#include<reg52.h> //包含頭文件,一般情況不需要改動,頭文件包含特殊功能寄存器的定義
#include<intrins.h>
sbit RS = P1^0; //定義端口
sbit RW = P1^1;
sbit EN = P2^5;
sbit DU = P2^0;
sbit WE = P2^1;
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
#define DataPort P0
void cmg88()//關(guān)數(shù)碼管,點陣函數(shù)
DU=1;
P0=0X00;
DU=0;
延遲函數(shù)
void delay(unsigned int xms)
unsigned int i,j; 毫秒
for(i=xms;i>0;i--)
for(j=114;j>0;j--);
判忙函數(shù)
bit LCD_Check_Busy(void)
DataPort= 0xFF;
RS_CLR;
RW_SET;
EN_CLR;
_nop_();
EN_SET;
return (bit)(DataPort & 0x80);
寫入命令函數(shù)
void LCD_Write_Com(unsigned char com)
while(LCD_Check_Busy()); //忙則等待
RS_CLR;
RW_CLR;
EN_SET;
DataPort= com;
_nop_();
EN_CLR;
寫入數(shù)據(jù)函數(shù)
void LCD_Write_Data(unsigned char Data)
RS_SET;
RW_CLR;
EN_SET;
DataPort= Data;
_nop_();
EN_CLR;
清屏函數(shù)
void LCD_Clear(void)
LCD_Write_Com(0x01);
DelayMs(5);
寫入字符串函數(shù)
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
LCD_Write_Com(0x80 + x); //表示第一行
LCD_Write_Com(0xC0 + x); //表示第二行
while (*s)
LCD_Write_Data( *s);
s ++;
寫入字符函數(shù)
void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)
if (y == 0)
LCD_Write_Data( Data);
初始化函數(shù)
void LCD_Init(void)
LCD_Write_Com(0x38); /*顯示模式設(shè)置*/
DelayMs(5);
DelayMs(5);
DelayMs(5);
LCD_Write_Com(0x08); /*顯示關(guān)閉*/
LCD_Write_Com(0x01); /*顯示清屏*/
LCD_Write_Com(0x06); /*顯示光標移動設(shè)置*/
DelayMs(5);
LCD_Write_Com(0x0C); /*顯示開及光標設(shè)置*/
主函數(shù)
void main(void)
cmg88();//關(guān)數(shù)碼管,點陣函數(shù)
LCD_Init();
LCD_Clear();//清屏
while (1)
LCD_Write_Char(1,0,'-');
LCD_Write_Char(2,0,'-');
LCD_Write_Char(3,0,'-');
LCD_Write_Char(4,0,'-');
LCD_Write_Char(5,0,'-');
LCD_Write_Char(6,0,'>');
LCD_Write_Char(7,0,'3');
LCD_Write_Char(8,0,'<');
LCD_Write_Char(9,0,'-');
LCD_Write_Char(10,0,'-');
LCD_Write_Char(11,0,'-');
LCD_Write_Char(12,0,'-');
LCD_Write_Char(13,0,'-');
delay(2000);
LCD_Write_Char(7,0,'2');
delay(2000);
LCD_Write_Char(7,0,'1');
delay(2000);
LCD_Write_String(1,1,"6666666666");
while(1);
