主控采用HC32L110低功耗單片機(jī),射頻芯片PAN3020,SPI接口
2021-4-9 18:18 上傳
2021-4-9 18:18 上傳
2021-4-9 18:17 上傳
// * @file RF.c
// * @author Shi Zheng
// * @version V1.1
// * @date 24/4/2015
// * @brief pan3020 communication interface
// * @modify user: linjianan
// * @modify date: 28/11/2015
#include "stdio.h"
//#include "RFAPI.H"
#include "RF.H"
#include "ddl.h"
#include "SRWF_1E80.h"
extern uint8_t lpUartSend(uint8_t *pBuf,uint8_t len);
const uint8_t TX_ADDRESS_DEF[5] = {0xCC,0xCC,0xCC,0xCC,0xCC}; //RF 地址:接收端和發(fā)送端需一致
//unsigned short Payload_Count = 0;
uint16_t Payload_Count = 0;
uint8_t fb=0,fc=0;
extern void RF_CalVco( uint8_t * ptr_Dem_cal1);
extern uint8_t Dem_cal1_data[];
extern uint8_t RF_cal1_data[];
uint8_t Channel_Index=10;
uint8_t const CHANNEL_TABLE[] = {16,24,32,40,48,56,64,72,80,88};
uint8_t temp = 0;
uint8_t RFmachine = 0;
// SPI_init
// init spi pin and IRQ CE input/out mode
void SPI_init(void)
Gpio_InitIO(CSN_PORT, CSN_PIN, GpioDirOut);
Gpio_InitIO(MISO_PORT, MISO_PIN, GpioDirIn);
Gpio_InitIO(MOSI_PORT, MOSI_PIN, GpioDirOut);
Gpio_InitIO(SCK_PORT, SCK_PIN, GpioDirOut);
Gpio_InitIO(SPIIRQ_PORT, SPIIRQ_PIN,GpioDirIn);
Gpio_InitIO(SPICE_PORT, SPICE_PIN, GpioDirOut);
// SPI_RW
// SPI Write/Read Data
// SPI寫入一個(gè)BYTE的同時(shí),讀出一個(gè)BYTE返回
uint8_t SPI_RW( uint8_t R_REG)
uint8_t i;
for(i = 0; i < 8; i++)
SCK_LOW;
if(R_REG & 0x80)
MOSI_HIGH;
MOSI_LOW;
R_REG = R_REG << 1;
SCK_HIGH;
if( MISO_STATUS )
R_REG = R_REG | 0x01;
SCK_LOW;
return R_REG;
// RF_WriteReg
// Write Data(1 Byte Address ,1 byte data)
void RF_WriteReg( uint8_t reg, uint8_t wdata)
CSN_LOW;
SPI_RW(reg);
SPI_RW(wdata);
CSN_HIGH;
// RF_ReadReg
// Read Data(1 Byte Address ,1 byte data return)
uint8_t ucRF_ReadReg( uint8_t reg)
uint8_t tmp;
CSN_LOW;
SPI_RW(reg);
tmp = SPI_RW(0);
CSN_HIGH;
return tmp;
// RF_WriteBuf
// Write Buffer
void RF_WriteBuf( uint8_t reg, uint8_t *pBuf, uint8_t length)
uint8_t j;
CSN_LOW;
j = 0;
SPI_RW(reg);
for(j = 0;j < length; j++)
SPI_RW(pBuf[j]);
j = 0;
CSN_HIGH;
// RF_ReadBuf
// Read Data(1 Byte Address ,length byte data read)
void RF_ReadBuf( uint8_t reg, unsigned char *pBuf, uint8_t length)
uint8_t byte_ctr;
CSN_LOW;
SPI_RW(reg);
for(byte_ctr=0;byte_ctr<length;byte_ctr++)
pBuf[byte_ctr] = SPI_RW(0);
CSN_HIGH;
void RF_PwrDwnMode(void)
//關(guān)閉RF,PWR_UP 0, CE 0
CE_LOW;
//1111 1101
RF_WriteReg(W_REGISTER+CONFIG,ucRF_ReadReg(CONFIG)&0xFD);
delay10us(1);
