查看: 2143|回復: 5
新手求助,請高手看看單片機程序問題出在哪里?
ID:217075 發(fā)表于 2021-3-18 10:41 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
單片機STC15W202S
sout,xout分別控制2路可控硅,實現(xiàn)加熱爐的強弱檔控制,強檔可控硅始終導通,弱檔可控硅斷續(xù)導通,定時器T0確定弱檔時的周期t0,T2確定占空比t1/t0,每路兩個按鈕,開關(guān)和強弱選擇
#include<reg52.h>
sbit sqr=P1^3; //輸出強弱選擇按鍵1
sbit skg=P1^2; //輸出開關(guān)鍵1,打開進入強輸出狀態(tài)
sbit xqr=P1^5; //輸出強弱選擇按鍵2
sbit xkg=P1^4; //輸出開關(guān)鍵2,同1
sbit sout=P1^1;        //輸出1
sbit xout=P3^0;        //輸出2
sbit sq=P3^7;  //輸出1強發(fā)光二極管顯示
sbit sr=P3^6;  //輸出1弱發(fā)光二極管顯示
sbit xq=P3^1;  //輸出2強發(fā)光二極管顯示
sbit xr=P3^2;  //輸出2弱發(fā)光二極管顯示
uchar t0=20;
uchar t1=10;
uchar num1;
uchar num2;
uchar led1;
uchar led2;
uchar scan;
uchar xcan;
void delayms(uint xms)
        uint i,j;
        for(i=xms;i>0;i--)
                for(j=110;j>0;j--);
void ledcan()
         if((skg==0)&&(scan==1))
                delayms(10);
                    TR0=0;
                        AUXR&=0x00;
                        while(!skg);
                        TR0=1;
                        AUXR|=0x10;
                        scan=0;
                        sout=0;
                        sq=0;
                        sr=1;
                delayms(10);
        if((skg==0)&&(scan==0))
                delayms(10);
                    TR0=0;
                        AUXR&=0x00;
                        while(!skg);
                        TR0=1;
                        AUXR|=0x10;
                        scan=1;
                        sout=1;
                        sq=1;
                        sr=1;
                delayms(10);
        if((xkg==0)&&(xcan==1))
                delayms(10);
                    TR0=0;
                        AUXR&=0x00;
                        while(!xkg);
                        TR0=1;
                        AUXR|=0x10;
                        xcan=0;
                        xout=0;
                        xq=0;
                        xr=1;
                delayms(10);
        if((xkg==0)&&(xcan==0))
                delayms(10);
                    TR0=0;
                        AUXR&=0x00;
                        while(!xkg);
                        TR0=1;
                        AUXR|=0x10;
                        xcan=1;
                        xout=1;
                        xq=1;
                        xr=1;
                delayms(10);
        if((sqr==0)&&(scan==0)&&(sq==0))
                delayms(10);
                    TR0=0;
                        AUXR&=0x00;
                        while(!sqr);
                        TR0=1;
                        AUXR|=0x10;
                        sout=led2;
                        sq=1;
                        sr=0;
                delayms(10);
        if(sr==0)
         sout=led2;
        if((sqr==0)&&(scan==0)&&(sr==0))
                delayms(10);
                    TR0=0;
                        AUXR&=0x00;
                        while(!sqr);
                        TR0=1;
                        AUXR|=0x10;
                        sout=0;
                        sq=0;
                        sr=1;
                delayms(10);
        if((xqr==0)&&(xcan==0)&&(xq==0))
                delayms(10);
            TR0=0;
                        AUXR&=0x00;
                        while(!xqr);
                        TR0=1;
                        AUXR|=0x10;
                        xout=led2;
                        xq=1;
                        xr=0;
                delayms(10);
        if(xr==0)
         xout=led2;
        if((xqr==0)&&(xcan==0)&&(xr==0))
                delayms(10);
            TR0=0;
                        AUXR&=0x00;
                        while(!xqr);
                        TR0=1;
                        AUXR|=0x10;
                        xout=0;
                        xq=0;
                        xr=1;
                delayms(10);
        sqr=1;
        skg=1;
        xqr=1;
        xkg=1;
        sout=1;
        xout=1;
        sq=1;
        sr=1;
        xq=1;
        xr=1;
        num1=0;
        num2=0;
        led1=0;
        led2=0;
        scan=1;
        xcan=1;
        TMOD=0x11;
        TH0=(65535-45872)/256;
        TL0=(65535-45872)%256;
        T2H=(65535-45872)/256;
        T2L=(65535-45872)%256;
        EA=1;
        ET0=1;
        TR0=1;
    IE2|=0x04;
        AUXR|=0x10;
            ledcan();
void T0time() interrupt 1
        TH0=(65535-45872)/256; //50ms初值
        num1++;
                if(num1==t0)
                        TR0=0;
                        AUXR&=0x00;
                    led1=1;
                    delayms(5);
                        TR0=1;
                        AUXR|=0x10;
                    led1=0;
                    num1=0;
void T2time() interrupt 12
        num2++;
                if(num2==t1)
                    AUXR&=0x00;
                    led2=1;
                if(led1==1)
                    AUXR|=0x10;
                        num2=0;
                        led2=0;
ID:235200 發(fā)表于 2021-3-18 13:42 | 只看該作者
程序那么長,你要描述你的問題吧!
