#include <REGX52.H>
#include "onewire.h"
sbit L1 = P0^0;
sbit L2 = P0^1;
sbit L3 = P0^2;
sbit key7 = P3^0;
sbit key6 = P3^1;
sbit key5 = P3^2;
sbit key4 = P3^3;
uint code Shu[] =
{0xc0,0xf9,0xa4,0xb0,
0x99,0x92,0x82,0xf8,
0x80,0x90,
0xbf,0xff, 0xc6};
void Delay(uint t);
void Init_hc573(uint sel);
void Init_set(void);
void DisplaySMG_Dat(uint pos, uint dat);
void DisplaySMG_all(void);
void DisplaySMG(void);
void keyscan(void);
void Init_Timer0(void);
uint yi = 11, er = 11, san = 11, si = 11, wu = 11, liu = 11, qi = 11,ba = 11;
uint display;
uint work;
uint motor;
uint sec = 50;
uint flag_5;
uint flag_7;
uint stop;
uint temperature;
uint count;
uint time;
Init_Timer0();
Init_set();
if(display == 0)
if(work == 0)
if(sec > 0)
Init_hc573(4);
P0 = 0xff;
L1 = 0;
Init_hc573(4);
P0 = 0xff;
yi = 10;er = work+1;san = 10;
si = 11;
wu = sec/1000;liu = sec%1000/100;
qi = sec%100/10;ba = sec&10;
else if(work == 1)
if(sec > 0)
Init_hc573(4);
P0 = 0xff;
L2 = 0;
Init_hc573(4);
P0 = 0xff;
si = 11;
else if(work == 2)
if(sec > 0)
Init_hc573(4);
P0 = 0xff;
L3 = 0;
Init_hc573(4);
P0 = 0xff;
si = 11;
temperature = read_temperature();
yi = 10;er = 4;san = 10;
si = 11;wu = 11;
liu = temperature/10;qi = temperature%10;ba = 12;
if(sec > 0)
EA = 1;
ET0 = 1;
EA = 0;
ET0 = 0;
Init_hc573(4);
P0 = 0xff;
motor = 0;
count = 0;
keyscan();
DisplaySMG();
void Delay(uint t)
while(t --);
switch(sel)
case 4:P2 = (P2 &0x1f)|0x80;break;
case 5:P2 = (P2 &0x1f)|0xa0;break;
case 6:P2 = (P2 &0x1f)|0xc0;break;
case 7:P2 = (P2 &0x1f)|0xe0;break;
void Init_set(void)
Init_hc573(4);
P0 = 0xff;
Init_hc573(5);
P0 = 0x00;
Init_hc573(6);
P0 = 0x01 << pos;
Init_hc573(7);
P0 = dat;
Delay(100);
P0 = 0xff;
Init_hc573(6);
P0 = 0xff;
Init_hc573(7);
P0 = 0xff;
DisplaySMG_Dat(0, Shu[yi]);
Delay(100);
DisplaySMG_Dat(1, Shu[er]);
Delay(100);
DisplaySMG_Dat(2, Shu[san]);
Delay(100);
DisplaySMG_Dat(3, Shu[si]);
Delay(100);
DisplaySMG_Dat(4, Shu[wu]);
Delay(100);
DisplaySMG_Dat(5, Shu[liu]);
Delay(100);
DisplaySMG_Dat(6, Shu[qi]);
Delay(100);
DisplaySMG_Dat(7, Shu[ba]);
Delay(100);
DisplaySMG_all();
void keyscan(void)
if(!key4)
Delay(200);
if(!key4)
if(!display)
work ++;
if(work == 3)
work = 0;
while(!key4);
if(!key5)
Delay(200);
if(!key5)
if(!display)
sec += 60;
flag_5 ++;
if(flag_5 == 2)
sec = 0;
while(!key5);
if(!key6)
Delay(200);
if(!key6)
if(!display)
Init_hc573(4);
P0 = 0xff;
sec = 0;
while(!key6);
if(!key7)
Delay(200);
if(!key7)
display = 1;
flag_7 ++;
if(flag_7 == 2)
flag_7 = 0;
display = 0;
while(!key7);
TMOD = 0x01;
TL0 = (65535-10)/256;
TH0 = (65535-10)%256;
// EA =
// ET0 =
TR0 = 1;
void Service_Timer0(void) interrupt 1
count ++;
if(work == 0)
if(count < 20)
motor = 1;
motor = 0;
count = 0;
else if(work == 1)
if(count < 30)
motor = 1;
motor = 0;
count = 0;
else if(work == 2)
if(count < 70)
motor = 1;
motor = 0;
count = 0;
time ++;
if(time == 100000 )
sec --;
time = 0;