RFmachine = RFIDLEMODE;
void RF_STB1Mode(void)
//RF STB1模式,PWR_UP 1, CE 0
CE_LOW;
//0000 0010
RF_WriteReg(W_REGISTER+CONFIG,ucRF_ReadReg(CONFIG)|0x02);
delay10us(1);
void RF_STB2Mode(void)
//RF STB2模式,PWR_UP 1, CE 1
CE_HIGH;
//0000 0010
delay10us(1);
// RF_TxMode
// Set RF into TX mode
void RF_TxMode(void)
uint8_t i;
char tmpstr[64];
CE_LOW;
// 將RF設(shè)置成TX模式,允許發(fā)送中斷
RF_WriteReg(W_REGISTER + CONFIG, 0X0E);
delay10us(1);
RFmachine = RFTXMODE;
RF_TR_HIGH;
// RF_RxMode
// 將RF設(shè)置成RX模式,準(zhǔn)備接收數(shù)據(jù)
void RF_RxMode(void)
char tmpstr[64];
uint8_t RF_cal3_temp[] = {0x01,0x08,0xD4,0x02,0x64};
uint8_t RF_cal3_temp1[] = {0x01,0x08,0xD4,0x02,0x66};
CE_LOW;
RF_WriteReg(W_REGISTER + CONFIG, 0X0F ); // 將RF設(shè)置成RX模式
delay1ms(20);
CE_HIGH; // Set CE pin high
delay10us(50); //keep ce high at least 150us
RF_WriteBuf(W_REGISTER + RF_CAL3, RF_cal3_temp, sizeof(RF_cal3_temp));
RF_WriteBuf(W_REGISTER + RF_CAL3, RF_cal3_temp1, sizeof(RF_cal3_temp1));
delay1ms(2);
RFmachine = RFRXMODE;
RF_TR_LOW;
// sprintf(tmpstr,"[RF Rx] sta %02X\r\n",ucRF_ReadReg(STATUS));
// lpUartSend(tmpstr,strlen(tmpstr));
// lpUartSend("[RF Rx]\r\n",strlen("[RF Rx]\r\n"));
// RF_GetStatus
// read RF IRQ status,3bits return
uint8_t ucRF_GetStatus(void)
return ucRF_ReadReg(STATUS)&0x70; //讀取RF的狀態(tài)
// RF_ClearStatus
// clear RF IRQ
void RF_ClearStatus(void)
RF_WriteReg(W_REGISTER + STATUS,0x70); //清除RF的狀態(tài)
// RF_ClearFIFO
// clear RF TX/RX FIFO
void RF_ClearFIFO(void)
RF_WriteReg(FLUSH_TX, 0); //清除RF 的 TX FIFO
RF_WriteReg(FLUSH_RX, 0); //清除RF 的 RX FIFO
// RF_SetPower
// in: RF_cal1_data
// in: power ndbm ,define by rf.h
void RF_SetPower( uint8_t * p,uint8_t power)
switch (power)
case RF18DBM :
*(p+1) &= ~0xfe;//8-15
*(p+1) |= 0xfe;
*(p+2) &= ~0x07;//16-23
*(p+2) |= 0x07;
RF_WriteBuf(W_REGISTER + RF_CAL1, p, 5);
break;
case RF14DBM:
*(p+1) &= ~0xfe;
*(p+1) |= 0xf8;
*(p+2) &= ~0x07;
*(p+2) |= 0x01;
break;
case RF9DBM:
*(p+1) &= ~0xfe;
*(p+1) |= 0xf8;
*(p+2) &= ~0x07;
*(p+2) |= 0x00;
break;
case RF1DBM:
*(p+1) &= ~0xfe;
*(p+1) |= 0x60;
*(p+2) &= ~0x07;
*(p+2) |= 0x00;
break;
default:
break;
//in Fb[5:0], FC[8:1]
// return none
//315 fre = 1/6*8000000*(200+fb+fc/400)hz
//433 fre = 1/4*8000000*(200+fb+fc/400)hz=400Mhz+2fbMhz+50fckHz
//868 915 feq = 1/2*8000000*(200+fb+fc/400)hz=800Mhz+4fbMhz+100kHz
// for example fre= 434.1khz ,Fb=0x11 Fc=0x01. default fc[0]=0,only set fc[8:1](reg5) .
