查看: 5672|回復(fù): 6
NTC熱敏電阻與MAX6675熱電偶測溫(51單片機代碼+Proteus仿真)
ID:554500 發(fā)表于 2021-4-17 09:51 | 顯示全部樓層 |閱讀模式
完整代碼,請下載附件!謝謝支持!
51單片機NTC熱敏電阻配合MAX6675熱電偶測量溫度的源程序如下:
  1. //2021-04-18
  2. #include "1602.h"
  3. #include "reg51.h"
  4. #include "MAX6675.h"
  5. #include "ADC1031.H"
  6. #include <math.h>
  7. //proteus仿真軟件 ADC0831是8位的,測出來的溫度有些偏差實屬正常。
  8. //仿真畢竟不是真實的,如有興趣,可自己搭電路驗證。
  9. //NTC 10K  B3950
  10. //檢測溫度0-100
  11. //數(shù)組下標(biāo)就是對應(yīng)溫度
  12. code u8 Temp_adc[101]={
  13. 196,        194,        191,        189,        186,        184,        181,        179,        176,        173,        170,        168,
  14. 165,        162,        159,        157,        154,        151,        148,        145,        142,        139,        136,        134,
  15. 131,        128,        125,        122,        120,        117,        114,        112,        109,        106,        104,        101,
  16. 99,        96,        94,        91,        89,        87,        84,        82,        80,        78,        76,        74,        71,        70,        68,        66,        64,        62,
  17. 60,        59,        57,        55,        54,        52,        51,        49,        48,        47,        45,        44,        43,        41,        40,        39,        38,        37,
  18. 36,        35,        34,        33,        32,        31,        30,        29,        28,        27,        27,        26,        25,        24,        24,        23,        22,        22,
  19. 21,        21,        20,        20,        19,        18,        18,        17,        17,        16,        16};
  20. //查找相近值,并返回下標(biāo)
  21. u8 Find_data(u8 *a,u8 x,u8 len)
  22. {
  23.         u8 i,min,r=0;
  24.
  25.         min=abs(*a-x);
  26.         for(i=0;i<len;i++)
  27.         {
  28.                 if(abs(a[i]-x)<min)
  29.                 {
  30.                         min=abs(a[i]-x);
  31.                         r=i;
  32.                 }
  33.         }
  34.
  35.         return r;
  36. }
  37. void Timer0_init() //50MS
  38. {
  39.   TMOD=0X01;
  40.   TH0=0X4B;
  41.   TL0=0XFD;
  42.   TR0=1;
  43. }
  44. void ISR_init()
  45. {
  46.    EA=1;
  47.    ET0=1;
  48. }
  49. void isr_timer0() interrupt 1
  50. {
  51.   static u8 i;
  52.   TH0=0X4B;
  53.   TL0=0XFD;
  54.   i++;
  55.   if(i==6)  //300ms
  56.   {
  57.     i=0;
  58.           MAX6675_ReadTemper();
  59.   }
  60. }
  61. void main()
  62. {
  63.         u8 ad;
  64.
  65.   LCD_init();  //LCD初始化
  66.   Timer0_init(); //50MS
  67.   ISR_init();
  68.         Max6675_Init();
  69.   while(1)
  70.   {
  71.                 ad=read_0831();
  72.
  73.                 Show_string(0,0,"MAX6675=");
  74.                 show_nuber(8,0,(u16)MAX6675_Temper);
  75.                 Show_string(12,0,"C");
  76.
  77.                 Show_string(0,1,"10K NTC=");
  78.                 Show_string(12,1,"C");
  79.
  80.                 show_nuber(8,1,Find_data(Temp_adc,ad,101));
  81.   }
  82. }
Proteus仿真與代碼下載:
NTC MAX6675 Proteus仿真.zip (577.88 KB, 下載次數(shù): 251)
admin + 50 共享資料的黑幣獎勵!
ID:262 發(fā)表于 2021-12-9 19:34 | 顯示全部樓層
1ZZC 發(fā)表于 2021-12-9 10:36
為啥我打開仿真以后什么裝置都沒有啊
要用Proteus8.8才能打開這個仿真,你看我打開后的效果
ID:989025 發(fā)表于 2021-12-9 10:36 | 顯示全部樓層
為啥我打開仿真以后什么裝置都沒有啊
ID:987373 發(fā)表于 2021-12-9 10:44 | 顯示全部樓層
仿真打不開啊
ID:228452 發(fā)表于 2022-4-13 00:26 | 顯示全部樓層
Simulation working ok
You must locate clock.hex file and put in proteus working dir
CLOCK.rar
4.48 KB, 下載次數(shù): 11, 下載積分: 黑幣 -5
ID:205485 發(fā)表于 2022-4-13 10:39 | 顯示全部樓層
不錯,AD6675的方案比較實惠
ID:982617 發(fā)表于 2022-4-13 17:20 | 顯示全部樓層
最近就在做這個東西,很實用!
