- #include<reg51.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar code num[4][32]={ {0xFE,0xFF,0xFE,0xFB,0x00,0x01,0xFE,0xFF,0xFD,0xFF,0xC0,0x03,0xDB,0xDB,0xDD,0xBB,0xD0,0x0B,0xDE,0xFB,0xC0, 0x03,0xDE,0xFB,0xDE,0xFB,0xDE,0xEB,0xDE,0xF7,0xFF,0xFF},/*"南",0*/
- {0xFD,0xFF,0xFE,0xF7,0x80,0x03,0xFF,0xFF,0xFF,0xFF,0xE0,0x0F,0xEF,0xEF,0xEF,0xEF,0xE0,0x0F,0xFE,0xFF,0xF6, 0xCF,0xE6,0xE7,0xCE,0xF3,0xBE,0xF7,0xFA,0xFF,0xFD,0xFF},/*"京",1*/
- {0xFF,0xFF,0xC0,0x03,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE, 0xFF,0xFE,0xFF,0xFE,0xFF,0x00,0x01,0xFF,0xFF,0xFF,0xFF},/*"工",2*/
- {0xF2,0x07,0x8E,0xF7,0xEE,0xF7,0xEE,0xF7,0x02,0xF7,0xEE,0x07,0xCF,0xFF,0xC4,0x03,0xAB,0xBF,0xAF,0xBF,0x6C, 0x03,0xEF,0xBF,0xEF,0xBF,0xEF,0xBF,0xE8,0x01,0xEF,0xFF}/*"程",3*/
- uchar idatanum_temp[16][8]; //數(shù)據(jù)緩存,用于移位
- uchar b[8]; //16*16點(diǎn)陣,每次發(fā)送1個(gè)字節(jié)。用b[8]保存
- int n1=0;
- uchar zuoyou=0;
- uchar hanzi;
- sbit EN=P1^0; //74hc154的使能端
- sbit A_R=P2^0; //A B C D每位數(shù)據(jù)對(duì)應(yīng)于74hc154的4個(gè)數(shù)據(jù)口
- sbit B_R=P2^1;
- sbit C_R=P2^2;
- sbit D_R=P2^3;
- sbit RST_C=P1^1; //74hc595的復(fù)位口
- sbit DATA_C=P3^2; //串行數(shù)據(jù)口
- sbit SRC_C=P3^3; //74hc595的寄存器時(shí)鐘線
- sbit SLC_C=P3^4; //74hc595的鎖存器的時(shí)鐘線
- 函數(shù)功能:延時(shí)程序
- void delay(int i)
- int a;
- for(a=0;a<i;a++);
- 函數(shù)功能: 595在SLC上升沿的時(shí)候并行輸出到寄存器下的8位數(shù)據(jù)
- 入口參數(shù):無
- 返回值 :無
- void SLC_595()
- SLC_C=0;
- SLC_C=1;
- SLC_C=0;
- 函數(shù)功能:往num_temp[16][8]暫存器下存儲(chǔ)數(shù)據(jù) 16對(duì)應(yīng)著16個(gè)字節(jié)
- void hanziku()
- int i,j=0,k;
- for(i=0;i<16;i++){
- b[0]=num[0][j];b[2]=num[1][j];b[4]=num[2][j];b[6]=num[3][j];
- j++;
- b[1]=num[0][j];b[3]=num[1][j];b[5]=num[2][j];b[7]=num[3][j];
- j++;
- for(k=7;k>=0;k--){
- num_temp[i][k]=b[k]; [/i][i]
- 函數(shù)功能: 595輸出列向的數(shù)據(jù)64個(gè)(8位為一字節(jié),那就是8字節(jié)的數(shù)據(jù))
- 入口參數(shù): 無
- 返回值 :無
- //右移
- void column_zuoyi(int n)
- int i,j,e=0,f;
- uchar a1,b1;
- for(i=7;i>=0;i--){
- f=e;
- e=num_temp[n][i]&0x80;[/i][i]
- num_temp[n][i]<<=1;[/i][i]
- if(f){
- num_temp[n][i]=num_temp[n][i]+0x01;[/i][/i][i][i]
- b1=num_temp[n][i];[/i][i]
- for(j=0;j<8;j++){
- a1=0x01;
- SRC_C=0;
- DATA_C=b1&a1;
- b1>>=1;
- SRC_C=1;
- //左移
- void column_youyi(int n)
- int i,j,e=0,f;
- uchar a1,b1;
- if(i!=0)
- f=num_temp[n][i-1]&0x01;
- else
- f=0;
- num_temp[n][i]>>=1;[/i][i]
- if(f)
- num_temp[n][i]=num_temp[n][i]+0x80;[/i][/i][i][i]
- for(j=0;j<8;j++){
- a1=0x01;
- SRC_C=0;
- DATA_C=b1&a1;
- b1>>=1;
- SRC_C=1;
- //靜止
- void column_stop(int n)
- int i,j;
- uchar a1,b1;
- for(j=0;j<8;j++){
- a1=0x01;
- SRC_C=0;
- DATA_C=b1&a1;
- b1>>=1;
- SRC_C=1;
- 函數(shù)功能:行掃描程序,16次為1個(gè)周期,利用154的譯碼器
- 入口參數(shù):無
- 返回值: 無
- void column_16()
- int i,j=0;
- char temp=0x00;
- //這里輸入行數(shù)據(jù)en打開
- n1++;
- //對(duì)應(yīng)16行數(shù)據(jù)
- for(i=0;i<16;i++)
- switch(zuoyou)
- case 0:
- if(hanzi==0)
- hanziku();
- hanzi++;
- column_stop(i);
- break;
- case 1:
- column_zuoyi(i);
- hanzi=0;
- break;
- case 2:
- if(hanzi==0)
- hanziku();
- hanzi++;
- column_stop(i);
- break;
- case 3:
- column_youyi(i);
- hanzi=0;
- break;
- if(n1==70)
- n1=0;
- zuoyou++;
- if(zuoyou==4)
- zuoyou=0;
- EN=0;
- //每一行的數(shù)據(jù)
- P2=temp++; //P2從0000開始到1111
- SLC_595();
- int main()
- int i=0;
- EN=1; //154使能端關(guān)上
- SRC_C=0; //595初始化
- SLC_C=0;
- hanziku(); //初始化漢字庫
- while(1){
- column_16();
- delay(5);
- EN=1;
復(fù)制代碼 |
