查看: 3483|回復(fù): 0
單片機(jī)直插心形流水燈制作 眼神不太好 拿去表白 不謝
ID:169534 發(fā)表于 2021-4-4 01:12 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#define        uint        unsigned int
#define        uchar        unsigned char
uchar code table0[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//LED從低位往高位移
uchar code table1[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};//LED從高位往低位移
uchar code table2[]={0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0x80,0x00};//LED從1個(gè)亮到8個(gè)都點(diǎn)亮(從低位往高位)
uchar code table3[]={0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01,0x00};//LED從1個(gè)亮到8個(gè)都點(diǎn)亮(從高位往低位)
uchar code table4[]={0x00,0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff};//LED從8個(gè)全亮到一個(gè)都不亮(從低位往高位)
uchar code table5[]={0x00,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff};//LED從8個(gè)全亮到一個(gè)都不亮(從高位往低位)
uchar code table6[]={0xfe,0xfc,0xfa,0xf6,0xee,0xde,0xbe,0x7e};//LED從低位往高位移(最低位始終為0)
uchar code table7[]={0x7f,0x3f,0x5f,0x6f,0x77,0x7b,0x7d,0x7e};//LED從高位往低位移(最高位始終為0)
uchar i,j;                //定義循環(huán)變量
uint tt=70;                //定義時(shí)間指數(shù)
void delay(uint time)        //延時(shí)函數(shù)
        uint x,y;
        for(x=time;x>0;x--)
        for(y=110;y>0;y--);
void disp0()                        //狀態(tài)0 所有LED閃爍3次
        for(i=0;i<3;i++)
                P0=0x00; P2=0x00; P3=0x00; P1=0x00;
                delay(300);
                P0=0xff; P2=0xff; P3=0xff; P1=0xff;
                delay(300);
void disp1()                        //狀態(tài)1 LED順時(shí)針轉(zhuǎn)一圈
        for(i=0;i<8;i++)
                P2=table1[ i];
                delay(100);
        P2=0xff;
        for(i=0;i<8;i++)
                P3=table1[ i];
                delay(100);
        P3=0xff;
        for(i=0;i<8;i++)
                P1=table1[ i];
                delay(100);
        P1=0xff;
        for(i=0;i<8;i++)
                P0=table0[ i];
                delay(100);
        P0=0xff;
void disp2()                        //狀態(tài)2 LED逆時(shí)針轉(zhuǎn)一圈
        for(i=0;i<8;i++)
                P0=table1[ i];
                delay(100);
        P0=0xff;
        for(i=0;i<8;i++)
                P1=table0[ i];
                delay(100);
        P1=0xff;
        for(i=0;i<8;i++)
                P3=table0[ i];
                delay(100);
        P3=0xff;
        for(i=0;i<8;i++)
                P2=table0[ i];
                delay(100);
        P2=0xff;
void disp3()                        //狀態(tài)3 4個(gè)LED同時(shí)順時(shí)、逆時(shí)針移動1/4圈
        for(i=0;i<8;i++)
                P0=table1[ i];
                P1=table1[ i];
                P2=table1[ i];
                P3=table0[ i];
                delay(100);
        for(i=0;i<8;i++)
                P0=table0[ i];
                P1=table0[ i];
                P2=table0[ i];
                P3=table1[ i];
                delay(100);
        P3=0xff; P0=0xff;
void disp4()                        //狀態(tài)4  2個(gè)LED同時(shí)順時(shí)針移動半圈
        for(i=0;i<8;i++)
                P2=table1[ i];
                P1=table1[ i];
                delay(100);
        P2=0xff; P1=0xff;
        for(i=0;i<8;i++)
                P3=table1[ i];
                P0=table0[ i];
                delay(100);
        P3=0xff; P0=0xff;
void disp5()                        //狀態(tài)5  2個(gè)LED同時(shí)逆時(shí)針移動半圈
        for(i=0;i<8;i++)
                P0=table1[ i];
                P3=table0[ i];
                delay(100);
        P0=0xff; P3=0xff;
        for(i=0;i<8;i++)
                P1=table0[ i];
                P2=table0[ i];
                delay(100);
        P1=0xff; P2=0xff;
void disp6()                        //狀態(tài)6 LED自上而下逐漸點(diǎn)亮(一半點(diǎn)亮一半不亮)
