查看: 4975|回復(fù): 7
單片機(jī)超聲波測(cè)距儀Proteus7.5仿真程序 數(shù)碼管顯示
采用51單片機(jī)+超聲波模塊
提供了另外一種超聲波測(cè)速及其程序仿真文件
超聲波模塊電路連接
Trig -------  P2^1;
Echo -------  P2^0;
VCC  -------- +5v
GND  -------- GND
void Conut(void)   //距離數(shù)據(jù)處理函數(shù)
         time=TH0*256+TL0;
         TH0=0;
         TL0=0;
         S=(time*1.7)/100;     //算出來(lái)是CM
         if((S>=700)||flag==1) //超出測(cè)量范圍顯示“-”
          flag=0;
          DisplayOneChar(0, 1, ASCII[11]);
          DisplayOneChar(1, 1, ASCII[10]);        //顯示點(diǎn)
          DisplayOneChar(2, 1, ASCII[11]);
          DisplayOneChar(3, 1, ASCII[11]);
          DisplayOneChar(4, 1, ASCII[12]);        //顯示M
          disbuff[0]=S%1000/100;
          disbuff[1]=S%1000%100/10;
          disbuff[2]=S%1000%10 %10;
          DisplayOneChar(0, 1, ASCII[disbuff[0]]);
          DisplayOneChar(2, 1, ASCII[disbuff[1]]);
          DisplayOneChar(3, 1, ASCII[disbuff[2]]);
//中斷函數(shù)
void zd0() interrupt 1                  //T0中斷用來(lái)計(jì)數(shù)器溢出,超過(guò)測(cè)距范圍
    flag=1;                                                         //中斷溢出標(biāo)志
//主函數(shù)
void main(void)
         TMOD=0x01;                   //設(shè)T0為方式1,GATE=1;
         TH0=0;
         TL0=0;
         ET0=1;             //允許T0中斷
         EA=1;                           //開(kāi)啟總中斷
        InitLcd1602();
        LcdShowStr(0,0,PuZh);
                 StartModule();
             while(!Echo);                //當(dāng)RX為零時(shí)等待
             TR0=1;                            //開(kāi)啟計(jì)數(shù)
             while(Echo);                        //當(dāng)RX為1計(jì)數(shù)并等待
             TR0=0;                                //關(guān)閉計(jì)數(shù)
         Conut();                        //計(jì)算
                 delayms(80);
LCD1602顯示函數(shù)
void Read_Busy()           //忙檢測(cè)函數(shù),判斷bit7是0,允許執(zhí)行;1禁止
    unsigned char sta;      //
    LCD1602_DB = 0xff;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do
        LCD1602_EN = 1;
        sta = LCD1602_DB;
        LCD1602_EN = 0;    //使能,用完就拉低,釋放總線
    }while(sta & 0x80);
void Lcd1602_Write_Cmd(unsigned char cmd)     //寫命令
    Read_Busy();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_EN = 1;
    LCD1602_EN = 0;
void Lcd1602_Write_Data(unsigned char dat)   //寫數(shù)據(jù)
      Read_Busy();
      LCD1602_RS = 1;
      LCD1602_RW = 0;
      LCD1602_DB = dat;
      LCD1602_EN = 1;
      LCD1602_EN = 0;
void LcdSetCursor(unsigned char x,unsigned char y)  //坐標(biāo)顯示
    unsigned char addr;
    if(y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
    Lcd1602_Write_Cmd(addr|0x80);
//按指定位置顯示一個(gè)字符
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
        Y &= 0x1;
        X &= 0xF; //限制X不能大于15,Y不能大于1
        if (Y) X |= 0x40; //當(dāng)要顯示第二行時(shí)地址碼+0x40;
        X |= 0x80; //算出指令碼
        Lcd1602_Write_Cmd(X); //發(fā)命令字
        Lcd1602_Write_Data(DData); //發(fā)數(shù)據(jù)
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str)     //顯示字符串
    LcdSetCursor(x,y);      //當(dāng)前字符的坐標(biāo)
    while(*str != '\0')
        Lcd1602_Write_Data(*str++);
void InitLcd1602()              //1602初始化
    Lcd1602_Write_Cmd(0x38);    //打開(kāi),5*8,8位數(shù)據(jù)
    Lcd1602_Write_Cmd(0x0c);
    Lcd1602_Write_Cmd(0x06);
    Lcd1602_Write_Cmd(0x01);    //清屏
全部資料51hei下載地址:
仿真代碼.7z (156.31 KB, 下載次數(shù): 146)
收藏收藏3 分享淘帖 頂 踩
ID:903863 發(fā)表于 2021-4-11 15:58 | 只看該作者
樓主右下角那個(gè)是什么?
ID:827454 發(fā)表于 2021-4-21 11:48 | 只看該作者
藍(lán)精靈. 發(fā)表于 2021-4-11 15:58
樓主右下角那個(gè)是什么?
超聲波模塊
ID:827454 發(fā)表于 2021-4-21 11:49 | 只看該作者
樓主右下角那個(gè)是什么?
超聲波模塊,按鍵控制距離
ID:924160 發(fā)表于 2021-5-19 22:33 | 只看該作者
樓主可以給個(gè)Proteus8.0的仿真嗎? 壓縮包的這個(gè)dsn文件只能用7.5版本的打開(kāi),,而我只安裝了8.0的軟件
ID:74293 發(fā)表于 2021-5-25 19:01 | 只看該作者
樓主,超聲波模塊那個(gè)怎么設(shè)置起始距離?我這怎么一開(kāi)機(jī)就是200多CM
ID:1053360 發(fā)表于 2022-11-22 16:21 | 只看該作者
樓主 HC-SR04.hex文件的作用是什么?
ID:987283 發(fā)表于 2022-11-28 17:12 | 只看該作者
且以深情共白頭 發(fā)表于 2021-5-19 22:33
兄弟你的解決了沒(méi)有,我也是這,要是解決了的話發(fā)我一份唄
