查看: 4351|回復(fù): 13
基于51單片機和DS18B20的溫控電機Proteus仿真程序設(shè)計
ID:893265 發(fā)表于 2021-3-24 15:21 | 顯示全部樓層 |閱讀模式
#include "reg51.h"
#include "ds18b20.c"
#include "lcd1602.c"
#include "timer.c"
sbit led_z = P1^3;
sbit led_f = P1^4;
sbit bz = P1^7;
sbit Ap = P1^0;
sbit Bp = P1^1;
void main(void)
        unsigned char tp,tp_old,tep,speed;
        unsigned char bz_on;
        unsigned char way;
        duty = 100;
        pwm = 25;
        tp = 25;
        tp_old = 25;
        tep = 26;
        speed = 0;
        led_z = 1;
        led_f = 1;
        bz = 0;
        bz_on = 0;
        way = 0;
        Init_LCD1602();
        Init_timer0();
        ds18b20_set_temp(85,0);//ζè0-85
                ds18b20_temp_conver();
                LCD_Display_Byte(0,2,'T');
                LCD_Write(1,'e');
                LCD_Write(1,'m');
                LCD_Write(1,'p');
                LCD_Write(1,':');
                LCD_Write(1,'0'+tep/10);
                LCD_Write(1,'0'+tep%10);
                LCD_Write(1,'C');
                delayms(50);
                tp = ds18b20_read_temp();
                if(tp!=tp_old)
                        tp_old = tp;
                        if(tp<100)
                                tep = tp;
                if(tep<=10)
                        pwm = (10-tep)*10;
                        speed = pwm;
                        if(tep==0)
                                bz_on = 1;
                                bz_on = 0;
                        way = 1;
                else if(tep>=45)
                        if(tep<=75)
                                pwm = (tep-45)*7/2;
                                if(pwm>99)
                                        pwm = 100;
                                speed = pwm;
                                pwm = 100;
                                speed = pwm;
                        if(tep>=75)
                                bz_on = 1;
                                bz_on = 0;
                        way= 0;
                if((tep>10)&&(tep<45))
                        pwm = 0;
                        speed = pwm;
                        bz_on = 0;
                LCD_Display_Byte(1,2,'S');
                LCD_Write(1,'p');
                LCD_Write(1,'e');
                LCD_Write(1,'e');
                LCD_Write(1,'d');
                LCD_Write(1,':');
                LCD_Write(1,'0'+speed/100);
                LCD_Write(1,'0'+(speed/10)%10);
                LCD_Write(1,'0'+speed%10);
                LCD_Write(1,'%');
                if(pwm>0)
                        if(!way)
                                Ap = 1;
                                Bp = 0;
                                led_z = 0;
                                led_f = 1;
                                Ap = 0;
                                Bp = 1;
                                led_z = 1;
                                led_f = 0;
                                led_z = 1;
                                led_f = 1;
                if(bz_on)
                        bz = ~bz;
                        bz = 0;
溫控電機.zip
121.94 KB, 下載次數(shù): 128, 下載積分: 黑幣 -5
admin + 50 共享資料的黑幣獎勵!
ID:893265 發(fā)表于 2021-4-2 11:29 | 顯示全部樓層
reworld 發(fā)表于 2021-3-30 14:29
您好~LCD1602沒有顯示內(nèi)容誒
參與人數(shù) 1黑幣 +40 收起 理由
admin + 40 回帖助人的獎勵!
ID:720305 發(fā)表于 2021-3-28 17:32 | 顯示全部樓層
電機周圍那四個器件是什么啊 急急急
ID:766622 發(fā)表于 2021-3-30 14:29 | 顯示全部樓層
ID:720305 發(fā)表于 2021-4-1 16:25 | 顯示全部樓層
可能是protues版本的問題 我也做了一份類似的 可以私聊我
ID:893265 發(fā)表于 2021-4-2 11:25 | 顯示全部樓層
AI工程 發(fā)表于 2021-3-28 17:32
電機周圍那四個器件是什么啊 急急急
二極管
ID:893265 發(fā)表于 2021-4-2 11:28 | 顯示全部樓層
應(yīng)該是你版本問題,截圖好像發(fā)不上來
ID:899171 發(fā)表于 2021-4-2 14:44 | 顯示全部樓層
參考下,希望我的溫度傳感器能有用
ID:766622 發(fā)表于 2021-4-25 17:04 | 顯示全部樓層
回復(fù)晚了抱歉,謝謝!
ID:296417 發(fā)表于 2021-5-8 14:13 | 顯示全部樓層
估計有參考價值
ID:915917 發(fā)表于 2021-5-10 21:05 | 顯示全部樓層
電機周圍那四個器件是什么啊 急急急
整流橋
ID:245820 發(fā)表于 2021-5-11 10:58 | 顯示全部樓層
剛好學習溫度傳感器,學習了,謝謝
ID:939357 發(fā)表于 2021-6-20 21:55 | 顯示全部樓層
AI工程 發(fā)表于 2021-4-1 16:25
你好求您的仿真設(shè)計
ID:941093 發(fā)表于 2021-6-21 18:23 | 顯示全部樓層
祝51黑越來越好