        for(i=0;i<8;i++)
                P0=table3[ i];
                P2=table3[ i];
                delay(100);
        P0=0xff; P2=0xff;
        for(i=0;i<8;i++)
                P1=table2[ i];
                P3=table3[ i];
                delay(100);
        P1=0xff; P3=0xff;
void disp7()                        //狀態(tài)7 LED自下而上逐漸點(diǎn)亮(直到全部點(diǎn)亮)
        for(i=0;i<8;i++)
                P1=table3[ i];
                P3=table2[ i];
                delay(100);
        for(i=0;i<8;i++)
                P0=table2[ i];
                P2=table2[ i];
                delay(100);
void disp8()                        //狀態(tài)8 間斷8格的4個(gè)LED亮并逆時(shí)針旋轉(zhuǎn)
        for(j=0;j<2;j++)
                for(i=0;i<8;i++)
                        P0=table1[ i];
                        P2=table0[ i];
                        P1=table0[ i];
                        P3=table0[ i];
                        delay(100);
                P0=0xff; P2=0xff; P1=0xff; P3=0xff;
                for(i=0;i<8;i++)
                        P0=table1[ i];
                        P2=table0[ i];
                        P1=table0[ i];
                        P3=table0[ i];
                        delay(100);
void disp9()                        //狀態(tài)9 間斷8格的4個(gè)LED亮,然后逆時(shí)針逐漸點(diǎn)亮(直到全部點(diǎn)亮)
        for(i=0;i<8;i++)
                P0=table3[ i];
                P2=table2[ i];
                P1=table2[ i];
                P3=table2[ i];
                delay(100);
        delay(500);
void disp10()                        //狀態(tài)10 從LED全部亮到全不亮(間斷8格的4個(gè)LED開始逆時(shí)針熄滅)
        for(i=0;i<9;i++)
                P0=table5[ i];
                P2=table4[ i];
                P1=table4[ i];
                P3=table4[ i];
                delay(100);
        delay(300);
void disp11()                        //狀態(tài)11 間斷8格的4個(gè)LED亮并順時(shí)針旋轉(zhuǎn)
        for(j=0;j<2;j++)
                for(i=0;i<8;i++)
                        P0=table0[ i];
                        P2=table1[ i];
                        P1=table1[ i];
                        P3=table1[ i];
                        delay(100);
                for(i=0;i<8;i++)
                        P0=table0[ i];
                        P2=table1[ i];
                        P1=table1[ i];
                        P3=table1[ i];
                        delay(100);
void disp12()                        //間斷8格的4個(gè)LED亮,然后順時(shí)針逐漸點(diǎn)亮(直到全部點(diǎn)亮)
        for(i=0;i<8;i++)
                P0=table2[ i];
                P2=table3[ i];
                P1=table3[ i];
                P3=table3[ i];
                delay(100);
        delay(1000);
void disp13()                        //狀態(tài)13 從LED全部亮到全不亮(間斷8格的4個(gè)LED開始順時(shí)針熄滅)
        for(i=0;i<9;i++)
                P0=table4[ i];
                P2=table5[ i];
                P1=table5[ i];
                P3=table5[ i];
                delay(100);
        delay(300);
void disp14()                        //狀態(tài)14 從LED不亮到全亮(從P0.0、P1.0、P2.0、P3.7開始逐步點(diǎn)亮)
        for(i=0;i<8;i++)
                P0=table2[ i];
                P1=table2[ i];
                P2=table2[ i];
                P3=table3[ i];
                delay(100);
void disp15()                        //狀態(tài)15 從LED全亮到全不亮(從P0.7、P1.7、P2.7、P3.0開始逐步熄滅)
        for(i=0;i<9;i++)
                P0=table5[ i];
                P1=table5[ i];
                P2=table5[ i];
                P3=table4[ i];
                delay(100);
        delay(300);
void disp16()                        //狀態(tài)16 LED燈交替閃爍(頻率有慢變快)
        for(i=0;i<5;i++)
                P0=0xaa; P1=0xaa; P2=0xaa; P3=0xaa;
                delay(100);
                P0=~P0; P1=~P1; P2=~P2; P3=~P3;
