查看: 1890|回復(fù): 3
單片機(jī)LED點(diǎn)陣實(shí)現(xiàn)了垂直方向的滾動(dòng)顯示程序,如何修改為水平滾動(dòng)?
ID:884109 發(fā)表于 2021-5-2 21:40 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
使用LED點(diǎn)陣滾動(dòng)顯示數(shù)字,實(shí)現(xiàn)了垂直方向的滾動(dòng)(代碼如下),但是怎么實(shí)現(xiàn)水平方向上的滾動(dòng)呢?
我把行列掃描互換后,水平是水平了,可數(shù)字全躺平了 該怎么解決呢?請(qǐng)各位大神幫幫忙吧,先謝了.
#include <REG51.H>
#define uchar unsigned char //8 0-255
#define uint unsigned int   //16  0-65535
void delay(uint xms)
          uint i,j;
        for(i=xms; i>0; i--)
                for(j=111; j>0; j--);
uchar code table[] = {
0x00,0x00,0x00,0x18,0x24,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18,0x00,0x00,  //0
0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x08,0x0E,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x3E,0x00,0x00,
0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x20,0x20,0x10,0x08,0x04,0x42,0x7E,0x00,0x00,
0x00,0x00,0x00,0x3C,0x42,0x42,0x20,0x18,0x20,0x40,0x40,0x42,0x22,0x1C,0x00,0x00,
0x00,0x00,0x00,0x20,0x30,0x28,0x24,0x24,0x22,0x22,0x7E,0x20,0x20,0x78,0x00,0x00,
0x00,0x00,0x00,0x7E,0x02,0x02,0x02,0x1A,0x26,0x40,0x40,0x42,0x22,0x1C,0x00,0x00,
0x00,0x00,0x00,0x38,0x24,0x02,0x02,0x1A,0x26,0x42,0x42,0x42,0x24,0x18,0x00,0x00,
0x00,0x00,0x00,0x7E,0x22,0x22,0x10,0x10,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00,
0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x24,0x18,0x24,0x42,0x42,0x42,0x3C,0x00,0x00,
0x00,0x00,0x00,0x18,0x24,0x42,0x42,0x42,0x64,0x58,0x40,0x40,0x24,0x1C,0x00,0x00, //9
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
};  //0-9 8*16點(diǎn)陣數(shù)組
uchar code scan[] = { 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80 };
void main(void)
        uchar i,j,k;
          while(1){
                 for( i = 0; i < 196; i=i+2){
                        for(k = 0; k<20; k++){
                                for(j = 0; j<8; j++){
                                        P1 = P3 = P2 = 0x00;
                                         P1 = table[i+j];
                                        P3 = scan[j];
                                        P2 = 0x00;
                                        delay(1);
                                        P1 = table[i+j+8];
                                        P3 = 0x00;
                                        P2 = scan[j];
                                        delay(1);
ID:390416 發(fā)表于 2021-5-3 13:12 | 只看該作者
算法比較復(fù)雜 我做過(guò)8*8點(diǎn)陣的 上下左右 四個(gè)斜角的移位
ID:275826 發(fā)表于 2021-5-3 14:45 | 只看該作者
要簡(jiǎn)單的話就重新取模
ID:358019 發(fā)表于 2021-6-9 21:35 | 只看該作者
最簡(jiǎn)單方法就是把點(diǎn)陣轉(zhuǎn)90°
