查看: 4033|回復(fù): 7
單片機(jī)+LCD1602初始化失敗
ID:900860 發(fā)表于 2021-5-7 10:36 | 顯示全部樓層 |閱讀模式
50黑幣
仿真可以,但是實(shí)物接的時(shí)候就不行
//函數(shù)聲明
void Read_Busy();        //忙檢測(cè)函數(shù)
void Lcd1602_Write_Cmd(unsigned char cmd);        //寫(xiě)命令
void Lcd1602_Write_Data(unsigned char dat);        //寫(xiě)數(shù)據(jù)
void LcdSetCursor(unsigned char x,unsigned char y);        //坐標(biāo)顯示
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);        //顯示字符
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str);        //顯示字符串
void InitLcd1602();        //初始化
#include"lcd.h"
void Read_Busy()           //忙檢測(cè)函數(shù),判斷bit7是0,允許執(zhí)行;1禁止
    unsigned char sta;
    LCD1602_DB = 0xff;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do
        LCD1602_EN = 1;
        sta = LCD1602_DB;
        LCD1602_EN = 0;    //使能,用完就拉低,釋放總線
    }while(sta & 0x80);
/*void delay(uint n)
    uint x,y;
    for(x=n;x>0;x--)
    for(y=110;y>0;y--);
void Lcd1602_Write_Cmd(unsigned char cmd)     //寫(xiě)命令
    Read_Busy();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_EN = 1;
         delay(5);
    LCD1602_EN = 0;
void Lcd1602_Write_Data(unsigned char dat)   //寫(xiě)數(shù)據(jù)
     Read_Busy();
      LCD1602_RS = 1;
      LCD1602_RW = 0;
      LCD1602_DB = dat;
      LCD1602_EN = 1;
           delay(5);
      LCD1602_EN = 0;
void LcdSetCursor(unsigned char x,unsigned char y)  //坐標(biāo)顯示
    unsigned char addr;
    if(y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
    Lcd1602_Write_Cmd(addr|0x80);
//按指定位置顯示一個(gè)字符
        Y &= 0x1;
        X &= 0xF; //限制X不能大于15,Y不能大于1
        if (Y) X |= 0x40; //當(dāng)要顯示第二行時(shí)地址碼+0x40;
        X |= 0x80; //算出指令碼
        Lcd1602_Write_Cmd(X); //發(fā)命令字
        Lcd1602_Write_Data(DData); //發(fā)數(shù)據(jù)
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str)     //顯示字符串
    LcdSetCursor(x,y);      //當(dāng)前字符的坐標(biāo)
    while(*str != '\0')
        Lcd1602_Write_Data(*str++);
        void InitLcd1602()              //1602初始化
    Lcd1602_Write_Cmd(0x38);    //打開(kāi),5*8,8位數(shù)據(jù)
    Lcd1602_Write_Cmd(0x0c);
    Lcd1602_Write_Cmd(0x06);
    Lcd1602_Write_Cmd(0x01);    //清屏
ID:818487 發(fā)表于 2021-5-7 12:38 | 顯示全部樓層
初始化前有問(wèn)題,檢查一下接線,還有顯示屏說(shuō)明書(shū)和仿真軟件命令上的差異
ID:894154 發(fā)表于 2021-5-7 14:14 | 顯示全部樓層
賊個(gè)調(diào)一下對(duì)比度就好啦 后面有旋鈕
ID:900860 發(fā)表于 2021-5-7 14:47 | 顯示全部樓層
ANT1987 發(fā)表于 2021-5-7 14:14
是對(duì)比度的問(wèn)題嗎?我百度里說(shuō)的是初始化失敗才有這個(gè)白條...對(duì)比度調(diào)整是不是得接電阻
ID:390416 發(fā)表于 2021-5-7 15:02 | 顯示全部樓層
正巧,我前幾天發(fā)了一個(gè)LCD1602 的貼子 專(zhuān)門(mén) 針對(duì)復(fù)位失敗這個(gè)問(wèn)題的
ID:451718 發(fā)表于 2021-5-7 17:23 | 顯示全部樓層
從圖片看,對(duì)比度沒(méi)太大問(wèn)題。    應(yīng)該是初始化問(wèn)題,延遲函數(shù)準(zhǔn)不準(zhǔn)? 另外硬件的引腳定義正確么?
另外,寫(xiě)指令和寫(xiě)數(shù)據(jù)用下面這段試試
    Read_Busy();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
        LCD1602_EN = 1;
    LCD1602_DB = cmd;
        _nop_();_nop_();_nop_();_nop_();
    LCD1602_EN = 1;
    LCD1602_EN = 0;
      Read_Busy();
      LCD1602_RS = 1;
      LCD1602_RW = 0;
        LCD1602_EN = 1;
      LCD1602_DB = dat;
      LCD1602_EN = 1;
      LCD1602_EN = 0;
ID:593706 發(fā)表于 2021-5-8 17:48 | 顯示全部樓層
不是對(duì)比度調(diào)整的問(wèn)題,如果是對(duì)比度不正常,會(huì)出現(xiàn)二行白條而不是只有第二行白條,從硬件上檢查接線是否正確,軟件上好好看看程序有沒(méi)有問(wèn)題。
ID:889094 發(fā)表于 2021-5-8 17:59 來(lái)自手機(jī) | 顯示全部樓層
程序一般例程不會(huì)出錯(cuò),確認(rèn)一下你的delay函數(shù)是否準(zhǔn)確,可以main開(kāi)始delay(1000)然后debug看看用時(shí)是不是你想要的
