好東東,大家注意PCB只能用Protel99才能打開,其他版本均不行.樓主的單片機(jī)程序:- #include <reg52.h> //定義頭文件
- #include <intrins.h>
- #define uchar unsigned char //宏定義
- #define uint unsigned int //宏定義
- #define D P2 //段選用D代替
- sbit s1=P3^0;//定義加按鍵
- sbit s2=P3^1;//定義減按鍵
- sbit q1=P0^2;//定義蜂鳴器
- sbit s3=P1^0;//定義點(diǎn)焊開始
- sbit m=P0^0;//定義點(diǎn)焊脈沖輸出
- uchar a; //設(shè)置全局變量
- #define RdCommand 0x01 //定義ISP的操作命令
- #define PrgCommand 0x02
- #define EraseCommand 0x03
- #define Error 1
- #define Ok 0
- #define WaitTime 0x01 //定義CPU的等待時(shí)間
- sfr ISP_DATA=0xe2; //寄存器申明
- sfr ISP_ADDRH=0xe3;
- sfr ISP_ADDRL=0xe4;
- sfr ISP_CMD=0xe5;
- sfr ISP_TRIG=0xe6;
- sfr ISP_CONTR=0xe7;
- uchar code d[]={0x88,0xEE,0x94,0xC4,0xE2,0xC1,0x81,0xEC,0x80,0xC0}; //不帶小數(shù)點(diǎn)
- void DelayMs(unsigned int t); //ms級(jí)延時(shí)
- void anjian( ); //按鍵函數(shù)
- void mchshch( ); //脈沖輸出函數(shù)
- /* ================ 打開 ISP,IAP 功能 ================= */
- void ISP_IAP_enable(void)
- EA = 0; /* 關(guān)中斷 */
- ISP_CONTR = ISP_CONTR & 0x18; /* 0001,1000 */
- ISP_CONTR = ISP_CONTR | WaitTime; /* 寫入硬件延時(shí) */
- ISP_CONTR = ISP_CONTR | 0x80; /* ISPEN=1 */
- /* =============== 關(guān)閉 ISP,IAP 功能 ================== */
- void ISP_IAP_disable(void)
- ISP_CONTR = ISP_CONTR & 0x7f; /* ISPEN = 0 */
- ISP_TRIG = 0x00;
- EA = 1; /* 開中斷 */
- /* ================ 公用的觸發(fā)代碼 ==================== */
- void ISPgoon(void)
- ISP_IAP_enable(); /* 打開 ISP,IAP 功能 */
- ISP_TRIG = 0x46; /* 觸發(fā)ISP_IAP命令字節(jié)1 */
- ISP_TRIG = 0xb9; /* 觸發(fā)ISP_IAP命令字節(jié)2 */
- _nop_();
- /* ==================== 字節(jié)讀 ======================== */
- unsigned char byte_read(unsigned int byte_addr)
- ISP_ADDRH = (unsigned char)(byte_addr >> 8);/* 地址賦值 */
- ISP_ADDRL = (unsigned char)(byte_addr & 0x00ff);
- ISP_CMD = ISP_CMD & 0xf8; /* 清除低3位 */
- ISP_CMD = ISP_CMD | RdCommand; /* 寫入讀命令 */
- ISPgoon(); /* 觸發(fā)執(zhí)行 */
- ISP_IAP_disable(); /* 關(guān)閉ISP,IAP功能 */
- return (ISP_DATA); /* 返回讀到的數(shù)據(jù) */
- /* ================== 扇區(qū)擦除 ======================== */
- void SectorErase(unsigned int sector_addr)
- unsigned int iSectorAddr;
- iSectorAddr = (sector_addr & 0xfe00); /* 取扇區(qū)地址 */
- ISP_ADDRH = (unsigned char)(iSectorAddr >> 8);
- ISP_ADDRL = 0x00;
- ISP_CMD = ISP_CMD & 0xf8; /* 清空低3位 */
- ISP_CMD = ISP_CMD | EraseCommand; /* 擦除命令3 */
- /* ==================== 字節(jié)寫 ======================== */
- void byte_write(unsigned int byte_addr, unsigned char original_data)
- ISP_ADDRH = (unsigned char)(byte_addr >> 8); /* 取地址 */
- ISP_CMD = ISP_CMD & 0xf8; /* 清低3位 */
- ISP_CMD = ISP_CMD | PrgCommand; /* 寫命令2 */
- ISP_DATA = original_data; /* 寫入數(shù)據(jù)準(zhǔn)備 */
- ISP_IAP_disable(); /* 關(guān)閉IAP功能 */
- 主函數(shù)
- void main (void)
- { DelayMs(5);
- a=byte_read(0x2000);//程序開始時(shí)讀取EEPROM中數(shù)據(jù)
- //SectorErase(0x2000);//擦除扇區(qū)
- // byte_write(0x2000,5);//重新寫入數(shù)據(jù)
- while (1) //主循環(huán)
- { D=d[a];
- anjian( );
- mchshch( );
- void anjian( ) //按鍵函數(shù)
- { if(s1==0)
- {DelayMs(5);
- if(s1==0)
- {while(!s1) //按鍵不松開調(diào)用顯示函數(shù)
- DelayMs(5);
- a++;
- if(a==10)
- a=1;
- SectorErase(0x2000);//擦除扇區(qū)
- byte_write(0x2000,a);//重新寫入數(shù)據(jù)
- if(s2==0)
- {DelayMs(5);
- if(s2==0)
- {while(!s2) //按鍵不松開調(diào)用顯示函數(shù)
- DelayMs(5);
- a--;
- if(a==0)
- a=9;
- void mchshch( ) //脈沖輸出函數(shù)
- { if(s3==0)
- {DelayMs(1000);
- if(s3==0)
- {DelayMs(500);
- m=0;
- q1=0;
- DelayMs(a);
- m=1;
- q1=1;
- DelayMs(100);
- m=0;
- q1=0;
- DelayMs(a);
- m=1;
- q1=1;
- DelayMs(100);
- while(!s3)
- DelayMs(50); }
- uS延時(shí)函數(shù),含有輸入?yún)?shù) unsigned char t,無(wú)返回值
- unsigned char 是定義無(wú)符號(hào)字符變量,其值的范圍是
- 0~255 這里使用晶振12M,精確延時(shí)請(qǐng)使用匯編,大致延時(shí)
- 長(zhǎng)度如下 T=tx2+5 uS
- void DelayUs2x(unsigned char t)
- while(--t);
- mS延時(shí)函數(shù),含有輸入?yún)?shù) unsigned char t,無(wú)返回值
- void DelayMs(unsigned int t) //大致延時(shí)1mS
- while(t--)
- DelayUs2x(245);
- DelayUs2x(245);
復(fù)制代碼 |
