#include "sys.h"
#include "usart.h"
#include "led.h"
#include "delay.h"
//加入以下代碼,支持printf函數(shù),而不需要選擇use MicroLIB
#if 1
#pragma import(__use_no_semihosting)
//標(biāo)準(zhǔn)庫需要的支持函數(shù)
struct __FILE
int handle;
FILE __stdout;
//定義_sys_exit()以避免使用半主機(jī)模式
_sys_exit(int x)
x = x;
//重定義fputc函數(shù)
int fputc(int ch, FILE *f)
while((USART1->SR&0X40)==0);//循環(huán)發(fā)送,直到發(fā)送完畢
USART1->DR = (u8) ch;
return ch;
#endif
/*使用microLib的方法*/
USART_SendData(USART1, (uint8_t) ch);
while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET) {}
return ch;
int GetKey (void) {
while (!(USART1->SR & USART_FLAG_RXNE));
return ((int)(USART1->DR & 0x1FF));
#if EN_USART1_RX //如果使能了接收
//串口1中斷服務(wù)程序
//注意,讀取USARTx->SR能避免莫名其妙的錯誤
u8 USART_RX_BUF[USART_REC_LEN]; //接收緩沖,最大USART_REC_LEN個字節(jié).
//接收狀態(tài)
//bit15, 接收完成標(biāo)志
//bit14, 接收到0x0d
//bit13~0, 接收到的有效字節(jié)數(shù)目
u16 USART_RX_STA=0; //接收狀態(tài)標(biāo)記
void uart_init(u32 bound){
//GPIO端口設(shè)置
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA, ENABLE); //使能USART1,GPIOA時鐘
//USART1_TX GPIOA.9
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //復(fù)用推挽輸出
GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.9
//USART1_RX GPIOA.10初始化
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//PA10
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空輸入
GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.10
//Usart1 NVIC 配置
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//搶占優(yōu)先級3
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //子優(yōu)先級3
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能
NVIC_Init(&NVIC_InitStructure); //根據(jù)指定的參數(shù)初始化VIC寄存器
//USART 初始化設(shè)置
USART_InitStructure.USART_BaudRate = bound;//串口波特率
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字長為8位數(shù)據(jù)格式
USART_InitStructure.USART_StopBits = USART_StopBits_1;//一個停止位
USART_InitStructure.USART_Parity = USART_Parity_No;//無奇偶校驗(yàn)位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//無硬件數(shù)據(jù)流控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收發(fā)模式
USART_Init(USART1, &USART_InitStructure); //初始化串口1
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//開啟串口接受中斷
USART_Cmd(USART1, ENABLE); //使能串口1
void USART1_IRQHandler(void) //串口1中斷服務(wù)程序
u8 Res;
if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) //接收中斷
USART_ClearITPendingBit(USART1,USART_IT_RXNE);
Res=USART_ReceiveData(USART1); //讀取接收到的數(shù)據(jù)
USART_SendData(USART1,Res);//回傳接收到的數(shù)據(jù)
LED1=0;
while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待發(fā)送完畢
delay_ms(100);
LED1=1;//LED燈閃爍,接收成功發(fā)送完成
if(Res=='1')//接收到1,點(diǎn)亮LED
LED0=1;
else//其他情況熄滅LED
LED0=0;
USART_RX_STA=0;
#endif
