查看: 976|回復: 0
求講解飛思卡爾908jb8匯編代碼的意思
ID:884804 發(fā)表于 2021-2-19 12:00 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本人初學飛思卡爾匯編,下面是一段908jb8匯編代碼,請高手講解一下代碼的思,謝謝!
FLASH:E190                                                 sub_E190:                               ; CODE XREF: sub_E1AB↓P
FLASH:E190        ; __RESET_0+11↓P
FLASH:E190 6E 00 94                                                        mov     #0, byte_94    ;byte_94是一個8位內(nèi)存地址
FLASH:E193 3F 95                                                           clr     byte_95              ;byte_95是一個8位內(nèi)存地址
FLASH:E195 3F 96                                                           clr     byte_96               ; byte_96是一個8位內(nèi)存地址
FLASH:E197 6E 80 38                                                        mov     #$80, UADDR     ; USB Address Register
FLASH:E19A 3F 3B                                                           clr     UCR0            ; USB Control Register 0
FLASH:E19C 3F 3C                                                           clr     UCR1            ; USB Control Register 1
FLASH:E19E 3F 19                                                           clr     UCR2            ; USB Control Register 2
FLASH:E1A0 3F 1B                                                           clr     UCR4            ; USB Control Register 4
FLASH:E1A2 3F 39                                                           clr     UIR0            ; USB Interrupt Register 0
FLASH:E1A4 6E FF 18                                                        mov     #$FF, UIR2      ; USB Interrupt Register 2
FLASH:E1A7 6E 44 1A                                                        mov     #$44, UCR3 ; 'D' ; USB Control Register 3
FLASH:E1AA 81                                                              rts
FLASH:E1AA                                                 ; End of function sub_E190
FLASH:E1AA
FLASH:E1AB
FLASH:E1AB                                                 ; =============== S U B R O U T I N E =======================================
FLASH:E1AB
FLASH:E1AB
FLASH:E1AB                                                 sub_E1AB:                               ; CODE XREF: USB_0+6↓P
FLASH:E1AB CD E1 90                                                        jsr     sub_E190
FLASH:E1AE 6E 03 39                                                        mov     #3, UIR0        ; USB Interrupt Register 0
FLASH:E1B1 6E 40 18                                                        mov     #$40, UIR2 ; '@' ; USB Interrupt Register 2
FLASH:E1B4 6E 10 3B                                                        mov     #$10, UCR0      ; USB Control Register 0
FLASH:E1B7 6E 80 38                                                        mov     #$80, UADDR     ; USB Address Register
FLASH:E1BA 6E 01 94                                                        mov     #1, byte_94
FLASH:E1BD 81                                                              rts
FLASH:E1BD                                                 ; End of function sub_E1AB
FLASH:E1BD
FLASH:E1BE
FLASH:E1BE                                                 ; =============== S U B R O U T I N E =======================================
FLASH:E1BE
FLASH:E1BE
FLASH:E1BE                                                 sub_E1BE:                                  ; CODE XREF: __RESET_0+B↓P
FLASH:E1BE 6E 20 1D                                                        mov     #$20, POCR    ; ' ' ; Port Option Control Register
FLASH:E1C1 3F 00                                                           clr     PTA                 ; Port A Data Register
FLASH:E1C3 6E 00 04                                                        mov     #0, DDRA        ; Data Direction Register A
FLASH:E1C6 3F 02                                                           clr     PTC               ; Port C Data Register
FLASH:E1C8 3F 08                                                           clr     PTE                ; Port E Data Register
FLASH:E1CA A6 FF                                                           lda     #$FF
FLASH:E1CC B7 06                                                           sta     DDRC            ; Data Direction Register C
FLASH:E1CE B7 09                                                           sta     DDRE            ; Data Direction Register E
FLASH:E1D0 6E FC 03                                                        mov     #$FC, PTD       ; Port D Data Register
FLASH:E1D3 6E FF 07                                                        mov     #$FF, DDRD      ; Data Direction Register D
FLASH:E1D6 6E 88 9B                                                        mov     #$88, byte_9B
FLASH:E1D9 81                                                              rts
FLASH:E1D9                                                 ; End of function sub_E1BE
FLASH:E1D9
