100黑幣
自己寫了一個四輪的小車,主控是stm32f103rct6
目前的問題是,不論怎么設(shè)置初值,車輪總是全速轉(zhuǎn)動,并且拔掉編碼器的線,車輪轉(zhuǎn)速依舊沒啥變化,不知道是哪里除了問題
單片機源程序如下:
- #include "sys.h"
- #include "delay.h"
- #include "encoder.h"
- #include "timer.h"
- #include "pwm.h"
- #include "pid.h"
- #include "motor.h"
- #include <stdio.h>
- #include "usart.h"
- int FleftSpeedNow =0;
- int FrightSpeedNow =0;
- int BleftSpeedNow =0;
- int BrightSpeedNow =0;
- int FleftSpeeSet =400;//mm/s
- int FrightSpeedSet = 2000;//mm/s
- int BleftSpeeSet = 600;//mm/s
- int BrightSpeedSet = 600;//mm/s
- int main(void)
- GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable,ENABLE);
- GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//禁用JTAG 啟用 SWD
- MY_NVIC_PriorityGroupConfig(2); //=====設(shè)置中斷分組
- delay_init(); //=====延時函數(shù)初始化
- Motor_Init(); //電機初始化
- Encoder_Init_TIM2(); //=====初始化編碼器
- Encoder_Init_TIM1();
- Encoder_Init_TIM3();
- Encoder_Init_TIM4(); //=====初始化編碼器
- PWM_Init(7199,0); //=====初始化PWM
- TIM5_Int_Init(50-1,7200-1); //=====定時器初始化 5ms一次中斷
- PID_Init(); //=====PID參數(shù)初始化
- uart_init(9600);
- FrontmotorLeft=400;
- //閉環(huán)速度控制
- while(1)
- //給速度設(shè)定值,想修改速度,就更該leftSpeeSet、rightSpeedSet變量的值
- Fpid_Task_Letf.speedSet = FleftSpeeSet;
- Fpid_Task_Right.speedSet = FrightSpeedSet;
- Bpid_Task_Letf.speedSet = BleftSpeeSet;
- Bpid_Task_Right.speedSet = BrightSpeedSet;
- //給定速度實時值
- Fpid_Task_Letf.speedNow = FleftSpeedNow;
- Fpid_Task_Right.speedNow = FrightSpeedNow;
- Bpid_Task_Letf.speedNow = BleftSpeedNow;
- Bpid_Task_Right.speedNow = BrightSpeedNow;
- //執(zhí)行PID控制函數(shù)
- Pid_Ctrl(&FrontmotorLeft ,&FrontmotorRight,&BackmotorLeft ,&BackmotorRight);
- //根據(jù)PID計算的PWM數(shù)據(jù)進(jìn)行設(shè)置PWM
- Set_Pwm_Front(FrontmotorLeft,FrontmotorRight);
- Set_Pwm_Back(BackmotorLeft,BackmotorRight);
- delay_ms(10);
- //5ms 定時器中斷服務(wù)函數(shù) --> 計算速度實時值,運行該程序之前,確保自己已經(jīng)能獲得輪速,如果不懂,可看之前電機測速的文章
- void TIM5_IRQHandler(void) //TIM7中斷
- if(TIM_GetITStatus(TIM5, TIM_IT_Update) != RESET) //檢查指定的TIM中斷發(fā)生與否
- TIM_ClearITPendingBit(TIM5, TIM_IT_Update); //清除TIMx的中斷待處理位
- Get_Motor_Speed(&FleftSpeedNow ,&FrightSpeedNow,&BleftSpeedNow,&BrightSpeedNow);//計算電機速度
- #include "sys.h"
- #include "pwm.h"
- #include "pid.h"
- int main(void)
- uart_init(9600);
- //閉環(huán)速度控制
- while(1)
- //給定速度實時值
- delay_ms(10);
PID - 全車.7z
2021-2-21 15:22 上傳
點擊文件名下載附件
194.4 KB, 下載次數(shù): 19