                delay(100);
        for(i=0;i<5;i++)
                delay(200);
                delay(200);
        for(i=0;i<5;i++)
                delay(300);
                delay(300);
        delay(300);
void disp17()                        //狀態(tài)17 LED從P0.7開始逆時(shí)針逐步點(diǎn)亮,(循環(huán)2次)并且速度會逐步提高
        for(i=0;i<8;i++)
                P0=table3[ i];
                delay(100);
        for(i=0;i<8;i++)
                P1=table2[ i];
                delay(100);
        for(i=0;i<8;i++)
                P3=table2[ i];
                delay(100);
        for(i=0;i<8;i++)
                P2=table2[ i];
                delay(100);
        P0=0xff; P1=0xff; P3=0xff; P2=0xff;
        for(i=0;i<8;i++)
                P0=table3[ i];
                delay(50);
        for(i=0;i<8;i++)
                P1=table2[ i];
                delay(50);
        for(i=0;i<8;i++)
                P3=table2[ i];
                delay(50);
        for(i=0;i<8;i++)
                P2=table2[ i];
                delay(50);
void disp18()                        //狀態(tài)18 LED從P0.7開始逆時(shí)針逐步點(diǎn)亮(每亮8位后就熄滅)
        for(i=0;i<8;i++)
                P0=table3[ i];
                delay(100);
        P0=0xff;
        for(i=0;i<8;i++)
                P1=table2[ i];
                delay(100);
        P1=0xff;
        for(i=0;i<8;i++)
                P3=table2[ i];
                delay(100);
        P3=0xff;
        for(i=0;i<8;i++)
                P2=table2[ i];
                delay(100);
        P2=0xff;
void disp19()                        //狀態(tài)19 LED從P2.7開始順時(shí)針逐步點(diǎn)亮,(循環(huán)2次)并且速度會逐步提高
        for(i=0;i<8;i++)
                P2=table3[ i];
                delay(100);
        for(i=0;i<8;i++)
                P3=table3[ i];
                delay(100);
        for(i=0;i<8;i++)
                P1=table3[ i];
                delay(100);
        for(i=0;i<8;i++)
                P0=table2[ i];
                delay(100);
        for(i=0;i<8;i++)
                P2=table3[ i];
                delay(50);
        for(i=0;i<8;i++)
                P3=table3[ i];
                delay(50);
        for(i=0;i<8;i++)
                P1=table3[ i];
                delay(50);
        for(i=0;i<8;i++)
                P0=table2[ i];
                delay(50);
void disp20()                        //狀態(tài)20 LED從P2.7開始順時(shí)針逐步點(diǎn)亮(每亮8位后就熄滅)
        for(i=0;i<8;i++)
                P2=table3[ i];
                delay(100);
        P2=0xff;
        for(i=0;i<8;i++)
                P3=table3[ i];
                delay(100);
        P3=0xff;
        for(i=0;i<8;i++)
                P1=table3[ i];
                delay(100);
        P1=0xff;
        for(i=0;i<8;i++)
                P0=table2[ i];
                delay(100);
        P0=0xff;
void disp21()                        //狀態(tài)21 2個(gè)LED開始上下移動半圈
        for(i=0;i<8;i++)
                P0=table1[ i];
                P2=table1[ i];
                delay(100);
        P0=0xff; P2=0xff;
        for(i=0;i<8;i++)
                P1=table0[ i];
                P3=table1[ i];
                delay(100);
        for(i=0;i<8;i++)
                P1=table1[ i];
                P3=table0[ i];
                delay(100);
        P1=0xff; P3=0xff;
        for(i=0;i<8;i++)
                P0=table0[ i];
                P2=table0[ i];
                delay(100);
void disp22()                        //裝態(tài)22 2個(gè)LED自上而下移動(循環(huán)5次,且頻率漸快,到最快時(shí)持續(xù)循環(huán)16次,然后循環(huán)5次頻率再逐漸降低)
        for(j=0;j<5;j++)
                for(i=0;i<8;i++)
                        P0=table1[ i];
                        P2=table1[ i];
                        delay(tt);
                P0=0xff; P2=0xff;
                for(i=0;i<8;i++)
