此程序只有轉速PID 速度通過程序Set_Point調節(jié) 調節(jié)范圍在100到12000之間
KEY2控制無刷電機啟動
KEY3控制無刷電機停止
單片機源程序如下:
- #include "includes.h"
- void Delay_us(uint8_t t);
- /**********常量定義**********/
- #define IDLE 0
- #define START 1
- #define RUN 2
- #define STOP 3
- #define FAULT 4
- #define HIGH 1480
- #define LOW 3
- /*********全局變量***********/
- u8 state; //主狀態(tài)
- FlagStatus zheng_fan = RESET;//初始化后為正轉
- uint8_t stalling_count = 0; //堵轉計數器
- * Description : None
- * Input : None
- * Output : None
- * Return : None
- * Attention : None
- void BLDC_GPIOConfig(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10; //TIM1輸出
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;//TIM1輸出
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7; //TIM3的霍爾輸入
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //TIM3的霍爾輸入
- * Input : None
- * Output : None
- * Return : None
- void BLDC_TIM1Config(void)
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; //基本結構體變量定義
- TIM_OCInitTypeDef TIM_OCInitStructure; //輸出結構體變量定義
- TIM_BDTRInitTypeDef TIM_BDTRInitStructure; //死區(qū)剎車結構體變量定義
- TIM_DeInit(TIM1);
- TIM_TimeBaseStructure.TIM_Prescaler = 2; //TIM基本初始化
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_CenterAligned2;//中央對齊計數模式
- TIM_TimeBaseStructure.TIM_Period = 1499; //PWM 16K
- TIM_TimeBaseStructure.TIM_ClockDivision = 0;
- TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
- TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure);
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //TIM輸出通道初始化
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Disable;
- TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable;
- TIM_OCInitStructure.TIM_Pulse =1200;
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
- TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
- TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
- TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
- TIM_OC1Init(TIM1,&TIM_OCInitStructure);
- TIM_OC2Init(TIM1,&TIM_OCInitStructure);
- TIM_OC3Init(TIM1,&TIM_OCInitStructure);
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //TIM輸出通道4初始化,用來觸發(fā)AD注入采樣
- TIM_OCInitStructure.TIM_Pulse =1495;
- TIM_OC4Init(TIM1,&TIM_OCInitStructure);
- TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable; //死區(qū)剎車初始化
- TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
- TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_OFF;
- TIM_BDTRInitStructure.TIM_DeadTime = 100;
- TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable; //如打開,開機無輸出且狀態(tài)紊亂????
- TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_Low;
- TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Disable;
- TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure);
- TIM_OC1PreloadConfig(TIM1,TIM_OCPreload_Enable); //使能捕獲比較寄存器預裝載(通道1)
- TIM_OC2PreloadConfig(TIM1,TIM_OCPreload_Enable); //使能捕獲比較寄存器預裝載(通道2)
- TIM_OC3PreloadConfig(TIM1,TIM_OCPreload_Enable); //使能捕獲比較寄存器預裝載(通道3)
- TIM_SelectInputTrigger(TIM1, TIM_TS_ITR2); //輸入觸發(fā)源選擇TIM3
- //TIM_SelectSlaveMode(TIM1, TIM_SlaveMode_Trigger);//從模式選擇 觸發(fā)
- TIM_CtrlPWMOutputs(TIM1,ENABLE);
- TIM_Cmd(TIM1,ENABLE);
- * Input : None
- * Output : None
- * Return : None
- void BLDC_TIM3Config(void)
