ov2640寄存器是原子例程基礎(chǔ)上修改的,程序是tq2440 ov9650裸跑程序改的。
主要是把攝像頭設(shè)置為ycbcr422輸出(因為2440只支持ITU601-656標準的8位ycbcr)。
剛開始傻傻的設(shè)置為rgb發(fā)現(xiàn)怎么調(diào)都無法出圖像,仔細看了2440的camera接口時序才發(fā)現(xiàn)不支持rgb。
其實rgb也可以顯示只是camera接口不支持,需要io口模擬時序。但是這樣輸出幀率較低而且圖像不完整,想快只能使用硬件camera接口。
以下是主要配置 :
0xff, 0x00,
0x2c, 0xff,
0x2e, 0xdf,
0xff, 0x01,
0x3c, 0x32,
0x11, 0x00,
0x09, 0x02,
0x04, 0xD8,
0x13, 0xe5,
0x14, 0x48,
0x2c, 0x0c,
0x33, 0x78,
0x3a, 0x33,
0x3b, 0xfB,
0x3e, 0x00,
0x43, 0x11,
0x16, 0x10,
0x39, 0x92,
0x35, 0xda,
0x22, 0x1a,
0x37, 0xc3,
0x23, 0x00,
0x34, 0xc0,
0x36, 0x1a,
0x06, 0x88,
0x07, 0xc0,
0x0d, 0x87,
0x0e, 0x41,
0x4c, 0x00,
0x48, 0x00,
0x5B, 0x00,
0x42, 0x03,
0x4a, 0x81,
0x21, 0x99,
0x24, 0x40,
0x25, 0x38,
0x26, 0x82,
0x5c, 0x00,
0x63, 0x00,
0x46, 0x00,
0x0c, 0x3c,
0x61, 0x70,
0x62, 0x80,
0x7c, 0x05,
0x20, 0x80,
0x28, 0x30,
0x6c, 0x00,
0x6d, 0x80,
0x6e, 0x00,
0x70, 0x02,
0x71, 0x94,
0x73, 0xc1,
0x3d, 0x34,
0x5a, 0x57,
0x12, 0x00,//UXGA 1600*1200
0x17, 0x11,
0x18, 0x75,
0x19, 0x01,
0x1a, 0x97,
0x32, 0x36,
0x03, 0x0f,
0x37, 0x40,
0x4f, 0xca,
0x50, 0xa8,
0x5a, 0x23,
0x6d, 0x00,
0x6d, 0x38,
0xff, 0x00,
0xe5, 0x7f,
0xf9, 0xc0,
0x41, 0x24,
0xe0, 0x14,
0x76, 0xff,
0x33, 0xa0,
0x42, 0x20,
0x43, 0x18,
0x4c, 0x00,
0x87, 0xd5,
0x88, 0x3f,
0xd7, 0x03,
0xd9, 0x10,
0xd3, 0x82,
0xc8, 0x08,
0xc9, 0x80,
0x7c, 0x00,
0x7d, 0x00,
0x7c, 0x03,
0x7d, 0x48,
0x7d, 0x48,
0x7c, 0x08,
0x7d, 0x20,
0x7d, 0x10,
0x7d, 0x0e,
0x90, 0x00,
0x91, 0x0e,
0x91, 0x1a,
0x91, 0x31,
0x91, 0x5a,
0x91, 0x69,
0x91, 0x75,
0x91, 0x7e,
0x91, 0x88,
0x91, 0x8f,
0x91, 0x96,
0x91, 0xa3,
0x91, 0xaf,
0x91, 0xc4,
0x91, 0xd7,
0x91, 0xe8,
0x91, 0x20,
0x92, 0x00,
0x93, 0x06,
0x93, 0xe3,
0x93, 0x05,
0x93, 0x05,
0x93, 0x00,
0x93, 0x04,
0x93, 0x00,
0x93, 0x00,
0x93, 0x00,
0x93, 0x00,
0x93, 0x00,
0x93, 0x00,
0x93, 0x00,
0x96, 0x00,
0x97, 0x08,
0x97, 0x19,
0x97, 0x02,
0x97, 0x0c,
0x97, 0x24,
0x97, 0x30,
0x97, 0x28,
0x97, 0x26,
0x97, 0x02,
0x97, 0x98,
0x97, 0x80,
0x97, 0x00,
0x97, 0x00,
0xc3, 0xef,
0xa4, 0x00,
0xa8, 0x00,
0xc5, 0x11,
0xc6, 0x51,
0xbf, 0x80,
0xc7, 0x10,
0xb6, 0x66,
0xb8, 0xA5,
0xb7, 0x64,
0xb9, 0x7C,
0xb3, 0xaf,
0xb4, 0x97,
0xb5, 0xFF,
0xb0, 0xC5,
0xb1, 0x94,
0xb2, 0x0f,
0xc4, 0x5c,
0xc0, 0xc8,
0xc1, 0x96,
0x8c, 0x00,
0x86, 0x3d,
0x50, 0x00,
0x51, 0x90,
0x52, 0x2c,
0x53, 0x00,
0x54, 0x00,
0x55, 0x88,
0x5a, 0x90,
0x5b, 0x2C,
0x5c, 0x05,
0xd3, 0x02,
0xc3, 0xed,
0x7f, 0x00,
0xda, 0x09,
0xe5, 0x1f,
0xe1, 0x67,
0xe0, 0x00,
0xdd, 0x7f,
0x05, 0x00,
//yuv422
0xc2,0x0c,
0xFF, 0x00,
0xD7, 0x03,
0xDF, 0x00,
0x33, 0x80,
0x3C, 0x40,
0xe1, 0x77,
0xda, 0x00,
0x00, 0x00,
rCIGCTRL |=(1<<25)|(0<<27); // inverse PCLK, test pattern
rCIWDOFST = (1<<30)|(0xf<<12); // clear overflow
rCIWDOFST = 0;
rCIWDOFST=(WinOfsEn<<31)|(WinHorOffset<<16)|(WinVerOffset);
rCISRCFMT=(CAM_ITU601<<31)|(0<<30)|(0<<29)|(CAM_SRC_HSIZE<<16)|(CAM_ORDER_YCBYCR<<14)|(CAM_SRC_VSIZE);
