查看: 3230|回復(fù): 1
求大俠給ds1302加上掉電檢測程序
ID:47184 發(fā)表于 2013-8-25 20:11 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#include<intrins.h>
uchar temp[]={0xeb,0x88,0xb3,0xba,0xd8,0x7a,0x7b,0xa8,0xfb,0xfa};
sbit ce=P3^5;//ds1302
sbit sclk=P3^7;//時鐘
sbit io=P3^6;//數(shù)據(jù)口
//定義摁鍵
sbit key1=P1^5;//小時+
sbit key2=P1^4;//小時-
sbit key3=P1^3;//分鐘+
sbit key4=P1^2;//分鐘-
//定義蜂鳴器
sbit beep=P1^6;
//定義段位
sbit duan=P1^0;
sbit wei=P1^1;
//位尋址寄存器定義
sbit ACC_7=ACC^7;
uchar num,dat1,dat2;
//地址數(shù)據(jù)發(fā)送子程序
void write1302(unsigned char addr,dat)
        uchar i,temp;
        ce=0;
        sclk=0;
        ce=1;
        for(i=8;i>0;i--)
                sclk=0;
                temp=addr;
                io=(bit)(temp&0x01);
                addr>>=1;
                sclk=1;
        for(i=8;i>0;i--)
                sclk=0;
                temp=dat;
                dat>>=1;
                sclk=1;
        ce=0;
//數(shù)據(jù)獲取子程序
uchar read1302(uchar addr)
        uchar i,temp;
        ce=0;
        sclk=0;
        ce=1;
        for(i=8;i>0;i--)
                sclk=0;
                temp=addr;
                addr>>=1;
                sclk=1;
        for(i=8;i>0;i--)
                ACC_7=io;
                sclk=1;
                ACC>>=1;
                sclk=0;
        ce=0;
        dat1=ACC;
        dat2=dat1/16;
        dat1=dat1%16;
        dat1=dat1+dat2*10;
        return(dat1);
//初始化1302
void init()
        write1302(0x8e,0x00);
        write1302(0x90,0x06);
        write1302(0x80,0x56);
        write1302(0x82,0x46);
        write1302(0x84,0x19);
        write1302(0x8e,0x80);
//簡單延時
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
//把1302讀取到的數(shù)據(jù)顯示到數(shù)碼管上
void xianshi(uchar wela1,wela2)
        uchar shi,ge;
        shi=dat1/10;
        ge=dat1%10;
        wei=1;
        P2=wela1;
        wei=0;
        duan=1;
        P2=temp[shi];
        duan=0;
        delay(5);
        wei=1;
        P2=wela2;
        wei=0;
        duan=1;
        P2=temp[ge];
        duan=0;
        delay(5);
//蜂鳴器發(fā)聲程序
void di()
        beep=0;
        delay(50);
        beep=1;
//摁鍵檢測
void key_check()
                                                if(key1==0)
                                                        delay(1);
                                                        if(key1==0)
        di();
        while(!key1);
        read1302(0x85);
        dat1=dat1++;
        if(dat1==24)
        dat1=0;
        dat1=dat1%10+dat1/10*16;
        write1302(0x84,dat1);
                                                if(key3==0)
                                                        delay(1);
                                                        if(key3==0)
        di();
        while(!key3);
        read1302(0x83);
        dat1=dat1++;
        if(dat1==60)
        dat1=0;
        write1302(0x82,dat1);
                                                if(key2==0)
                                                        delay(1);
                                                        if(key2==0)
        di();
        while(!key2);
        read1302(0x85);
        dat1=dat1--;
        if(dat1==0)
        dat1=23;
                                                if(key4==0)
                                                        delay(1);
                                                        if(key4==0)
        di();
        while(!key4);
        read1302(0x83);
        dat1=dat1--;
        if(dat1==0)
        dat1=59;
//主程序
        init();
                key_check();//鍵盤檢測
                        read1302(0x83);//讀分鐘
                        xianshi(0xdf,0xef);        //顯示分鐘
                        read1302(0x85);//讀小時
                        xianshi(0x7f,0xbf);//顯示小時
ID:76287 發(fā)表于 2015-4-10 09:17 | 只看該作者
雖然不懂,但還是要頂,畢竟每一位老手都是從新手蛻變而來的,贊一個。。。。。。