                        P1=table0[ i];
                        P3=table1[ i];
                        delay(tt);
                P1=0xff; P3=0xff;
                tt=tt-10;
        for(j=0;j<16;j++)
                for(i=0;i<8;i++)
                        P0=table1[ i];
                        P2=table1[ i];
                        delay(20);
                P0=0xff; P2=0xff;
                for(i=0;i<8;i++)
                        P1=table0[ i];
                        P3=table1[ i];
                        delay(20);
                P1=0xff; P3=0xff;
        tt=20;
        for(j=0;j<5;j++)
                for(i=0;i<8;i++)
                        P0=table1[ i];
                        P2=table1[ i];
                        delay(tt);
                P0=0xff; P2=0xff;
                for(i=0;i<8;i++)
                        P1=table0[ i];
                        P3=table1[ i];
                        delay(tt);
                P1=0xff; P3=0xff;
                tt=tt+10;
        tt=70;
void disp23()                        //狀態(tài)23 LED上下交替閃爍
        for(i=0;i<2;i++)
                P0=0x00; P2=0x00;
                delay(1000);
                P0=0xff; P2=0xff;
                P1=0x00; P3=0x00;
                delay(1000);
                P1=0xff; P3=0xff;
void disp24()                        //狀態(tài)24 LED左右交替閃爍
        P1=0xff; P3=0xff; P0=0xff; P2=0xff;
        for(i=0;i<2;i++)
                P0=0x00; P1=0x00;
                delay(1000);
                P0=0xff; P1=0xff;
                P2=0x00; P3=0x00;
                delay(1000);
                P2=0xff; P3=0xff;
void disp25()                        //狀態(tài)25 LED交替閃爍
        for(i=0;i<5;i++)
                delay(1000);
                delay(1000);
void disp26()                        //狀態(tài)26 2個(gè)LED開始上下移動半圈(LED不亮流水)
        P0=0x00;P1=0x00;P2=0x00;P3=0x00;
        for(i=0;i<8;i++)
                P0=~table1[ i];
                P2=~table1[ i];
                delay(200);
        P0=0x00; P2=0x00;
        for(i=0;i<8;i++)
                P1=~table0[ i];
                P3=~table1[ i];
                delay(200);
        for(i=0;i<8;i++)
                P1=~table1[ i];
                P3=~table0[ i];
                delay(200);
        P1=0x00; P3=0x00;
        for(i=0;i<8;i++)
                P0=~table0[ i];
                P2=~table0[ i];
                delay(200);
void disp27()                        //狀態(tài)27 逐步順時(shí)針點(diǎn)亮P2、P1的LED,熄滅后,再順時(shí)針點(diǎn)亮P0、P3的LED
        P0=0xff; P1=0xff; P2=0xff; P3=0xff;
        for(j=0;j<2;j++)
                for(i=0;i<8;i++)
                        P2=table3[ i];
                        P1=table3[ i];
                        delay(100);
                P2=0xff; P1=0xff;
                for(i=0;i<8;i++)
                        P0=table2[ i];
                        P3=table3[ i];
                        delay(100);
                P0=0xff; P3=0xff;
void disp28()                        //狀態(tài)28 P1、P2和P0、P3交替閃爍
        for(i=0;i<2;i++)
                P1=0x00; P2=0x00; P0=0xff; P3=0xff;
                delay(1000);
                P1=0xff; P2=0xff; P0=0x00; P3=0x00;
                delay(1000);
        P1=0xff; P2=0xff; P0=0xff; P3=0xff;
void disp29()                        //狀態(tài)29 逐步順時(shí)針點(diǎn)亮P2、P1的LED,再順時(shí)熄滅后,再順時(shí)針點(diǎn)亮P0、P3的LED,再順時(shí)熄滅
        for(j=0;j<2;j++)
                for(i=0;i<8;i++)
                        P2=table3[ i];
                        P1=table3[ i];
                        delay(100);
                for(i=0;i<9;i++)
                        P2=table5[ i];
                        P1=table5[ i];
                        delay(100);
                for(i=0;i<8;i++)
