查看: 2198|回復(fù): 0
適用于STC15F104W單片機(jī)模擬串口接收數(shù)據(jù)對(duì)比函數(shù)
ID:917140 發(fā)表于 2021-5-25 03:02 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
typedef unsigned char BYTE;
BYTE RX_Buffer[32]={"                                "};
void RECEIVE_DATA(void) interrupt 4 using 1         //′串口中斷
        unsigned char i = 0;
        if(RI == 1)
                temp = SBUF;
                if(num < 32)
                   RX_Buffer[num] = temp;
                   num++;
                        num = 0;
                if(temp == '\n'){
                        num = 0;
                        flagReceive = 1;                //óDêy¾Y½óêÕ
                RI = 0;
對(duì)比函數(shù)
void isReceiveOKOrTimeout()
        unsigned int count = 0;
        while(count++ < 30000)         //接收到OK或者超時(shí)退出
                if(flagReceive){
                        flagReceive = 0;
                        if(
                                RX_Buffer[0] == 'O'
                                && RX_Buffer[1] == 'K'
                                && RX_Buffer[2] == '\r'
                                && RX_Buffer[3] == '\n'
                                break;