void RF_SetChannel(uint8_t bb,uint8_t cc )
// uint8_t RFSetup_temp = 0;
// Fb &= 0x3f;
// RFSetup_temp = ucRF_ReadReg(RF_SETUP)&0xc0;
// RFSetup_temp |= Fb;
RF_WriteReg(W_REGISTER+RF_SETUP,bb|DATA_RATE);
RF_WriteReg(W_REGISTER+RF_CH,cc);
// 發(fā)送數(shù)據(jù)
// 參數(shù):
// 1. ucTXPayload:需要發(fā)送的數(shù)據(jù)首地址
// 2. length: 需要發(fā)送的數(shù)據(jù)長度
void RF_Tx_TransmintData( uint8_t *ucTXPayload, uint8_t length)
if(!ucRF_GetStatus()) // rf 處于空閑狀態(tài)才發(fā)送數(shù)據(jù)
RF_WriteBuf(W_TX_PAYLOAD, ucTXPayload, length); //write data to txfifo
CE_HIGH; //rf entery tx mode start send data
delay10us(15); //keep ce high at least 150us
RF_WriteBuf(W_REGISTER + RF_CAL3, RF_cal3_temp, sizeof(RF_cal3_temp)); // 切換時(shí)鐘
CE_LOW;
//發(fā)送結(jié)果
// 參數(shù):只在增強(qiáng)型模式下,使能ack帶payload有效
// 1. ucAckPayload:ackpayload的首地址
// 2. length:ackpayload 的長度
#include "stdio.h"
#include "stdlib.h"
uint8_t RF_Tx_CheckResult(uint8_t *ucAckPayload, uint8_t length)
uint8_t rtnTxResult;
sMacHeader_t tmpSyncHeader;
switch(ucRF_GetStatus())
case TX_DS_FLAG: // 普通型發(fā)送完成 或 增強(qiáng)型發(fā)送成功
Payload_Count++; // 增強(qiáng)型模式,累計(jì)ack次數(shù)
rtnTxResult = TX_DS_FLAG;
RF_ClearFIFO();
RF_ClearStatus ();
break;
case RX_TX_FLAG: //增強(qiáng)型發(fā)送成功且收到payload
RF_ReadBuf(R_RX_PAYLOAD,ucAckPayload, length);
Payload_Count++;
rtnTxResult = RX_TX_FLAG;
// //將PAN3020接收到的數(shù)據(jù)通過串口轉(zhuǎn)發(fā)
// lpUartSend(ucAckPayload, 16);
RF_ClearFIFO();
RF_ClearStatus ();
break;
case MAX_RT_FLAG: // 增強(qiáng)型發(fā)送超時(shí)失敗
rtnTxResult = MAX_RT_FLAG;
RF_ClearFIFO();
RF_ClearStatus ();
break;
default:
rtnTxResult = TX_NULL_FLAG;
break;
return rtnTxResult;
// ucRF_DumpRxData
// 讀出接收到的數(shù)據(jù):
// 參數(shù):
// 1. ucPayload:存儲(chǔ)讀取到的數(shù)據(jù)的Buffer
// 2. length: 讀取的數(shù)據(jù)長度
// Return:
// 1. 0: 沒有接收到數(shù)據(jù)
// 2. 1: 讀取接收到的數(shù)據(jù)成功
// note: Only use in Rx Mode
// length 通常等于 PAYLOAD_WIDTH
uint8_t ucRF_DumpRxData( uint8_t *ucPayload, uint8_t length)
if(ucRF_GetStatus()==0x40)
// RF_ReadBuf(R_RX_PAYLOAD, ucPayload, length);
