查看: 2626|回復(fù): 0
單片機(jī)LCD1602字符液晶垂直滾動(dòng)可以但是水平滾動(dòng)程序不行 求指導(dǎo)
一、電路設(shè)計(jì)此電路由AT89C51最小系統(tǒng)、LCD1602顯示模塊和獨(dú)立按鍵組成。
可實(shí)現(xiàn)文字的上下左右滾動(dòng)
二、運(yùn)行效果
三、部分單片機(jī)代碼
  1. /***************   writer:shopping.w   ******************/
  2. #include <reg52.h>
  3. #include <string.h>
  5. #define uint unsigned int
  6. void Initialize_LCD();
  7. void ShowString(uchar,uchar,uchar *);
  8. sbit K1 = P3^0;
  9. sbit K2 = P3^1;
  10. sbit K3 = P3^2;
  11. uchar code Prompt[]="PRESS K1--K4 TO START DEMO PROG";
  12. uchar const Line_Count = 6;
  13. uchar code Msg[][80]=
  14. {
  15.      "Many CAD users dismiss",
  16.     "process of creating PCB",
  17.     "of view.with PCB layout",
  18.     "placement and track routing,",
  19.     "can often be the most time",
  20.     "And if you use circuit simulation",
  21.     "you are going to spend even more"
  22. };
  23. uchar Disp_Buffer[32];
  24. void Delayxms(uint ms)
  25. {
  26.      uchar i;
  27.     while(ms--)
  28.     {
  29.          for(i=0;i<120;i++);
  30.     }
  31. }
  32. void V_Scroll_Display()
  33. {
  34.      uchar i,j,k = 0;
  35.     uchar *p = Msg[0];
  36.     uchar *q = Msg[Line_Count] + strlen(Msg[Line_Count]);
  37.     while(p<q)
  38.     {
  39.          for(i=0;(i<16)&&(p<q);i++)
  40.         {
  41.              if(((i==0)||(i==15))&& *p == ' ')
  42.                 p++;
  43.             if(*p != '\0')
  44.             {
  45.                  Disp_Buffer[i] = *p++;
  46.             }
  47.             else
  48.             {
  49.                  if(++k>Line_Count)
  50.                     break;
  51.                 p = Msg[k];
  52.                 Disp_Buffer[i] = *p++;
  53.             }
  54.         }
  55.         for(j=i;j<16;j++)
  56.             Disp_Buffer[j]=' ';
  57.         while(F0)
  58.             Delayxms(5);
  59.         ShowString(0,0,"      ");
  60.         Delayxms(150);
  61.         while(F0)
  62.             Delayxms(5);
  63.         ShowString(0,1,Disp_Buffer);
  64.         Delayxms(150);
  65.         while(F0)
  66.             Delayxms(5);
  67.         ShowString(0,0,Disp_Buffer);
  68.         ShowString(0,1,"      ");
  69.         Delayxms(150);
  70.     }
  71.     ShowString(0,0,"         ");
  72.     ShowString(0,1,"         ");
  73. }
  74. void H_Scroll_Display()
  75. {
  76.     uchar m,n,t = 0,L=0;
  77.     uchar *p = Msg[0];
  78.     uchar *q = Msg[Line_Count] + strlen(Msg[Line_Count]);
  79.     for(m=0;m<16;m++)
  80.             Disp_Buffer[m]=' ';
  81.     while(p<q)
  82.     {
  83.          if((m=16||m==31)&& *p == ' ')
  84.             p++;
  85.         for(m=16;m<32&&p<q;m++)
  86.         {
  87.              if(*p != '\0')
  88.             {
  89.                 Disp_Buffer[m] = *p++;
  90.             }
  91.             else
  92.             {
  93.                  if(++t>Line_Count)
  94.                     break;
  95.                 p = Msg[t];
  96.                 Disp_Buffer[m] = *p++;
  97.             }
  98.         }
  99.         for(n=m;n<32;n++)
  100.             Disp_Buffer[n]=' ';
  101.         for(m=0;m<=16;m++)
  102.         {
  103.              while(F0)
  104.                  Delayxms(5);
  105.                ShowString(0,L,Disp_Buffer+1);
  106.                while(F0)
  107.                  Delayxms(5);
  108.             Delayxms(20);
  109.         }
  110.         L = (L==0)? 1:0;
  111.         Delayxms(200);
  112.     }
  113.     if(L==1)
  114.         ShowString(0,1,"      ");
  115. }
  116. void EX_INT0() interrupt 0
  117. {
  118.      F0 = !F0;
  119. }
  120. void main()
  121. {
  122.      uint Count = 0;
  123.     IE = 0x81;
  124.     IT0 = 1;
  125. ……………………
  126. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
全部資料51hei下載地址:
1602字符液晶滾動(dòng)演示程序.zip (88.69 KB, 下載次數(shù): 35)
