#pragma src(E:\remote.asm)
#include "reg51.h"
#include "intrins.h"
#define disout P2
sbit dula=P3^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
sbit remotein=P3^1;
sbit sin=P3^0;
sbit K1=P0^0;
sbit K2=P0^1;
sbit K3=P0^2;
sbit K4=P0^3;
sbit K5=P0^4;
sbit K6=P0^5;
sbit K7=P0^6;
sbit K8=P0^7;
uint i,j,m,n,k,s=1;
uint keyvol; //值存放
/*********1 毫秒延時(shí)程序**********/
delay1ms(uint t)
for(i=0;i<t;i++)
for(j=0;j<120;j++);
/***********初始化函數(shù)**********/
clearmen()
dula=0;
EX0=1;
EA=1; //開總中斷
/**********函數(shù)************/
loop()
switch(disout&0x07)
case 0:{s=1;break;}
case 1:{s=2;break;}
case 2:{s=3;break;}
case 3:{s=4;break;}
case 4:{s=5;break;}
case 5:{s=6;break;}
case 6:{s=7;break;}
case 7:{s=8;break;}
default:break;}
xianshi()
dula=1;
P1=table[keyvol-2] ;
dula=0;
/***********主函數(shù)***************/
main()
clearmen(); //初始化
loop();
while(sin==1);
delay1ms(s);
K8=0;
delay1ms(1);
K8=1;
/************外中斷遙控接收函數(shù)**************/
void intt0(void) interrupt 0
EX0=0;keyvol=0;
if(remotein==0)
{delay1ms(1);
if(remotein==0)
{while(1)
{while(remotein==0);
keyvol++;k=0;
while(remotein==1){delay1ms(1);k++;if(k>2){ xianshi();goto OOUUTT; xianshi();};}
OOUUTT:
switch(keyvol)
case 2:{K1=~K1;break;}
case 3:{K2=~K2;break;}
case 4:{K3=~K3;break;}
case 5:{K4=~K4;break;}
case 6:{K5=~K5;break;}
case 7:{K6=~K6;break;}
case 8:{K7=~K7;break;}
case 9:{if(disout==0x00){disout=0xff;}else{disout--;}loop();break;}
default:break;
EX0=1;
