查看: 1406|回復: 0
大家看一下,為什么單片機小車不能用藍牙和按鍵驅(qū)動前進,后退?
ID:900384 發(fā)表于 2021-4-17 16:49 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
大家看一下,為什么小車不能用藍牙和按鍵驅(qū)動前進,后退
單片機源程序如下:
#include "REG51.h"
#include "oled.h"
#include "bmp.h"
#include <intrins.h>
sbit S2 = P2^3;
sbit S3 = P2^2;
sbit S4 = P2^1;
sbit S5 = P2^0;
int num;
unsigned int time;
uint w,a,s,d,q,e;
sbit LIN1=P1^5;
sbit LIN2=P1^4;
sbit LIN3=P1^3;
sbit LIN4=P1^2;
void delay(uint z)
        uint x,y;
        for(x = z; x > 0; x--)
                for(y = 114; y > 0 ; y--);
void delay_nus(unsigned int i)
  i=i/10;
  while(--i);
void delay_nms(unsigned int n)
  n=n+1;
  while(--n)
  delay_nus(900);
void UsartInit()
SCON=0X50;
TMOD=0X20;
PCON=0X80;
TH1=0XF9;
TL1=0XF9;
ES=1;
EA=1;
TR1=1;
char i;
int msy;
void forward()
        uchar t;
                OLED_Init();
                                t=' ';
LIN1=1;LIN2=0;LIN3=0;LIN4=1;
OLED_ShowCHinese(20,0,0);
OLED_ShowCHinese(40,0,1);
void back()
uchar t;
                OLED_Init();
                                t=' ';
LIN1=0;LIN2=1;LIN3=1;LIN4=0;
OLED_ShowCHinese(20,0,2);
OLED_ShowCHinese(40,0,3);
void stop()
LIN1=1;LIN2=1;LIN3=1;LIN4=1;
void left()
uchar t;
                OLED_Init();
                                t=' ';
LIN1=1;LIN2=1;LIN3=0;LIN4=1;
OLED_ShowCHinese(20,0,4);
OLED_ShowCHinese(40,0,7);
void right()
uchar t;
                OLED_Init();
                                t=' ';
LIN1=1;LIN2=0;LIN3=1;LIN4=1;
OLED_ShowCHinese(20,0,6);
OLED_ShowCHinese(40,0,5);
void ControlCar(unsigned char ConType)
  stop();
switch(ConType)
   case 01:forward(); delay(500);break;
   case 02:left(); delay(500);break;
   case 03:right();delay(500);break;
   case 04:back();delay(500);break;
   case 05:stop();delay(500);break;
void InitTimer0(void)
    TMOD = 0x01;
    TH0 = 0x0D8;
    TL0 = 0x0F0;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
void sao()
{if(S2 == 0)
                        delay(20);
                        if(S2 == 0)
                        {w=w+1;
                                q=time;
                                while(!S2);
if(S3 == 0)
                        delay(20);
                        if(S3 == 0)
                        {a=a+1;
                                while(!S3);
if(S4 == 0)
                        delay(20);
                        if(S4 == 0)
s=s+1;
e=time;
                                while(!S4);
if(S5 == 0)
                        delay(20);
                        if(S5 == 0)
d=d+1;
                                while(!S5);
        void Timer0Interrupt(void) interrupt 1
    TH0 = 0x0D8;
    TL0 = 0x0F0;
    time++;
         sao();
        if(q!=0||e!=0)
        {switch(msy)
                 case 0:stop();
                 case 1:if(time==q+3000){time=0;w=0;s=0;stop();msy=0;q=0;}break;
                 case 2:if( time==q+6000){time=0;w=0;s=0;stop();msy=0;q=0;}break;
                 case 3:if( time ==q+9000){time=0;w=0;s=0;stop();msy=0;q=0;}break;
                 case -1:if( time ==e+3000){time=0;w=0;s=0;stop();msy=0;e=0;}break;
                 case -2:if( time ==e+6000){time=0;w=0;s=0;stop();msy=0;e=0;}break;
                 case -3:if( time ==e+9000){time=0;w=0;s=0;stop();msy=0;e=0;}break;
void UARTInit()
    EA=1;
        ES=1;
        SM0=0;SM1=1;
        REN=1;
        TR1=1;
        TMOD|=0X20;
        TH1=0xfd;
        TL1=0xfd;
void Usart() interrupt 4
uchar receiveData;
uint a;
   delay_nms(50);
receiveData=SBUF;
ControlCar(5);
delay_nms(50);
   RI=0;
   a=SBUF;
   a=SBUF%16;
  ControlCar(a);
  delay_nms(50);
SBUF=receiveData;
while(!TI);
TI=0;
void         main()
         w=0;a=0;s=0;d=0;
        msy=0;
        time=0;
        InitTimer0();
                                while(1){
   delay_nms (10);
UARTInit();
  delay_nms (10);
msy=w-s;
  if(msy!=0)
                if(msy>0)
                forward();
                        back();
                        if(a>0)
                {right();
                a--;
                delay(2000);
                stop();}
                 if(d>0)
                { left();
                d--;
                delay(2000);
        stop();}
