查看: 2004|回復(fù): 3
單片機(jī)+LCD12864串行顯示魚缸水質(zhì),但是超聲波水位的數(shù)值一直顯示不出,是什么問題求解
ID:652483 發(fā)表于 2021-4-12 18:12 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
主程序
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #include "LCD12864.h"
  4. #include "timer1.h"
  5. #include "ADC0832.h"
  6. #include "DS18B20.h"
  7. #include "eepom52.h"
  8. #include "HC_SR04.h"
  9. sbit beep = P2^0;
  10. sbit setKey = P3^3;
  11. sbit addKey = P3^4;
  12. sbit subKey = P3^5;
  13. float dataV[4]= {0};
  14. unsigned char dataTH[8]={110,30, 99, 30, 8,2, 45, 15};
  15. unsigned char lcd[8] = {0};
  16. void alarm();
  17. void delay(unsigned int i){
  18.     while(i--);
  19. }
  20. float pre_ph_v, phv;
  21. void setKeyDeal();
  22. void addKeyDeal();
  23. void subKeyDeal();
  24. //³õʼ»¯eeprom
  25. void init_eeprom(){
  26.     unsigned char is_first_init =  byte_read(0x2020);
  27.     if(is_first_init == 1){
  28.         dataTH[0] = byte_read(0x2000);
  29.         dataTH[1] = byte_read(0x2001);
  30.         dataTH[2] = byte_read(0x2002);
  31.         dataTH[3] = byte_read(0x2003);
  32.         dataTH[4] = byte_read(0x2004);
  33.         dataTH[5] = byte_read(0x2005);
  34.         dataTH[6] = byte_read(0x2006);
  35.         dataTH[7] = byte_read(0x2007);
  36.     }else{
  37.             SectorErase(0x2000);
  38.             byte_write(0x2000, dataTH[0]);
  39.             byte_write(0x2001, dataTH[1]);
  40.             byte_write(0x2002, dataTH[2]);
  41.             byte_write(0x2003, dataTH[3]);
  42.             byte_write(0x2004, dataTH[4]);
  43.             byte_write(0x2005, dataTH[5]);
  44.             byte_write(0x2006, dataTH[6]);
  45.             byte_write(0x2007, dataTH[7]);
  46.             byte_write(0x2020, 1);
  47.     }
  48. }
  49. //¸üÐÂeeprom´æ´¢µÄÊý¾Ý
  50. void update_eeprom(){
  51.             SectorErase(0x2000);
  52.             byte_write(0x2000, dataTH[0]);
  53.             byte_write(0x2001, dataTH[1]);
  54.             byte_write(0x2002, dataTH[2]);
  55.             byte_write(0x2003, dataTH[3]);
  56.             byte_write(0x2004, dataTH[4]);
  57.             byte_write(0x2005, dataTH[5]);
  58.             byte_write(0x2006, dataTH[6]);
  59.             byte_write(0x2007, dataTH[7]);
  60.             byte_write(0x2020, 1);
  61. }
  62. void updateLCD(){
  63.     dataV[0] = get_0832_AD_data(0); //PH
  64.     dataV[1] = get_0832_AD_data(1);  //ZD
  65.     dataV[2] = get_hc_sr04_distance();//ˮλ
  66.     dataV[3] = Get18B20Temp();  //WD
  67.
  68.     phv = -58.87*(dataV[0]*5.0/255.0) + 216.77;
  69.     if(phv > 141 || phv < 0 ) { phv = pre_ph_v; }
  70.     pre_ph_v = phv;
  71.     lcd[0] = ((int)phv)%1000/100+48;
  72.     lcd[1] = ((int)phv)%100/10 + 48;
  73.     lcd[2] =  '.';
  74.     lcd[3] = ((int)phv)%10 + 48;
  75.     lcd[4] =  '\0';
  76.     PutStr(0,1, lcd);
  77.     dataV[0] = phv;
  78.     dataV[1]  = dataV[1] /2.55;
  79.     if(dataV[1] > 99) dataV[1] = 99;
  80.     lcd[0] = ((int)dataV[1])%100/10 + 48;
  81.     lcd[1] = ((int)dataV[1])%10 + 48;
  82.     lcd[2] =  '\0';
  83.     PutStr(1,1, lcd);
  84.
  85.     dataV[2]  = 10 - (dataV[2]-40) /19;
  86.     if(dataV[2] > 10) dataV[2] = 10;
  87.     if(dataV[2] < 0) dataV[2] = 0;
  88.     lcd[0] = ((int)dataV[2])%100/10 + 48;
  89.     lcd[1] = ((int)dataV[2])%10 + 48;
  90.     lcd[2] =  '\0';
  91.     PutStr(2,1, lcd);
  92.
  93.     lcd[0] = ((int)dataV[3])%100/10 + 48;
  94.     lcd[1] = ((int)dataV[3])%10 + 48;
  95.     lcd[2] =  '\0';
  96.     PutStr(3,1, lcd);
  97. }
  98. void updateTH(){
  99.     lcd[0] = ((int)dataTH[0])%1000/100+48;
  100.     lcd[1] = ((int)dataTH[0])%100/10 + 48;
  101.     lcd[2] =  '\0';
  102.     PutStr(0,4, lcd);
  103.
  104.   lcd[0] = ((int)dataTH[1])%1000/100+48;
  105.     lcd[1] = ((int)dataTH[1])%100/10 + 48;
  106.     lcd[2] =  '\0';
  107.     PutStr(0,7, lcd);
  108.