ID:213173 發(fā)表于 2021-3-18 15:36 | 只看該作者
程序沒有細看,不知道你想達到什么目的,也不知道你遇到什么問題。有2點明顯錯誤。
1.只為了相同的定時時間干嘛要開兩個定時器?只要設(shè)置標志,1個定時器可以完成N個定時時間。
2.這個延時函數(shù)void delayms(uint xms)只適合12T單片機,11.0592MHz 1T環(huán)境要改為:
        uint i,j;
        for(i=xms;i>0;i--)
                for(j=829;j>0;j--);
ID:217075 發(fā)表于 2021-3-18 16:05 | 只看該作者
ID:213173 發(fā)表于 2021-3-18 22:02 | 只看該作者
hsujinshan 發(fā)表于 2021-3-18 16:05
sout,xout分別控制2路可控硅,實現(xiàn)加熱爐的強弱檔控制,強檔可控硅始終導通,弱檔可控硅斷續(xù)導通,定時器T0 ...
這種簡單控制不用寫得那么啰嗦。定時器也不必非得50ms,用最大值約71ms不影響占空比,用鍵控制占空比可以由全開到關(guān)斷,如不用數(shù)碼管顯示占空比就用LED閃亮時間觀察占空比。修改如下:
  1. #include<reg52.h>
  2. #define uint unsigned int
  4. sfr AUXR = 0x8E; //STC15W特殊寄存器定義
  5. //sbit sqr=P1^3; //輸出強弱選擇按鍵1
  6. //sbit skg=P1^2; //輸出開關(guān)鍵1,打開進入強輸出狀態(tài)
  7. //sbit xqr=P1^5; //輸出強弱選擇按鍵2
  8. //sbit xkg=P1^4; //輸出開關(guān)鍵2,同1
  9. sbit sout=P1^1;        //輸出1
  10. sbit xout=P3^0;        //輸出2
  11. sbit sled=P3^7;  //輸出1強/弱發(fā)光二極管顯示
  12. //sbit sr=P3^6;  //輸出1弱發(fā)光二極管顯示
  13. sbit xled=P3^1;  //輸出2強/弱發(fā)光二極管顯示
  14. //sbit xr=P3^2;  //輸出2弱發(fā)光二極管顯示
  15. uchar num;        //鍵值變量
  16. uchar num1; //中斷計數(shù)1變量
  17. uchar num2; //中斷計數(shù)2變量
  18. uchar scan; //占空比1變量
  19. uchar xcan; //占空比2變量
  20. void delayms(uint xms)//@11.0592MHz/1T
  21. {
  22.         uint i,j;
  23.         for(i=xms;i>0;i--)
  24.                 for(j=829;j>0;j--);
  25. }
  26. void keyscan()
  27. {
  28.         static uchar count=0;//靜態(tài)計數(shù)變量
  29.         static bit sign=0;        //靜態(tài)標志位
  30.         num=(P1&0x3c)>>2;                //按鍵P1.2~1.5
  31.         if(num!=0x0f)        //有鍵按下
  32.         {
  33.                 if(++count>=10 && sign==0)//10ms消抖
  34.                 {
  35.                         sign=1;                //記憶鍵態(tài)
  36.                         switch(num)
  37.                         {
  38.                                 case 0x0e: if(scan<10)scan++; break;//輸出1占空比+
  39.                                 case 0x0d: if(scan>0)scan--; break;//輸出1占空比-
  40.                                 case 0x0b: if(xcan<10)xcan++; break;//輸出2占空比+
  41.                                 case 0x07: if(xcan>0)xcan--; break;//輸出2占空比-
  42.                                 default: break;
  43.                         }
  44.                 }
  45.         }
  46.         else  //松手
  47.         {
  48.                 count=0;//計數(shù)清0
  49.                 sign=0; //
  50.         }
  51. }
  52. void main()
  53. {
  54.         AUXR &= 0x7F;                //定時器時鐘12T模式
  55.         TMOD &= 0xF0;                //設(shè)置定時器模式
  56.         TMOD |= 0x01;                //設(shè)置定時器模式
  57.         TH0=0x00;//(65535-45872)/256;
  58.         TL0=0x00;//(65535-45872)%256;
  59.         EA=1;
  60.         ET0=1;
  61.         TR0=1;
  62.         while(1)
  63.         {
  64.                 keyscan(); //按鍵掃描
  65.                 delayms(1);//控制主循環(huán)周期約1ms
  66.         }
  67. }
  68. void T0time() interrupt 1
  69. {
  70. //        初值0x0000 71~72ms
  71. //        TH0=(65535-45872)/256; //50ms初值
  72. //        TL0=(65535-45872)%256;
  73.         if(num1<scan){sout=0;sled=0;}
  74.         else {sout=1;sled=1;}
  75.         num1=++num1%10;
  76.         if(num2<xcan){xout=0;xled=0;}
  77.         else {xout=1;xled=1;}
  78.         num2=++num2%10;
  79. }
復制代碼
參與人數(shù) 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎勵!
ID:217075 發(fā)表于 2021-3-19 08:19 | 只看該作者
多謝這位老師
