查看: 1241|回復(fù): 0
求助單片機(jī)藍(lán)牙觸控?zé)舻某绦騿栴}
我接了一個(gè)燈試了,藍(lán)牙沒用,是不是程序哪里出了問題?
#include <reg52.h>
#include <stdio.h>
#include "lcd1602.h"
//ADC0809
sbit CLK=P3^4;
sbit ST=P3^5;
sbit EOC=P3^6;
sbit OE=P3^7;
sbit RELAY = P3^3;
unsigned int pass = 0;
unsigned int ADCshow;
unsigned char pressure = 50;
unsigned char mode=0;
unsigned char status = 0;
void delay(unsigned int s)
        while(s--);
void DelayMS(unsigned int ms)
         unsigned char i;
        while(ms--)
                 for(i=0;i<120;i++);
void Timer0_INT() interrupt 1
        TH0=(65536-200)/256;
        TL0=(65536-200)%256;
        CLK=~CLK;
void UART_init()    //設(shè)置串行通信 本晶振為11.0592MHZ,其他的就自己算一下應(yīng)該設(shè)置多少
      TMOD = 0x20;
      TH1 = 0xfd;
      TL1 = 0xfd;  //波特率9600
      SM0 = 0;
      SM1 = 1;   // 串口工作方式1 10位異步
      REN = 1;  //串口允許接收
      TR1 = 1;
      EA = 1;
      ES =1 ;  //串口中斷
void main(void)
          RELAY=1;  //關(guān)燈
          UART_init();
      lcd_init(); //初始化1602
                TMOD=0x01; //設(shè)置定時(shí)器0
                TH0=(65536-200)/256; //初值重裝
        EA=1;  //開總中斷
                ET0=1;  //開定時(shí)器中斷
                TR0=1;   //開定時(shí)器0
                        //adc0809讀取數(shù)據(jù)
                                                ST=0;
                                                OE=0;
                                                ST=1;
                                                ST=0;
                                                while(EOC==0);
                                                OE=1;
                                                ADCshow=P1;
                                                OE=0;
     //lcd1602顯示壓力傳感器值
                                        LCD_ShowStr(0,0,"Real:");
                                        LCD_ShowChar(5,0,ADCshow/100+'0');
                                        LCD_ShowChar(6,0,ADCshow%100/10 +'0');
                                  LCD_ShowChar(7,0,ADCshow%10 +'0');
                                if(ADCshow<pressure||pass==0x11)
                                   RELAY=0;  //亮燈
                                {  //否則
                                         RELAY=1; //滅燈
void UART_INTERRUPT() interrupt 4
              pass = SBUF;
              RI = 0;
              SBUF = pass;  )
              while(!TI);
              TI = 0;