                        P0=table2[ i];
                        P3=table3[ i];
                        delay(100);
                for(i=0;i<9;i++)
                        P0=table4[ i];
                        P3=table5[ i];
                        delay(100);
        delay(200);
void disp30()                        //狀態(tài)30 逐步逆時(shí)針點(diǎn)亮P2、P1的LED,熄滅后,再逆時(shí)針點(diǎn)亮P0、P3的LED
        for(j=0;j<2;j++)
                for(i=0;i<8;i++)
                        P2=table2[ i];
                        P1=table2[ i];
                        delay(100);
                P2=0xff; P1=0xff;
                for(i=0;i<8;i++)
                        P0=table3[ i];
                        P3=table2[ i];
                        delay(100);
                P0=0xff; P3=0xff;
void disp31()                        //狀態(tài)31 逐步逆時(shí)針點(diǎn)亮P2、P1的LED,再逆時(shí)熄滅后,再逆時(shí)針點(diǎn)亮P0、P3的LED,再逆時(shí)熄滅
        for(j=0;j<2;j++)
                for(i=0;i<8;i++)
                        P2=table2[ i];
                        P1=table2[ i];
                        delay(100);
                for(i=0;i<9;i++)
                        P2=table4[ i];
                        P1=table4[ i];
                        delay(100);
                for(i=0;i<8;i++)
                        P0=table3[ i];
                        P3=table2[ i];
                        delay(100);
                for(i=0;i<9;i++)
                        P0=table5[ i];
                        P3=table4[ i];
                        delay(100);
        delay(200);
void disp32()                        //狀態(tài)32 LED自上而下逐步點(diǎn)亮,然后從下往上逐步熄滅
        for(i=0;i<8;i++)
                P0=table3[ i];
                P2=table3[ i];
                delay(100);
        for(i=0;i<8;i++)
                P1=table2[ i];
                P3=table3[ i];
                delay(100);
        for(i=0;i<9;i++)
                P1=table5[ i];
                P3=table4[ i];
                delay(100);
        for(i=0;i<9;i++)
                P0=table4[ i];
                P2=table4[ i];
                delay(100);
void disp33()                        //狀態(tài)33 LED從左往右開始點(diǎn)亮(直到全亮),然后從左右兩邊開始熄滅(直到全部熄滅)
        for(i=0;i<8;i++)
                P0=table2[ i];
                P1=table2[ i];
                delay(100);
        for(i=0;i<8;i++)
                P2=table3[ i];
                P3=table2[ i];
                delay(100);
        delay(500);
        for(i=0;i<9;i++)
                P2=table4[ i];
                P3=table5[ i];
                P1=table4[ i];
                P0=table4[ i];
                delay(100);
        delay(300);
void disp34()                        //狀態(tài)34 LED從左往右開始點(diǎn)亮(直到全亮),然后從中間往左右邊熄滅
        for(i=0;i<8;i++)
                P2=table2[ i];
                P3=table3[ i];
                delay(100);
        for(i=0;i<8;i++)
                P0=table3[ i];
                P1=table3[ i];
                delay(100);
        delay(500);
        for(i=0;i<9;i++)
                P2=table5[ i];
                P3=table4[ i];
                P1=table5[ i];
                P0=table5[ i];
                delay(100);
        delay(300);
void disp35()                        //狀態(tài)35  從P2.7、P1.7開始同時(shí)順時(shí)針旋轉(zhuǎn),直到LED全亮
        for(i=0;i<8;i++)
                P2=table3[ i];
                P1=table3[ i];
                delay(100);
        for(i=0;i<8;i++)
                P3=table3[ i];
                P0=table2[ i];
                delay(100);
void disp36()                        //狀態(tài)36  從P0.7、P3.1開始同時(shí)逆時(shí)針旋轉(zhuǎn),直到LED全亮
        for(i=0;i<8;i++)
                P0=table3[ i];
                P3=table2[ i];
                delay(100);
