#include "sys.h"
#include "delay.h"
#include "usart.h"
#include "led.h"
#include "pwm.h"
int main(void)
u16 led0pwmval=0;
u8 dir=1;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級分組2
delay_init(168); //初始化延時函數(shù)
uart_init(115200);//初始化串口波特率為115200
//pwm_int_TIM2(9999,143); //======初始化pwm輸出 72000 000 /7199+1=10000
//TIM3_PWM_Init(9999,143); //84M/84=1Mhz的計數(shù)頻率,重裝載值500,所以PWM頻率為 1M/500=2Khz.
pwm_int_TIM1(7199); //84M/84=1Mhz的計數(shù)頻率,重裝載值500,所以PWM頻率為 1M/500=2Khz.
// pwm_int_TIM3(7199,0);
while(1) //實現(xiàn)比較值從0-300遞增,到300后從300-0遞減,循環(huán)
delay_ms(10);
//if(dir)led0pwmval++;//dir==1 led0pwmval遞增
//else led0pwmval--; //dir==0 led0pwmval遞減
//if(led0pwmval>300)dir=0;//led0pwmval到達(dá)300后,方向為遞減
//if(led0pwmval==0)dir=1; //led0pwmval遞減到0后,方向改為遞增
TIM_SetCompare1(TIM3,710); //修改比較值,修改占空比
TIM_SetCompare1(TIM2,710); //設(shè)置TIM2通道2的占空比 pwm1/7200 PA1
TIM_SetCompare2(TIM2,710); //設(shè)置TIM2通道2的占空比 pwm1/7200 PA1
TIM_SetCompare3(TIM2,710); //設(shè)置TIM2通道2的占空比 pwm1/7200 PA1
TIM_SetCompare4(TIM2,710); //設(shè)置TIM2通道2的占空比 pwm1/7200 PA1
TIM_SetCompare1(TIM3,2220);
TIM_SetCompare2(TIM3,2220);
TIM_SetCompare3(TIM3,2220);
TIM_SetCompare4(TIM3,2220);
TIM_SetCompare1(TIM1,710); //設(shè)置TIM2通道2的占空比 pwm1/7200 PA1
TIM_SetCompare2(TIM1,710); //設(shè)置TIM2通道2的占空比 pwm1/7200 PA1
TIM_SetCompare3(TIM1,710); //設(shè)置TIM2通道2的占空比 pwm1/7200 PA1
TIM_SetCompare4(TIM1,710); //設(shè)置TIM2通道2的占空比 pwm1/7200 PA1
//delay_ms(1000);
//TIM_SetCompare1(TIM2,0); //設(shè)置TIM2通道2的占空比 pwm1/7200 PA1
/*TIM_SetCompare1(TIM3,40); //修改比較值,修改占空比
delay_ms(10);
TIM_SetCompare1(TIM3,0); //修改比較值,修改占空比