- TIM_ICInitTypeDef TIM_ICInitStructure; //定義結構體變量
- TIM_DeInit(TIM3);
- TIM_TimeBaseStructure.TIM_Prescaler = 71; //TIM基本初始化
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
- TIM_TimeBaseStructure.TIM_Period =65535;
- TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStructure);
- TIM_ICInitStructure.TIM_Channel = TIM_Channel_1; //選擇通道1
- TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; //輸入上升沿捕獲
- TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_TRC; //配置通道為輸入,并映射到哪里
- TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; //輸入捕獲預分頻值
- TIM_ICInitStructure.TIM_ICFilter = 10; //輸入濾波器帶寬設置
- TIM_ICInit(TIM3, &TIM_ICInitStructure); //輸入通道配置
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
- TIM_OCInitStructure.TIM_Pulse =1023;
- TIM_OC2Init(TIM3,&TIM_OCInitStructure);
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing; //TIM輸出通道初始化
- TIM_OCInitStructure.TIM_Pulse =65535;
- TIM_OC4Init(TIM3,&TIM_OCInitStructure);
- TIM_SelectHallSensor(TIM3,ENABLE); //使能TIMx的霍爾傳感器接口
- TIM_SelectInputTrigger(TIM3, TIM_TS_TI1F_ED); //輸入觸發(fā)源選擇
- TIM_SelectSlaveMode(TIM3, TIM_SlaveMode_Reset); //從模式選擇
- TIM_SelectMasterSlaveMode(TIM3, TIM_MasterSlaveMode_Enable);//主從模式選擇
- TIM_SelectOutputTrigger(TIM3, TIM_TRGOSource_OC2Ref); //選擇輸出觸發(fā)模式(TRGO端)
- TIM_ITConfig(TIM3, TIM_IT_Trigger|TIM_IT_CC4, ENABLE); //開定時器中斷
- //TIM_Cmd(TIM3,ENABLE);
- * Input : None
- * Output : None
- * Return : None
- void huanxiang(void)
- u8 irq_zhuanzi;
- irq_zhuanzi=(u8)((GPIOA->IDR&0x000000c0)>>6); //讀轉子位置
- irq_zhuanzi|=(u8)((GPIOB->IDR&0x00000001)<<2);
- if(zheng_fan==RESET)
- { //正轉
- switch(irq_zhuanzi) //根據轉子位置,決定CCER輸出相位和轉子字偏移量
- /* case 0x01:{
- TIM1->CCER=0x3081; //1,4
- };break;
- case 0x03:{
- TIM1->CCER=0x3180; //4,5
- };break;
- case 0x02:{
- TIM1->CCER=0x3108; //2,5
- };break;
- case 0x06:{
- TIM1->CCER=0x3018; //2,3
- };break;
- case 0x04:{
- TIM1->CCER=0x3810; //3,6
- };break;
- case 0x05:{
- TIM1->CCER=0x3801; //1,6
- };break;
- default:break; */
- case 0x05:{
- };break;
- case 0x04:{
- };break;
- case 0x06:{
- };break;
- case 0x02:{
- };break;
- case 0x03:{
- };break;
- case 0x01:{
- };break;
- default:break;
- else
- { //反轉
- case 0x01:{
- };break;
- case 0x05:{
- };break;
- case 0x04:{
- };break;
- case 0x06:{
- };break;
- case 0x02:{
- };break;
- case 0x03:{
- };break;
- default:break;
- /**************啟動******************/
- void BLDC_Start(void)
- TIM1->SMCR|=0x0006; //開TIM1的輸入觸發(fā)
- TIM1->DIER=0x0040; //開TIM1的觸發(fā)中斷
- huanxiang(); //調用換向函數,啟動
- TIM3->CR1|=0x0001; //開TIM3
- TIM3->DIER|=0x0050; //開TIM3中斷
- void BLDC_Stop(void)
- TIM1->SMCR&=0xfff8; //關閉TIM1的輸入觸發(fā)
- TIM1->CCER=0; //關閉TIM1的六路輸出
- Delay_us(40); //延時(加死區(qū))
- TIM1->CCER=0x0ccc; //打開三路下管,進行能耗制動
- while(stalling_count<1); //等待電機停止(TIM3連續(xù)溢出10次,即認為電機已停轉)
- TIM1->CCER=0; //關閉TIM1的六路輸出,關剎車
- TIM3->CR1&=0xfffe; //關閉TIM3
- TIM3->CNT=0; //清TIM3的計數器
- TIM3->DIER&=0xffaf; //關TIM3中斷
- while(t--)
- /**************停止******************/
- /*void stop(void)
- Delay(20); //延時(加死區(qū))
- while(duzhuan_value<1); //等待電機停止(TIM3連續(xù)溢出10次,即認為電機已停轉)
- data_reset(); //復位運行參數
復制代碼
所有代碼51hei提供下載:
STM32速度環(huán)PID.rar
(390.88 KB, 下載次數: 107)
2021-4-1 18:16 上傳
點擊文件名下載附件
STM32 BLDC驅動分享
