xef,0xdf,0xbf};
void delay5us(){
    _nop_();
        _nop_();
    _nop_();
        _nop_();
void i2cStart(){
         SCL=1;
         SDA=0;        //高變低【有效】
         SDA=1;
         delay5us();
         SDA=0;
         delay5us();
         SCL=0;
void i2cEnd(){
         SCL=0;
         SDA=0;
         SCL=1;
         delay5us();
         SDA=1;
         delay5us();
bit i2cAck(){         //我覺得可以用來阻塞或者反復傳操作
        SCL=1;
        delay5us();
        if(SDA) {
        SCL=0;
        return(1);
        else {
        SCL=0;
        return(0);
void i2cSendAck(bit b)
  SCL=0;
  if(b)
                  SDA=1;
                  SDA=0;
  SCL=1;
  delay5us();
  SCL=0;
  SDA=1;
void send(uchar DATA){
         uchar i;
         for(i=0;i<8;i++){
            SCL=0;
     if (DATA & 0x80)
                 SDA=1;
                 SDA=0;
     SCL=1;
         delay5us();
         DATA<<=1;
        SCL=0;
        SDA=1;
void i2cSend(uchar dataddr ,uchar dat){
        i2cStart();
        send(0xA0);
           if(i2cAck())
        flag=1;
        else flag=0;
        send(dataddr);
    if(i2cAck())
        flag=1;
        else flag=0;
    send(dat);
        if(i2cAck())
        flag=1;
        else flag=0;
        i2cEnd();
uchar accpect(){
        uchar i,index1;
           for(i=0;i<8;i++){
           index1<<=1;
           SCL=0;
           SCL=1;
           delay5us();
           if(SDA)
                           index1|=0X01;
        return index1;
uchar i2cAccp(uchar dataddr){
        uchar index1;
    i2cStart();
        send(0xA0);
        if(i2cAck())
        flag=1;
        else flag=0;
        send(dataddr);
    i2cAck();
        i2cStart();
        send(0xA1);
        if(i2cAck())
                flag=1;
                flag=0;
//        for(i=0;i<8;i++){
//           index1<<=1;
//           SCL=0;
//           SCL=1;
//           delay5us();
//           if(SDA)
//                           index1|=0X01;
        index1=accpect();
        i2cSendAck(1);
        i2cEnd();
        return index1;
void initP3(){
                 EA=1;
                 ET1=1;
                 TR1=1;
                 TMOD=0x10;
                 TH1=60927/255;
                 TL1=60927%255;
void display(uchar i){
        P0=weiS[index];
    switch(index) {
         case 0:         wei=1;duan=0;wei=0;duan=1;P0=duanS[i/100];
         break;
         case 1:         wei=1;duan=0;wei=0;duan=1;P0=duanS[i/10%10];
         break;
         case 2:         wei=1;duan=0;wei=0;duan=1;P0=duanS[i%10];
         break;
        index++;
        if(index>=3)
        index=0;
void main(){
          uchar i=1000;
      initP3();
          i2cSend(3,236);
          while(i--);
          s=i2cAccp(3);
          while(1);
void interP3() interrupt 3{
        TH1=60927/255;
    TL1=60927%255;
        display(s);
Powered by 單片機教程網
