查看: 1658|回復: 0
lcd12864顯示電池電流電壓亂碼問題
ID:723431 發(fā)表于 2021-5-14 14:59 | 顯示全部樓層 |閱讀模式
PCF8591做AD轉(zhuǎn)換,ACS712做電流傳感器,LCD12864做顯示屏,顯示出來的是亂碼,想知道怎么解決,程序和仿真如下所示:
#include<reg51.h>
#include<intrins.h>
#define PCF8591_WRITE 0x90
#define PCF8591_READ 0x91
sbit SDA=P2^0;
sbit SCL=P2^1;
unsigned char code dis1[]="0-0.00V  1-0.00V";
unsigned int data dis[4];
unsigned char data receivebuf[4];
#define uint8 unsigned char
#define uint16 unsigned int
#define LCD_databus P0
sbit RS = P1^4;
sbit RW = P1^3;
sbit EN = P1^5;
sbit CS1 = P1^0;//片選1.低電平有效,控制左半屏
sbit CS2 = P1^1;//片選2,低電平有效,控制右半屏
void Read_busy();
void write_LCD_command(uint8);
void write_LCD_data(uint8);
void Set_page(uint8);
void Set_line(uint8);
void Set_column(uint8);
void SetOnOff(uint8);
void SelectScreen(uint8);
void ClearScreen(uint8);
void InitLCD();
void show_ch(uint8,uint8,uint8,uint8 *);
void show_im(uint8,uint8,uint8,uint8 *);
void show_value(unsigned char ad_data);
//us延時函數(shù)(4.34us)
void delayNOP()
        _nop_();
        _nop_();
        _nop_();
        _nop_();
//ms延時函數(shù)
void delayms(unsigned int ms)
        unsigned char i;
        while  (ms--)
                for(i=0;i<114;i++)
        dis[2]=ad_data/51;
        dis[2]=dis[2]+0x30;
        dis[3]=ad_data%51;
        dis[3]=dis[3]*10;
        dis[1]=dis[3]/51;
        dis[1]=dis[1]+0x30;
        dis[3]=ad_data%51;
        dis[3]=dis[3]*10;
        dis[0]=dis[3]/51;
        dis[0]=dis[0]+0x30;
void Read_busy()
        P0 = 0X00;
        RS = 0;
        RW = 1;
        EN = 1;
        while(P0 & 0x80)
        EN = 0;
void write_LCD_command(uint8 value)        //寫命令函數(shù)
        Read_busy();
        RS = 0; //0:寫指令
        RW = 0;        //0:寫操作
        LCD_databus = value;
        EN = 1;        //EN下降沿鎖存有效數(shù)據(jù)
        _nop_();
        _nop_();
        _nop_();//空指令,短暫延時
        EN = 0;
void write_LCD_data(uint8 value)        //寫數(shù)據(jù)函數(shù)
        Read_busy();
        RS = 1; //1:寫數(shù)據(jù)
        RW = 0;        //寫操作
        _nop_();
        _nop_();
        _nop_();//空指令,短暫延時
        EN = 0;
}void Set_page(uint8 page)        //設置顯示起始頁
        page = 0xB8 | page;        //頁的首地址為0xB8
        write_LCD_command(page);
void Set_line(uint8 startline)        //設置顯示起始行
        startline = 0xC0 | startline;
        write_LCD_command(startline);
void Set_column(uint8 column)        //設置顯示的列
        column = column & 0x3F;        //列的最大值為64
        column = column | 0x40;        //列的首地址為0x40
        write_LCD_command(column);
void SetOnOff(uint8 onoff)        //顯示開關函數(shù),0x3E:關 0x3F:開
        onoff = 0x3E | onoff;        //onoff為0時關顯示,為1時開顯示
        write_LCD_command(onoff);
void SelectScreen(uint8 screen)        //選擇屏幕
        switch(screen)
                case 0:CS1 = 0;CS2 = 0;break;//全屏
                case 1:CS1 = 0;CS2 = 1;break;//左半屏
                case 2:CS1 = 1;CS2 = 0;break;//右半屏
                default:break;
void ClearScreen(uint8 screen)        //清屏
        uint8 i,j;
        SelectScreen(screen);
        for(i=0;i<8;i++)
                Set_page(i);
                Set_column(0);
                for(j=0;j<64;j++)
                        write_LCD_data(0x00);        //寫入0,地址指針自動加1
void InitLCD()
        Read_busy();
