查看: 2706|回復: 3
有關GH1621的MCU驅動程序問題
ID:438796 發(fā)表于 2021-3-31 11:24 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
20黑幣
我現(xiàn)在用GN1621驅動液晶屏,不能單獨操作SEG口,我想給SEG9一個0xf0,液晶屏全亮了。有有大佬知道問題嗎?
單片機源程序如下:
#define  unchar     unsigned char #define  unint      unsigned int
#define  unlong     unsigned long
#define CS                RC0                                        //片選端
//#define        RD                RC1                                        //讀數(shù)據(jù)時鐘
#define WR                RC1                                        //寫數(shù)據(jù)時鐘
#define DATA        RC4                                        //串行數(shù)據(jù)端
void DelayUs(unsigned char Time)
        unsigned char a;
        for(a=0;a<Time;a++)
                CLRWDT();
void delay(void)
        unchar i;
        for(i=0;i<200;i++);
void delay_ms(unsigned char Time)
        unsigned char a,b;
        for(a=0;a<Time;a++)
                for(b=0;b<5;b++)
                         DelayUs(197);                   //快1%
void write_byte(unchar byte,unchar length)
        unchar i;
        for(i=0;i<length;i++)
                WR = 0;
                delay();
                if(byte & 0X80)
                        DATA = 1;                        //高位先傳
                        DATA = 0;
                byte <<= 1;
                WR = 1;        //WR上升沿鎖存
                delay();
void Write_dat(unchar dat)                //寫數(shù)據(jù)
        unchar i;
        CS = 1;
        delay();
        CS = 0;        //片選低電平使能
        write_byte(0XA0,3);                                //傳3位命令碼101
        write_byte(0X09,6);                                //傳6位地址碼,起始地址00H
        for(i=0;i<32;i++)
                write_byte(dat,4);                //傳4位數(shù)據(jù)。高位先傳
void Write_dat1(unchar Addr,unchar dat)                //寫數(shù)據(jù)
        unchar i;
        CS = 1;
        delay();
        CS = 0;        //片選低電平使能
        write_byte(Addr,6);                                //傳6位地址碼,起始地址00H
        for(i=0;i<8;i++)
void Write_cmd(unchar cmd)                //寫指令
        CS = 1;
        delay();
        CS = 0;
        write_byte(0X80,3);                                //傳3位命令碼100
        write_byte(cmd,9);                                //傳9位指令
void lcd_init(void)
        delay_ms(100);
        Write_cmd(0x01);                                        //開啟系統(tǒng)時鐘
        Write_cmd(0X18);                                        //內部RC震蕩
//  Write_cmd(0X14);                                        //晶體振蕩
////        Write_cmd(0X07);          //允許WDT暫停標志輸出
////        Write_cmd(0X88);          //允許IRQ輸出
////        Write_cmd(0X60);          //蜂鳴頻率:2KHz
        Write_cmd(0x29);                                        //1/3偏置,4COM
        Write_dat(0x00);                                        //RAM清零
        Write_cmd(0x03);                                        //開顯示
*  函數(shù)名:POWER_INITIAL
*        功能:  上電系統(tǒng)初始化
*  輸入:  無
*  輸出:  無
void POWER_INITIAL (void)
        OSCCON = 0B01110001;        //WDT 32KHZ IRCF=111=16MHZ/2=8MHZ,0.125US/T
                                                         //Bit0=1,系統(tǒng)時鐘為內部振蕩器
                                                         //Bit0=0,時鐘源由FOSC<2:0>決定即編譯選項時選擇
        INTCON = 0;                          //暫禁止所有中斷
        PORTA = 0B00000000;
        TRISA = 0B00000000;                //PA輸入輸出 0-輸出 1-輸入
                                                        //PA3->輸出
        PORTC = 0B00000000;
        TRISC = 0B00000000;                //PC輸入輸出 0-輸出 1-輸入
        WPUA = 0B00000000;             //PA端口上拉控制 1-開上拉 0-關上拉
        WPUC = 0B00000000;             //PC端口上拉控制 1-開上拉 0-關上拉
        OPTION = 0B00001000;        //Bit3=1 WDT MODE,PS=000=1:1 WDT RATE
                                                         //Bit7(PAPU)=0 ENABLED PULL UP PA
        MSCKCON = 0B00000000;        //Bit6->0,禁止PA4,PC5穩(wěn)壓輸出
                                                          //Bit5->0,TIMER2時鐘為Fosc
                                                          //Bit4->0,禁止LVR
        CMCON0 = 0B00000111;         //關閉比較器,CxIN為數(shù)字IO口
*  函數(shù)名: main
*        功能:  主函數(shù)
*  輸入:  無
*  輸出:  無
        POWER_INITIAL();                        //系統(tǒng)初始化
    lcd_init();
//Write_dat1(0x16,0x00);
//Write_dat1(0x15,0x00);
//Write_dat1(0x14,0x00);
//Write_dat1(0x13,0x00);
//Write_dat1(0x12,0x00);
//Write_dat1(0x11,0x00);
//Write_dat1(0x10,0x00);
//Write_dat1(0x0F,0x00);
//Write_dat1(0x0E,0x00);
//Write_dat1(0x0D,0x00);
//Write_dat1(0x0C,0x00);
//Write_dat1(0x0B,0x00);
//Write_dat1(0x0A,0x00);
Write_dat1(0x09,0xf0);
ID:584814 發(fā)表于 2021-3-31 20:26 | 只看該作者
1621驅動液晶屏可以任意點亮任意字段的
ID:438796 發(fā)表于 2021-4-30 13:49 | 只看該作者
本帖最后由 林哈哈 于 2021-4-30 14:20 編輯
//        unchar i;
        CS = 1;
        delay();
        CS = 0;        //片選低電平使能
        write_byte(Addr<<2,6);                                //傳6位地址碼,起始地址00H
}這樣就可以了
ID:357396 發(fā)表于 2022-3-27 15:17 | 只看該作者
如下
  1. void Write_dat1(unchar Addr,unchar dat)                //寫數(shù)據(jù)
  2. {
  3. //        unchar i;
  4.         CS = 1;
  5.         delay();
  6.         CS = 0;        //片選低電平使能
  7.         write_byte(0XA0,3);                                //傳3位命令碼101
  8.         write_byte(Addr<<2,6);                                //傳6位地址碼,起始地址00H
  9.         write_byte(dat,4);                //傳4位數(shù)據(jù)。高位先傳
  10. }這樣就可以了
復制代碼