  109.     lcd[0] = ((int)dataTH[2])%100/10+48;
  110.     lcd[1] = ((int)dataTH[2])%10 + 48;
  111.     lcd[2] =  '\0';
  112.     PutStr(1,4, lcd);
  113.     lcd[0] = ((int)dataTH[3])%100/10+48;
  114.     lcd[1] = ((int)dataTH[3])%10 + 48;
  115.     lcd[2] =  '\0';
  116.     PutStr(1,7, lcd);
  117.     lcd[0] = ((int)dataTH[4])%100/10+48;
  118.     lcd[1] = ((int)dataTH[4])%10 + 48;
  119.     lcd[2] =  '\0';
  120.     PutStr(2,4, lcd);
  121.     lcd[0] = ((int)dataTH[5])%100/10+48;
  122.     lcd[1] = ((int)dataTH[5])%10 + 48;
  123.     lcd[2] =  '\0';
  124.     PutStr(2,7, lcd);
  125.     lcd[0] = ((int)dataTH[6])%100/10+48;
  126.     lcd[1] = ((int)dataTH[6])%10 + 48;
  127.     lcd[2] =  '\0';
  128.     PutStr(3,4, lcd);
  129.     lcd[0] = ((int)dataTH[7])%100/10+48;
  130.     lcd[1] = ((int)dataTH[7])%10 + 48;
  131.     lcd[2] =  '\0';
  132.     PutStr(3,7, lcd);
  133. }
  134. void timer1(){
  135.     updateLCD();
  136.     updateTH();
  137.     alarm();
  138. }
  139. void main(){
  140.
  141.     init_hc_sr04();
  142.     DS18B20Init();
  143.     LcmInit();           //LCD12864³õʼ»¯
  144.     LcmClearTXT();       //LCD12864ÇåÆÁ
  145.     init_eeprom();
  146.     timer1_start(1000, timer1);
  147.
  148.     PutStr(0,0, "PH     H     L  ");
  149.     PutStr(1,0, "ZD     H     L  ");
  150.     PutStr(2,0, "SW     H     L  ");
  151.     PutStr(3,0, "WD     H     L  ");
  152.
  153.     while(1){
  154.         setKeyDeal();
  155.         addKeyDeal();
  156.         subKeyDeal();
  157.     }
  158. }
超聲波
  1. #include "HC_SR04.h"
  2. unsigned char FLAG_OVERFLOW = 0;   //³¬Éù²¨Ê±¼ä¹ý³¤Òç³ö±êÖ¾
  3. //10us
  4. void delay10us(unsigned int i)
  5. {
  6.     while(i--);
  7. }
  8. void init_hc_sr04()
  9. {
  10.     TRIG = 0;
  11.
  12.     TMOD &= 0xf0;
  13.     TMOD |= 0x01;
  14.     TH0 = 0x3c;
  15.     TL0 = 0xb0;
  16.     TF0 = 0;
  17.     ET0 = 1;
  18.     PT0 = 1;
  19.     EA = 1;
  20. }
  21. void timer0() interrupt 1
  22. {
  23.     FLAG_OVERFLOW=1;
  24. }
  25. int get_hc_sr04_distance(){
  26.         unsigned int distance;
  27.
  28.     TH0 = 0x3c;
  29.     TL0 = 0xb0;
  30.         TR0 = 0;
  31.
  32.         FLAG_OVERFLOW = 0;
  33.         TRIG = 1;
  34.         delay10us(2);
  35.         TRIG = 0;
  36.         TR0 = 1;
  37.
  38.         while(!ECHO && FLAG_OVERFLOW == 0);
  39.     TH0 = 0x3c;
  40.     TL0 = 0xb0;
  41.         TR0 = 1;
  42.
  43.         while(ECHO && FLAG_OVERFLOW == 0);
  44.         TR0 = 0;
  45.     distance = TH0 << 8 | TL0;
  46.     distance = (distance-15536)/58;
  47.     if(FLAG_OVERFLOW == 1){
  48.        FLAG_OVERFLOW = 0;
  49.              distance = 999;
  50.     }
  51.
  52.         return distance;
  53. }
ID:476215 發(fā)表于 2021-4-12 23:05 | 只看該作者
我感覺問題可能出在timer1上面,看你的代碼timer1沒有指定中斷的位置。邏輯上這種長(zhǎng)時(shí)間的中斷操作的話建議進(jìn)入以后先關(guān)總中斷(因?yàn)槟愠暡ㄒ灿昧酥袛嗤獠恐袛嗟膬?yōu)先級(jí)相對(duì)較高)
ID:652483 發(fā)表于 2021-4-12 23:13 | 只看該作者
qee654 發(fā)表于 2021-4-12 23:05
我感覺問題可能出在timer1上面,看你的代碼timer1沒有指定中斷的位置。邏輯上這種長(zhǎng)時(shí)間的中斷操作的話建議 ...
但是顯示是正確的,超聲波的數(shù)值一直不變,不知道是不是超聲波壞了
ID:476215 發(fā)表于 2021-4-12 23:17 | 只看該作者
超聲波使用的時(shí)候有兩個(gè)地方要注意:1、超聲波有死區(qū),大概是3cm的樣子,太近的話超聲波測(cè)的值會(huì)為0或者亂跳;2、超聲波實(shí)際是具有方向性的,測(cè)試的時(shí)候先垂直測(cè)試,然后再考慮其他。
如果這兩個(gè)都排除了的話建議編一個(gè)就超聲波的程序或者使用例程測(cè)一下看模塊是不是真的有問題