        for(i=0;i<8;i++)
                P1=table2[ i];
                P2=table2[ i];
                delay(100);
void disp37()                        //狀態(tài)37 2個(gè)LED自上而下移動,并點(diǎn)亮最下2個(gè)LED,然后2個(gè)LED再自下而上回去,同時(shí)4個(gè)LED(上下各2個(gè)LED)再來回移動一次
        for(i=0;i<8;i++)
                P0=table1[ i];
                P2=table1[ i];
                delay(100);
        P0=0xff; P2=0xff;
        for(i=0;i<8;i++)
                P1=table0[ i];
                P3=table1[ i];
                delay(100);
        for(i=0;i<8;i++)
                P1=table7[ i];
                P3=table6[ i];
                delay(100);
        P1=0x7f; P3=0xfe;
        for(i=0;i<8;i++)
                P0=table0[ i];
                P2=table0[ i];
                delay(100);
        for(i=0;i<8;i++)
                P0=table1[ i];
                P2=table1[ i];
                P1=table1[ i];
                P3=table0[ i];
                delay(200);
        for(i=0;i<8;i++)
                P0=table0[ i];
                P1=table0[ i];
                P2=table0[ i];
                P3=table1[ i];
                delay(200);
        P0=0xff;P1=0xff; P2=0xff;P3=0xff;
void disp38()                        //狀態(tài)38 逐步順時(shí)針點(diǎn)亮P2、P1的LED,熄滅后,再順時(shí)針點(diǎn)亮P0、P3的LED
        for(j=0;j<2;j++)
                for(i=0;i<8;i++)
                        P2=table3[ i];
                        P1=table3[ i];
                        delay(100);
                P2=0xff; P1=0xff;
                for(i=0;i<8;i++)
                        P0=table2[ i];                        P3=table3;                        delay(100);                }                P0=0xff; P3=0xff;        }        }void disp39()                        //狀態(tài)39 P1、P3LED(下半部分)一直亮,上半部分LED向外擴(kuò)張亮,然后閃爍3次{        P1=0x00; P3=0x00;        for(i=0;i<8;i++)        {                P0=table3;                P2=table3;                delay(150);        }        for(i=0;i<8;i++)        {                P0=table3;                P2=table3;                delay(300);        }        for(i=0;i<4;i++)        {                P0=~P0; P2=~P2;                delay(300);        }        delay(1000);}void disp40()                        //狀態(tài)40 LED從P3.0、P0.7開始逆時(shí)針同時(shí)熄滅,直到LED全部熄滅{        for(i=0;i<9;i++)        {                P3=table4;                P0=table5;                delay(100);        }        for(i=1;i<9;i++)        {                P2=table4;                P1=table4;                delay(100);        }        delay(300);        }void disp41()                        //狀態(tài)41 LED從P2.7、P1.7開始順時(shí)針同時(shí)熄滅,直到全部熄滅{        for(i=0;i<9;i++)        {                P2=table5;                P1=table5;                delay(100);        }        for(i=1;i<9;i++)        {                P0=table4;                P3=table5;                delay(100);        }        delay(300);               }void main(){                while(1)        {                               disp22();                //裝態(tài)22 2個(gè)LED自上而下移動(循環(huán)5次,且頻率漸快,到最快時(shí)持續(xù)循環(huán)16次,然后循環(huán)5次頻率再逐漸降低)                disp0();                //狀態(tài)0 所有LED閃爍3次                disp1();                //狀態(tài)1 LED順時(shí)針轉(zhuǎn)一圈                disp2();                //狀態(tài)2 LED逆時(shí)針轉(zhuǎn)一圈                disp3();                //狀態(tài)3 4個(gè)LED同時(shí)順時(shí)、逆時(shí)針移動1/4圈                disp4();                //狀態(tài)4  2個(gè)LED同時(shí)順時(shí)針移動半圈                disp5();                //狀態(tài)5  2個(gè)LED同時(shí)逆時(shí)針移動半圈                disp6();                //狀態(tài)6 LED自上而下逐漸點(diǎn)亮(一半點(diǎn)亮一半不亮)                disp7();                //狀態(tài)7 