return 1;
return 0;
// Vco_Calibration
void RF_CalVco( uint8_t * Demod_Cal)
uint8_t i,j,h;
uint8_t Dem_cal2_data1[] = {0x0B,0xE7,0x00,0x03}; //Dataout_Sel置1
uint8_t RF_cal3_data1[] = {0x01,0x08,0xD4,0x02,0x76}; //Vco_Calibration EN
uint8_t RF_cal3_data2[] = {0x01,0x18,0xD4,0x02,0x76}; //觸發(fā)Vco_Calibration_SPI_Triger
CE_LOW;
RF_WriteReg(W_REGISTER + CONFIG, 0X0F ); //配置為接收模式
CE_HIGH;
RF_WriteBuf(W_REGISTER + DEM_CAL2, Dem_cal2_data1, sizeof(Dem_cal2_data1));
RF_WriteBuf(W_REGISTER + RF_CAL3, RF_cal3_data1, sizeof(RF_cal3_data1));
RF_WriteBuf(W_REGISTER + RF_CAL3, RF_cal3_data2, sizeof(RF_cal3_data2));
i=ucRF_ReadReg(RPD);
j=ucRF_ReadReg(FIFO_STATUS);
i >>= 2;
i &= 0x30;
j &= 0x0C;
h = i|j;
Demod_Cal[1] &= 0xC3;
Demod_Cal[1] |= h;
// 以下部分與RF通信相關(guān),不建議修改
// pan3020_Initial
// Initial RF
//uint16_t rfFreq; ///<ISM 頻率配置
//uint16_t rfPower; ///
#if 1
uint8_t firstpwrup = 0;
void RF_Init(uint16_t rfPower)
uint8_t feature =0x00;
uint8_t BB_cal_data[] = {0x3f,0xFC,0x1F,0x1F,0x04};
uint8_t RF_cal3_data[] = {0x01,0x08,0xD4,0x02,0x66};
uint8_t Dem_cal2_data[] = {0x0B,0xE7,0x00,0x01}; //如果使能動(dòng)態(tài)payload,需要配置為 uint8_t Dem_cal2_data[] = {0x0B,0xE7,0x00,0x00};
uint8_t RF_cal2_data[] = {0xC8,0x1E,0x68,0x39,0xF6};
// 433MHz
#if((DATA_RATE == DR_400K) && (BAND == B433MHz))
uint8_t Dem_cal1_data[] = {0x01,0x8e,0x48,0x4c,0x80};
uint8_t RF_cal1_data[] = {0xC4,0xFF,0xFF,0xDF,0xDB};
#elif((DATA_RATE==DR_40K) && (BAND==B433MHz))
uint8_t Dem_cal1_data[] = {0x01,0x4D,0x48,0x34,0x8C};
uint8_t RF_cal1_data[] = {0xC4,0xFF,0xFF,0x5F,0xD8};
#elif((DATA_RATE==DR_80K) && (BAND==B433MHz))
uint8_t Dem_cal1_data[] = {0x01,0x8D,0x48,0x4C,0x8C};
uint8_t RF_cal1_data[] = {0xC4,0xFF,0xFF,0xDF,0xD8};
#elif((DATA_RATE==DR_200K) && (BAND==B433MHz))
uint8_t Dem_cal1_data[] = {0x01,0x8C,0x48,0x4C,0x84};
uint8_t RF_cal1_data[] = {0xC4,0xFF,0xFF,0xDF,0xD9};
// 315MHz
#elif((DATA_RATE==DR_400K) && (BAND == B315MHz))
uint8_t Dem_cal1_data[] = {0x01,0xea,0x48,0x74,0x80};
uint8_t RF_cal1_data[] = {0xC5,0xFF,0xFF,0xDF,0xDB};
