查看: 2462|回復(fù): 0
51單片機(jī)第五課數(shù)碼管修改消除計(jì)數(shù)過程中快閃
ID:885163 發(fā)表于 2021-2-21 09:58 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
/********************51單片機(jī)第五課*******************/
/********************數(shù)碼管計(jì)數(shù)器*******************/
/******************** 運(yùn)用中斷控制 *******************/
/********************By Max.Zhang  *******************/
#include <reg52.h>
typedef unsigned char uint8;             //定義參數(shù)類型,規(guī)范書寫格式
typedef unsigned int  uint16;
typedef unsigned long uint32;
uint16 i;
uint8  cnt;
uint8  num;
uint32 a;
uint8  n;
/******** 38譯碼器引腳對(duì)應(yīng)P1位置*********/
sbit ADDR0  =P1^0;
sbit ADDR1  =P1^1;
sbit ADDR2  =P1^2;
sbit ADDR3  =P1^3;
sbit ENLED  =P1^4;
/********     數(shù)碼管真值表     *********/
uint8 code DS[16]={            //code 表示把數(shù)據(jù)存到flash,不占用內(nèi)部存儲(chǔ)
    0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
    0x80, 0x90};
uint8 buff[6]={
        0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
/************** 38譯碼器設(shè)置*************/
        ADDR3 =1;
        ENLED =0;
/************** 中斷初始化 *************/
        TMOD = 01;
        TH0         =0xFC;              //計(jì)算1ms的計(jì)數(shù)初值
        TL0  =0x66;
        TR0  =1;
        EA  =1;
        ET0 =1;
        while(1);
void timer0_interrupt() interrupt 1
        static i=0;
        static a=0;
        static cnt=0;
        TL0  =0x66;
        TF0  =0;
        cnt++;
                        P0=0xFF;
                switch(i)         //放到中斷里面 1ms刷新一次數(shù)碼管段選
                        case 0:ADDR2=0;ADDR1=0;ADDR0=0;i++;P0=DS[buff[0]];break;
                        case 1:ADDR2=0;ADDR1=0;ADDR0=1;i++;P0=DS[buff[1]];break;
                        case 2:ADDR2=0;ADDR1=1;ADDR0=0;i++;P0=DS[buff[2]];break;
                        case 3:ADDR2=0;ADDR1=1;ADDR0=1;i++;P0=DS[buff[3]];break;
                        case 4:ADDR2=1;ADDR1=0;ADDR0=0;i++;P0=DS[buff[4]];break;
                        case 5:ADDR2=1;ADDR1=0;ADDR0=1;i=0;P0=DS[buff[5]];break;
                default:break;
         if(cnt>=1000)               //計(jì)數(shù)1000次,延時(shí)1s
                        cnt=0;
                        a++;
    buff[0]=a%10;
                buff[1]=a/10%10;
                buff[2]=a/100%10;
                buff[3]=a/1000%10;
                buff[4]=a/10000%10;
                buff[5]=a/100000%10;
