這是修改后的手動(dòng)程序,但程序還是沒(méi)有反應(yīng)
#include<reg52.h>
uint a,b,c,d,e,PWM_T,time,count=1,value;
sbit ADD=P0^0; //電機(jī)加減速鍵
//sbit SUB=P0^1;
sbit STOP=P0^2; //電機(jī)剎車(chē)鍵
sbit DIR=P0^3; //電機(jī)換向鍵
sbit PWM=P2^1; //脈沖輸出端口
sbit KA1=P0^4; //電機(jī)剎車(chē)?yán)^電器
sbit KA2=P0^5; //電機(jī)換向繼電器
bit PWM_OUTDAT;
void delay(uint z);
void add();
//void sub();
void stop();
void dir();
void timeconfig();
PWM_OUT(uint Cycle,uint PWM_ON);
timeconfig();
add();
PWM=0;
add();
// sub();
stop();
dir();
switch(count)
case 1:
PWM=PWM_OUT(1000,950);
break;
case 2:
PWM=PWM_OUT(1000,900);
break;
case 3:
PWM=PWM_OUT(1000,850);
break;
case 4:
PWM=PWM_OUT(1000,800);
break;
case 5:
PWM=PWM_OUT(1000,750);
break;
case 6:
PWM=PWM_OUT(1000,700);
break;
case 7:
PWM=PWM_OUT(1000,650);
break;
case 8:
PWM=PWM_OUT(1000,600);
break;
case 9:
PWM=PWM_OUT(1000,550);
break;
case 10:
PWM=PWM_OUT(1000,500);
break;
case 11:
PWM=PWM_OUT(1000,450);
break;
case 12:
PWM=PWM_OUT(1000,400);
break;
case 13:
PWM=PWM_OUT(1000,350);
break;
case 14:
PWM=PWM_OUT(1000,300);
break;
case 15:
PWM=PWM_OUT(1000,250);
break;
case 16:
PWM=PWM_OUT(1000,200);
break;
case 17:
PWM=PWM_OUT(1000,150);
break;
case 18:
PWM=PWM_OUT(1000,100);
break;
case 19:
PWM=PWM_OUT(1000,50);
break;
case 20:
PWM=PWM_OUT(1000,0);
break;
void delay(uint z)
uint x,y;
for(x=0;x<z;x++)
for(y=0;y<180;y++);
void add()
if(ADD==0)
delay(5);
if(ADD==0)
count++;
if(count>=20)
count=20;
while(!ADD);
void timeconfig()
TMOD=0x01; //定時(shí)器0工作于方式1
TH0=0xFF;
TL0=0xFF;
TR0=1;
ET0=1;
EA=1;
void time0() interrupt 1
TH0=0xFF;
TL0=0xFF;
value++;
PWM_T++;
/* if(a==1)
if(PWM_T>=60000)
PWM_T=0;
count++;
if(count<=19)
count=19;
if(b==1)
if(PWM_T>=100)
PWM_T=0;
count--;
if(count==0)
count=0;
if(value>=PWM_ON)
PWM_OUTDAT=0;
if(value>=Cycle)
value=0;
if(PWM_ON!=0)
PWM_OUTDAT=1;
return PWM_OUTDAT;