#elif((DATA_RATE==DR_40K) && (BAND==B315MHz))
uint8_t Dem_cal1_data[] = {0x01,0x69,0x48,0x44,0x8C};
uint8_t RF_cal1_data[] = {0xC5,0xFF,0xFF,0x5F,0xD8};
#elif((DATA_RATE==DR_80K) && (BAND==B315MHz))
uint8_t Dem_cal1_data[] = {0x01,0xe9,0x48,0x74,0x8C};
uint8_t RF_cal1_data[] = {0xC5,0xFF,0xFF,0xDF,0xD8};
#elif((DATA_RATE==DR_200K) && (BAND==B315MHz))
uint8_t Dem_cal1_data[] = {0x01,0xE8,0x48,0x74,0x84};
uint8_t RF_cal1_data[] = {0xC5,0xFF,0xFF,0xDF,0xD9};
// 868MHz
#elif((DATA_RATE==DR_400K) && (BAND == B868MHz))
uint8_t Dem_cal1_data[] = {0x01,0x88,0x48,0x4c,0x94};
uint8_t RF_cal1_data[] = {0xd0,0xFF,0xFF,0xDF,0xDB};
#elif((DATA_RATE==DR_40K) && (BAND==B868MHz))
uint8_t Dem_cal1_data[] = {0x01,0x09,0x80,0x19,0x5C};
uint8_t RF_cal1_data[] = {0xd0,0xFF,0xFF,0x5F,0xD8};
#elif((DATA_RATE==DR_80K) && (BAND==B868MHz))
uint8_t Dem_cal1_data[] = {0x01,0x09,0x00,0x21,0x5C};
uint8_t RF_cal1_data[] = {0xD0,0xFF,0xFF,0xDF,0xD8};
#elif((DATA_RATE==DR_200K) && (BAND==B868MHz))
uint8_t Dem_cal1_data[] = {0x01,0x89,0x48,0x4c,0x9c};
uint8_t RF_cal1_data[] = {0xd0,0xFF,0xFF,0xDF,0xD9};
// 915MHz
#elif((DATA_RATE==DR_400K) && (BAND == B915MHz))
uint8_t Dem_cal1_data[] = {0x01,0x9c,0x48,0x54,0x84};
#elif((DATA_RATE==DR_40K) && (BAND==B915MHz))
uint8_t Dem_cal1_data[] = {0x01,0x1d,0x48,0x34,0x8C};
#elif((DATA_RATE==DR_80K) && (BAND==B915MHz))
uint8_t Dem_cal1_data[] = {0x01,0x1d,0x00,0x44,0x7C};
#elif((DATA_RATE==DR_200K) && (BAND==B915MHz))
uint8_t Dem_cal1_data[] = {0x01,0x9d,0x48,0x54,0x8c};
uint8_t RF_cal1_data[] = {0xD0,0xFF,0xFF,0xDF,0xD9};
#endif
#if(BAND == B433MHz)
fb = 0x12;
fc = 0x20;
#elif(BAND == B315MHz)
fb = 0x25;
fc = 0x20;
#elif(BAND == B868MHz)
fb = 0x11;
fc = 0x20;
#elif(BAND == B915MHz)
fb = 0x1c;
fc = 0x20;
// fb = 0x11;
// fc = 0x20;
#endif
SPI_init();
delay1ms(10);
#if(CE_USE_SPI==1)
feature |=0x20;
#endif
if(PAYLOAD_WIDTH >32)
feature |= 0x18; // fifo 64 byte
if ( firstpwrup == 0 )
firstpwrup = 1;
//以下三句,若每次初始化清零,增強(qiáng)模式下,count幀計(jì)數(shù)器永遠(yuǎn)為0.
