查看: 1575|回復: 0
單片機+數碼館仿真失敗
ID:692206 發(fā)表于 2021-4-22 22:53 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
  仿真只顯示13v
#include<reg51.h>
uchar code table[]={ 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
uchar Tcount;
uint wei3,wei2,wei1,wei0,num;
bit timerflag,ADflag;
sbit AD_end        =P3^2;
sbit OE=P2^5;
sbit ST=P2^6;
void AD_INT() interrupt 0
{ADflag=1;
AD_end=1;
void T0_int()interrupt 1
{TL0|=0xb0;
TH0=0x3c;
   if(--Tcount==0)
     {Tcount=20;
      timerflag=1;}
void delay(uint z)
{uint x,y;
for(x=z;x>0;x--)
    for(y=110;y>0;y--);
Tcount=20;
TMOD=0x01;
TL0=0xb0;
TH0=0x3c;
IT0=1;
TR0=1;
ET0=1;
EX0=1;
EA=1;
{ P2=P2&0xf0|0x07;
  P0=table[wei0];
  delay(1);
  P2=P2&0xf0|0x0b;
  P0=table[wei1];
  delay(1);
  P2=P2&0xf0|0x0d;
  P0=table[wei2]|0x80;
  delay(1);
  P2=P2&0xf0|0x0e;
  P0=table[wei3];
  delay(1);
  if(timerflag==1)
    {timerflag=0;
     ADflag=0;
     ST=1;
           ST=0;
      while(!ADflag);
         {OE=1;
          num=P1*20-2500;
          wei3=num/1000;
          wei2=num%1000/100;
          wei1=num%100/10;
          wei0=num%10;
          OE=0;
          ADflag=0;}
Powered by 單片機教程網