        SelectScreen(0);
        SetOnOff(0);
        SelectScreen(0);
        SetOnOff(1);
        SelectScreen(0);
        ClearScreen(0);
        Set_line(0);
//啟動i2c
void iic_start(void)
        SDA=1;
        SCL=1;
        delayNOP();
        SDA=0;
        delayNOP();
        SCL=0;
//停止i2c
void iic_stop(void)
        SDA=0;
        SCL=1;
        delayNOP();
        SDA=1;
        delayNOP();
        SCL=0;
//初始化i2c
void iicInit(void)
        SCL=0;
        iic_stop();
//應答子程序
void slave_ACK(void)
        SDA=0;
        SCL=1;
        delayNOP();
        SCL=0;
        SDA=1;
//非應答子程序
void slave_NOACK(void)
        SDA=1;
        SCL=1;
        delayNOP();
        SDA=0;
        SCL=0;
        SDA=0;
//檢查應答子程序
void check_ACK(void)
        SDA=1;
        SCL=1;
        F0=0;
        delayNOP();
        if(SDA==1)
                F0=1;
        SCL=0;
//發(fā)送1個字節(jié)
void IICSendByte(unsigned char indata)
        unsigned char n=8;
        while(n--)
                SDA=(bit)(indata &0x80);
                SCL=1;
                delayNOP();
                SCL=0;
                indata=indata<<1;
//接收一個字節(jié)
unsigned char IICreceiveByte(void)
        unsigned char n=8;
        unsigned char tdata=0;
        while(n--)
                SDA=1;
                SCL=1;
                tdata=tdata<<1;
                if(SDA==1)
                tdata=tdata|0x01;
                tdata=tdata&0xfe;
                SCL=0;
        return(tdata);
//發(fā)送數(shù)據(jù)子程序
void DAC_PCF8591(unsigned char controlbyte,unsigned char w_data)
        iic_start();
        delayNOP();
        IICSendByte(PCF8591_WRITE);
        check_ACK();
        IICSendByte(controlbyte&0x77);
        check_ACK();
        IICSendByte(w_data);
        check_ACK();
        iic_stop();
        delayNOP();
        delayNOP();
//A/D轉(zhuǎn)換
void ADC_PCF8591(unsigned char controlbyte)
        unsigned char i=0;
        iic_start();
        check_ACK();
        IICSendByte(controlbyte);
        check_ACK();
        iic_start();
        IICSendByte(PCF8591_READ);
        check_ACK();
        IICreceiveByte();
        slave_ACK();
        while(i<3)
                receivebuf[i++]=IICreceiveByte();
                slave_ACK();
        receivebuf[3]=IICreceiveByte();
        slave_NOACK();
        iic_stop();
        unsigned char i;
    delayms(10);
    InitLCD();
    SelectScreen(1);
        Set_page(1);
        Set_column(0*16);
    for(i=0;i<16;i++)
    write_LCD_data(dis1);
       ClearScreen(0);
        Set_line(0);
         iicInit();
         ADC_PCF8591(0x04);
          while(F0)
          {iicInit();
             ADC_PCF8591(0x04);
                show_value(receivebuf[0]);
                      SelectScreen(1);
                                Set_page(1);
                                Set_column(0*16);
                write_LCD_data(dis[2]);
                SelectScreen(1);
                                Set_page(1);
                                Set_column(2*16);
               write_LCD_data(dis[1]);
                write_LCD_data(dis[0]);
                iicInit();
                DAC_PCF8591(0x40,receivebuf[0]);
                while(F0)
                        iicInit();