LED自下而上逐漸點(diǎn)亮(直到全部點(diǎn)亮)                disp0();                //狀態(tài)0 所有LED閃爍3次                disp8();                //狀態(tài)8 間斷8格的4個(gè)LED亮并逆時(shí)針旋轉(zhuǎn)                disp9();                //狀態(tài)9 間斷8格的4個(gè)LED亮,然后逆時(shí)針逐漸點(diǎn)亮(直到全部點(diǎn)亮)                disp10();                //狀態(tài)10 從LED全部亮到全不亮(間斷8格的4個(gè)LED開始逆時(shí)針熄滅)                disp11();                //狀態(tài)11 間斷8格的4個(gè)LED亮并順時(shí)針旋轉(zhuǎn)                disp12();                //間斷8格的4個(gè)LED亮,然后順時(shí)針逐漸點(diǎn)亮(直到全部點(diǎn)亮)                disp13();                //狀態(tài)13 從LED全部亮到全不亮(間斷8格的4個(gè)LED開始順時(shí)針熄滅)                disp14();                //狀態(tài)14 從LED不亮到全亮(從P0.0、P1.0、P2.0、P3.7開始逐布點(diǎn)亮)                   disp15();                //狀態(tài)15 從LED全亮到全不亮(從P0.7、P1.7、P2.7、P3.0開始逐步熄滅)                disp16();                //狀態(tài)16 LED燈交替閃爍(頻率有慢變快)                disp17();                //狀態(tài)17 LED從P0.7開始逆時(shí)針逐步點(diǎn)亮,并且速度會逐步提高                disp18();                //狀態(tài)18 LED從P0.7開始逆時(shí)針逐步點(diǎn)亮(每亮8位后就熄滅)                disp19();                //狀態(tài)19 LED從P2.7開始順時(shí)針逐步點(diǎn)亮,(循環(huán)2次)并且速度會逐步提高                disp20();                //狀態(tài)20 LED從P2.7開始順時(shí)針逐步點(diǎn)亮(每亮8位后就熄滅)                disp21();                //狀態(tài)21 2個(gè)LED開始上下移動半圈                disp22();                //裝態(tài)22 2個(gè)LED自上而下移動(循環(huán)5次,且頻率漸快,到最快時(shí)持續(xù)循環(huán)16次,然后循環(huán)5次頻率再逐漸降低                disp23();                //狀態(tài)23 LED上下交替閃爍                disp39();                //狀態(tài)39 P1、P3LED(下半部分)一直亮,上半部分LED向外擴(kuò)張亮,然后閃爍3次                disp24();                //狀態(tài)24 LED左右交替閃爍                disp25();                //狀態(tài)25 LED交替閃爍                  disp8();                //狀態(tài)8 間斷8格的4個(gè)LED亮并逆時(shí)針旋轉(zhuǎn)                disp9();                //狀態(tài)9 間斷8格的4個(gè)LED亮,然后逆時(shí)針逐漸點(diǎn)亮(直到全部點(diǎn)亮)                disp10();                //狀態(tài)10 從LED全部亮到全不亮(間斷8格的4個(gè)LED開始逆時(shí)針熄滅)                disp26();                //狀態(tài)26 2個(gè)LED開始上下移動半圈(LED不亮流水)                disp27();                //狀態(tài)27 逐步順時(shí)針點(diǎn)亮P2、P1的LED,熄滅后,再順時(shí)針點(diǎn)亮P0、P3的LED                disp28();                //狀態(tài)28 P1、P2和P0、P3交替閃爍                disp38();                //狀態(tài)38 逐步順時(shí)針點(diǎn)亮P2、P1的LED,熄滅后,再順時(shí)針點(diǎn)亮P0、P3的LED                disp29();                //狀態(tài)29 逐步順時(shí)針點(diǎn)亮P2、P1的LED,再順時(shí)熄滅后,再順時(shí)針點(diǎn)亮P0、P3的LED,再順時(shí)熄滅                disp30();                //狀態(tài)30 逐步逆時(shí)針點(diǎn)亮P2、P1的LED,熄滅后,再逆時(shí)針點(diǎn)亮P0、P3的LED                disp31();                //狀態(tài)31 逐步逆時(shí)針點(diǎn)亮P2、P1的LED,再逆時(shí)熄滅后,再逆時(shí)針點(diǎn)亮P0、P3的LED,再逆時(shí)熄滅                disp32();                //狀態(tài)32 LED自上而下逐步點(diǎn)亮,然后從下往上逐步熄滅                disp33();                //狀態(tài)33 LED從左往右開始點(diǎn)亮(直到全亮),然后從左右兩邊開始熄滅(直到全部熄滅)                disp37();                //狀態(tài)37 2個(gè)LED自上而下移動,并點(diǎn)亮最下2個(gè)LED,然后2個(gè)LED再自下而上回去,同時(shí)4個(gè)LED(上下各2個(gè)LED)再來回移動一次                disp36();                //狀態(tài)36  從P0.7、P3.0開始同時(shí)逆時(shí)針旋轉(zhuǎn),直到LED全亮                disp40();                //狀態(tài)40 LED從P3.0、P0.7開始逆時(shí)針同時(shí)熄滅,直到LED全部熄滅                disp35();                //狀態(tài)35  從P2.7、P1.7開始同時(shí)順時(shí)針旋轉(zhuǎn),直到LED全亮                disp41();                //狀態(tài)41 LED從P2.7、P1.7開始順時(shí)針同時(shí)熄滅,直到全部熄滅                disp34();                //狀態(tài)34 LED從左往右開始點(diǎn)亮(直到全亮),然后從中間往左右邊熄滅                disp28();                //狀態(tài)28 P1、P2和P0、P3交替閃爍        }}
xx.rar
939.77 KB, 下載次數(shù): 21, 下載積分: 黑幣 -5
admin + 50 共享資料的黑幣獎勵(lì)!