RF_WriteReg(FLUSH_TX, 0); // CLEAR TXFIFO
RF_WriteReg(FLUSH_RX, 0); // CLEAR RXFIFO
RF_WriteReg(W_REGISTER + STATUS, 0x70); // CLEAR STATUS
RF_WriteReg(W_REGISTER + EN_RXADDR, 0x01); // Enable Pipe0
RF_WriteReg(W_REGISTER + SETUP_AW, 0x03); // address witdth is 5 bytes
RF_WriteReg(W_REGISTER + RX_PW_P0, PAYLOAD_WIDTH); // 64bytes
RF_WriteBuf(W_REGISTER + TX_ADDR, ( uint8_t*)TX_ADDRESS_DEF, sizeof(TX_ADDRESS_DEF)); // Writes TX_Address to pan3020
RF_WriteBuf(W_REGISTER + RX_ADDR_P0,( uint8_t*)TX_ADDRESS_DEF, sizeof(TX_ADDRESS_DEF)); // RX_Addr0 same as TX_Adr for Auto.Ack
RF_WriteBuf(W_REGISTER + BB_CAL, BB_cal_data, sizeof(BB_cal_data));
RF_WriteBuf(W_REGISTER + DEM_CAL1, Dem_cal1_data, sizeof(Dem_cal1_data));
RF_WriteBuf(W_REGISTER + DEM_CAL2, Dem_cal2_data, sizeof(Dem_cal2_data));
RF_WriteBuf(W_REGISTER + RF_CAL1, RF_cal1_data, sizeof(RF_cal1_data));
RF_WriteBuf(W_REGISTER + RF_CAL2, RF_cal2_data, sizeof(RF_cal2_data));
RF_WriteBuf(W_REGISTER + RF_CAL3, RF_cal3_data, sizeof(RF_cal3_data));
#if(TRANSMIT_TYPE == TRANS_ENHANCE_MODE)
//自動(dòng)傳輸設(shè)置 7:4, 0000 250us, 1111,9530us; 3:0, 0000 不帶自動(dòng)重傳 0011 3次重傳, 1111 15次重傳
RF_WriteReg(W_REGISTER + SETUP_RETR,0x03); //傳輸延遲250us, 3 retrans...
RF_WriteReg(W_REGISTER + EN_AA, 0x01); // Enable Auto.Ack:Pipe0
RF_WriteReg(ACTIVATE, 0x73);
#if(1== EN_DYNPLOAD)
feature |= 0x04; // ENDYNPD
RF_WriteReg(W_REGISTER +DYNPD, 0x01);
#endif
#if(1==EN_ACK_PAYLOAD) // en ack+payload
feature |= 0x02;
#endif
#elif(TRANSMIT_TYPE == TRANS_BURST_MODE)
RF_WriteReg(W_REGISTER + SETUP_RETR,0x00); // Disable retrans...
RF_WriteReg(W_REGISTER + EN_AA, 0x00); // Disable AutoAck
#endif
RF_WriteReg(W_REGISTER +FEATURE, feature);
RF_WriteReg(W_REGISTER + RF_SETUP, DATA_RATE|fb); //set datarate
RF_WriteReg(W_REGISTER + RF_CH, fc);
//RF_SetPower(RF_cal1_data,RF_POWER); // set power
RF_SetPower(RF_cal1_data,rfPower); // set power
// RF_SetChannel(fb,fc); // set fre
/* RF_CalVco(Dem_cal1_data); //Vco_Calibration
RF_WriteBuf(W_REGISTER + RF_CAL3, RF_cal3_data, sizeof(RF_cal3_data)); */
#endif
// 進(jìn)入載波模式
void RF_Carrier(uint8_t Fb,uint8_t Fc)
uint8_t BB_cal_data[] = {0x09,0x04,0x07,0x1F,0x05};
uint8_t Dem_cal1_data[] = {0xE1,0x8e,0x48,0x4c,0x80};
uint8_t Dem_cal2_data[] = {0x0B,0xE7,0x00,0x05};
SPI_init();
CE_HIGH;
delay10us(500);
RF_WriteReg(W_REGISTER + CONFIG, 0x0E);
RF_WriteReg(W_REGISTER + RF_SETUP, 0xd2);
RF_SetChannel(fb,CHANNEL_TABLE[Channel_Index]);
delay10us(500);
delay10us(500);
CE_LOW;
/***************************************end of file ************************************/
全部代碼51hei下載地址:
SNWL433 - change.7z
(169.14 KB, 下載次數(shù): 50)
2021-4-10 02:20 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
