查看: 1693|回復(fù): 0
51單片超聲波測(cè)距程序
ID:729916 發(fā)表于 2021-4-4 20:17 | 顯示全部樓層 |閱讀模式
超聲波測(cè)距 + 串口發(fā)送距離
#include<reg51.h>
#include<intrins.h>
sbit trig=P1^7;
sbit echo=P3^2;
float tA,dis;
uint distance,timeh,timel;
void delay(uint z)
    uint x,y;
    for(x=z;x>0;x--)
       for(y=1100;y>0;y--);
void delay20us()
    _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
void initT1_SCI()
   SM0 = 0; //
   SM1 = 1; //10位異步收發(fā),波特率可變
   TMOD = 0x21;
   TH1 = 0xfd;
   TL1 = 0xfd;
   TR1 = 1;
void Trig()
    trig = 0;
    echo = 0;
    TH0 = 0;
    TL0 = 0;
    trig = 1;
    delay20us();
    trig = 0;
    while(echo == 0);
    EX0 = 1;                    //外部中斷0允許
    ET0 = 1;                    //定時(shí)器0中斷允許
    TR0 = 1;                    //定時(shí)器0運(yùn)行控制位
    delay(60);
void putChar(uchar c)
    SBUF = c;
    while( !TI ); TI = 0;
void putStr(uchar str[], uint n)
    while( n-- )
        putChar( str[n] );
int main()
    initT1_SCI();
    EA = 1;
        Trig();
    return 0;
void T0_time() interrupt 1
   TH0 = 0;
   TL0 = 0;
void ex0()interrupt 0
   uchar num[2];
   timeh = TH0;
   timel = TL0;
   tA = (timeh * 256 + timel) * 1.09;
   dis = tA * 0.17;
   distance = (int)dis;
   num[1] = distance / 256;  num[0] = distance % 256;
   putStr(num, 2);
   TH0 = 0;
   TL0 = 0;
   TR0 = 0;
   EX0 = 0; //關(guān)閉外部中斷0
   ET0 = 0; //關(guān)閉定時(shí)器1中斷
Correct
#include<reg51.h>
#include<intrins.h>
#include "6x8.h"
#include "LQ12864.h"
sbit trig=P2^0;
sbit echo=P3^2;
uint succeed;
float tA,dis;
uint flagCG = 0;
uint flag600 = 0, flag50 = 1;
void delay(uint z)
    uint x,y;
        for(x=z;x>0;x--)
           for(y=110;y>0;y--);
void delay20us()
void initT1_SCI()
   TH0 = 0;
   TL0 = 0;
   TR0 = 0;
   SM0 = 0;        //
   TMOD = 0x21;
   TH1 = 0xfd;
   TL1 = 0xfd;
   TR1 = 1;
        SBUF = c;
        while( n-- )
                putChar( str[n] );
void display()
   unsigned char SPEED[4] = {0,0,0,1};
   SPEED[2]=distance/100;                 ready(6,0,SPEED[2]);
   SPEED[1]=(distance%100)/10;         ready(12,0,SPEED[1]);
   SPEED[0]=distance%10;                ready(18,0,SPEED[0]);
   putStr(SPEED, 3);
void Trig()
                trig = 0;
            echo = 0;
                succeed = 0;
                TH0 = 0;
                TL0 = 0;
                trig = 1;
                delay20us();
                trig = 0;
                while(echo == 0);
                EX0 = 1;                                        //外部中斷0允許
                delay(60);
    LCD_Init();
        initT1_SCI();
        EA = 1;
                Trig();
                if(succeed)
                        LCD_Cler_6x8(0,0,4);
                        display();
                delay(100);
   TH0 = 0;
   TL0 = 0;
   succeed = 0;
   timeh = TH0;
   timel = TL0;
   dis = tA * 0.17;
   succeed = 1;
   TH0 = 0;
   TL0 = 0;
   TR0 = 0;
