查看: 3671|回復(fù): 2
STM32F103C8T6-I2C-1602A程序
ID:296201 發(fā)表于 2021-3-6 09:30 | 顯示全部樓層 |閱讀模式
使用STM32F103C8T6單片機(jī)驅(qū)動(dòng)I2C-1602A模塊
  1. #include <stm32f10x.h>
  2. #include "delay.h"
  3. #include "IIC_1602.h"
  4. extern unsigned char LCD_data;
  5. /**
  6.   * @brief  I2C_Configuration,初始化硬件IIC引腳
  7.   * @param  無
  8.   * @retval 無
  9.   */
  10. void I2C_Configuration(void)
  11. {
  12.         I2C_InitTypeDef  I2C_InitStructure;
  13.         GPIO_InitTypeDef  GPIO_InitStructure;
  14.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE);
  15.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
  16.         /*STM32F103C8T6芯片的硬件I2C: PB6 -- SCL; PB7 -- SDA */
  17.         GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7;
  18.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  19.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;//I2C必須開漏輸出
  20.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  21.         I2C_DeInit(I2C1);//使用I2C1
  22.         I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
  23.         I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
  24.         I2C_InitStructure.I2C_OwnAddress1 = 0x30;//主機(jī)的I2C地址,隨便寫的
  25.         I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
  26.         I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
  27.         I2C_InitStructure.I2C_ClockSpeed = 400000;//400K
  28.         I2C_Cmd(I2C1, ENABLE);
  29.         I2C_Init(I2C1, &I2C_InitStructure);
  30. }
  31. /**
  32.   * @brief  I2C_WriteByte,向OLED寄存器地址寫一個(gè)byte的數(shù)據(jù)
  33.   * @param  addr:寄存器地址
  34.         *                                        data:要寫入的數(shù)據(jù)
  35.   * @retval 無
  36.   */
  37. void I2C_WriteByte(unsigned char data)
  38. {
  39.   while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY));
  40.
  41.         I2C_GenerateSTART(I2C1, ENABLE);//開啟I2C1
  42.         while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));/*EV5,主模式*/
  43.         I2C_Send7bitAddress(I2C1, LCD_ADDR, I2C_Direction_Transmitter);//器件地址 --
  44.         while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
  45. //        I2C_SendData(I2C1, addr);//寄存器地址
  46. //        while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
  47.         I2C_SendData(I2C1, data);//發(fā)送數(shù)據(jù)
  48.         while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
  49.
  50.         I2C_GenerateSTOP(I2C1, ENABLE);//關(guān)閉I2C1總線
  51. }
  52. void LCD_EN()
  53. {
  54.
  55.         LCD_data |= 1<<2;
  56.         I2C_WriteByte(LCD_data);//1 讀取數(shù)據(jù)
  57.         DelayUs(25);//延時(shí)
  58.         LCD_data ^= 1<<2;
  59.         I2C_WriteByte(LCD_data);//1→0 執(zhí)行指令
  60.
  61. }
  62. void LCD_WriteCMD(unsigned char cmd)
  63. {
  64.
  65.         DelayUs(25);
  66.         LCD_data &=~(1<<(1-1));//RS=0;
  67.         LCD_data &=~(1<<(2-1));//RW=0;
  68.         I2C_WriteByte(LCD_data);
  69.         LCD_data &= 0X0f; //清高四位
  70.         LCD_data |= cmd & 0xf0; //寫指令高四位
  71.         I2C_WriteByte(LCD_data);
  72.         LCD_EN();
  73.         cmd = cmd<<4;
  74.         LCD_data &= 0X0f; //清高四位
  75.         LCD_data |= cmd & 0xf0; //寫指令低四位
  76.         I2C_WriteByte(LCD_data);
  77.         LCD_EN();
  78. }
  79. void LCD_WriteDAT(unsigned char dat)
  80. {
  81.
  82.         DelayUs(25);
  83.         LCD_data |= (1<<(1-1));//RS=0;
  84.         LCD_data &=~(1<<(2-1));//RW=0;
  85.         I2C_WriteByte(LCD_data);
  86.         LCD_data &= 0X0f; //清高四位
  87.         LCD_data |= dat & 0xf0; //寫數(shù)據(jù)高四位
  88.         I2C_WriteByte(LCD_data);
  89.         LCD_EN();
  90.         dat = dat<<4;
  91.         LCD_data &= 0X0f; //清高四位
  92.         LCD_data |= dat & 0xf0; //寫數(shù)據(jù)低四位
  93.         I2C_WriteByte(LCD_data);
  94.         LCD_EN();
  95. }
  96. void Set_Position(unsigned char x,unsigned char y)
  97. {
  98.
  99.         unsigned char x_pos;
  100.         x_pos = x%0x10;
  101.         if(y==0)
  102.         {
  103.                 LCD_WriteCMD(0x80+x_pos);
  104.         }
  105.         else
  106.         {
  107.                 LCD_WriteCMD(0xc0+x_pos);
  108.         }
  109.
  110. }
  111. void LCD_ShowStr(unsigned char x,unsigned char y,unsigned char * str)
  112. {
  113.         Set_Position(x,y);
  114.         while(*str)
  115.         {
  116.
  117.                 LCD_WriteDAT(*str);
  118.                 str++;
  119.         }
  120.
  121. }
  122. void LCD_Init()
  123. {
  124.         LCD_WriteCMD(0x28);//4線操作模式
  125.         LCD_WriteCMD(0x0c);//
  126.         LCD_WriteCMD(0x80);
  127.         LCD_WriteCMD(0x01);
  128.         DelayMs(5);
  129. }
  130. void LCD_DispConf(unsigned char DispON,unsigned char CursorON,unsigned char GlareON)
  131. {
  132.         unsigned char x = 0x08;
  133.         if(DispON!=0)
  134.         {
  135.                 x = x|(DispON<<2);
  136.         }
  137.         if(CursorON!=0)
  138.         {
  139.                 x = x|(CursorON<<1);
  140.         }
  141.         if(GlareON!=0)
  142.         {
  143.                 x = x|GlareON;
  144.         }
  145.         LCD_WriteCMD(x);
  146. }
所有程序51hei提供下載:
IIC_1602A.7z (21.31 KB, 下載次數(shù): 106)
ID:208271 發(fā)表于 2022-2-9 17:32 | 顯示全部樓層
用STM32F103C6T6測(cè)試過,可以顯示,但液晶背光不受控制,背光會(huì)一直關(guān)閉。
