查看: 1968|回復(fù): 2
8051單片機(jī)匯編語(yǔ)言 求解串口通信只發(fā)不收?
  1.         ORG                0000H
  2.         LJMP        START
  3.         ORG                0023H
  4.         LJMP        SBR1
  5. START:
  6.         MOV                TMOD, #20H               ;foc=6Mhz   1200bps
  7.         MOV                TL1, #0F3H
  8.         MOV                TH1, #0F3H
  9.         SETB        TR1
  10.         MOV                SCON, #50H
  11.         SETB        ES
  12.         SETB        EA
  13. Loop:
  14.         SJMP        $
  15.         ORG                0200H
  16. SBR1:
  17.         JB                RI,SOUT
  18.         JB                TI,SIN
  19.         LJMP        Loop
  20. SOUT:
  21.         CPL         RI
  22.         MOV                A, SBUF
  23.         RET
  24. SIN:
  25.         CPL         TI
  26.         MOV                SBUF, A
  27.         RET
  28. END
示波器上可以看到有發(fā)的波形,但是另一個(gè)信道怎么也沒有接受信號(hào),虛擬串口中斷也沒有顯示接受的字符
ID:741935 發(fā)表于 2021-5-30 19:53 | 只看該作者
發(fā)送端
ORG 0000H
JMP START
ORG 0100H
START:
ACALL INIT
MAIN:
MOV P2,#0F0H
MOV A,P2
XRL A,#0F0H
JZ MAIN
ACALL KEYSCAN
MOV A,30H
MOV DPTR,#TABLE2
MOVC A,@A+DPTR
MOV P1,A
SETB P0.5
CLR P0.4
CLR P0.3
ACALL DELAY2
SETB P0.3
ACALL DELAY
ALOOP1:
MOV 40H,A
MOV SBUF,#0E1H
JNB TI,$;發(fā)送中斷
CLR TI
JNB RI,$;接收中斷
CLR RI
MOV A,SBUF;二號(hào)機(jī)應(yīng)答信號(hào)
XRL A,#0E2H;異或判定是否準(zhǔn)備完畢(判斷發(fā)送消息是否為#0E2)
JNZ ALOOP1;開始發(fā)送數(shù)據(jù)時(shí)定義初始地址,這個(gè)地址里面存儲(chǔ)要發(fā)送的數(shù)據(jù)
MOV R0,#40H
MOV R6,#00H;校驗(yàn)和
ALOOP2:
MOV SBUF,@R0
MOV A,R6
ADD A,@R0
MOV R6,A
JNB TI,$
CLR TI
MOV SBUF,R6
JNB TI,$;發(fā)送中斷
CLR TI
JNB RI,$;接收應(yīng)答中斷
CLR RI
MOV A,SBUF
XRL A,#00H
JNZ ALOOP2
JMP MAIN
INIT:
MOV A,#00000001B
MOV P1,A
ACALL ENABLE
MOV A,#00111000B
MOV P1,A
ACALL ENABLE
MOV A,#00001111B
MOV P1,A
ACALL ENABLE
MOV A,#00000110B
MOV P1,A
ACALL ENABLE
MOV A,#00H
MOV P1,A
ACALL ENABLE
CLR EA
MOV TMOD,#20H
MOV TH1,#0F4H
MOV TL1,#0F4H
MOV PCON,#00H
SETB TR1
MOV SCON,#50H
KEYSCAN:MOV P2,#0F0H;先讀列再讀行
        MOV A,P2
        ANL A,#0F0H
                MOV R3,A
                MOV P2,#0FH
                MOV A,P2
                ANL A,#0FH
                ORL A,R3
                CJNE A,#0FFH,KEYPRO;檢測(cè)鍵值是否成功讀入
                RET
KEYPRO: MOV R3,A
        MOV DPTR,#KEYVALUE
                MOV R4,#0FFH;存鍵值表到鍵碼表的偏移量
KEY1:   INC R4     ;掃描鍵碼表里面的數(shù)值
        MOV A,R4
                MOVC A,@A+DPTR
                CJNE A,03H,KEY1
                MOV A,R4
                MOV 30H,A
DELAY1: MOV R6,#60H;延時(shí)程序
DE2:    MOV R7,#90H
        DJNZ R7,$
                DJNZ R6,DE2
                RET
ENABLE: CLR P0.5;寫命令
        CLR P0.4
                CLR P0.3
                ACALL DELAY2
                SETB P0.3
                RET
DELAY2: MOV P1,#0FFH
        CLR P0.5
                SETB P0.4
                CLR P0.3
                NOP
                SETB P0.3
                JB P1.7,DELAY2
                RET
DELAY:
MOV R5,#10H;延時(shí)程序
D1:
MOV R6,#30H
D2:
MOV R7,#90H
DJNZ R7,$
DJNZ R6,D2
DJNZ R5,D1
RET
KEYVALUE:DB 0E7H,0D7H,0B7H,077H,0EBH,0DBH,0BBH,07BH,0EDH,0DDH,0BDH,07DH,0EEH,0DEH,0BEH,07EH;鍵碼矩陣
TABLE2:  DB 30H,31H,33H,38H,64H,69H,61H,6EH,6BH,65H,79H,74H,67H,3CH,5FH,3EH
END
ID:593706 發(fā)表于 2021-5-31 11:51 | 只看該作者
串口發(fā)送數(shù)據(jù)完成后,要退出發(fā)送子程序,并且要將發(fā)送中斷標(biāo)志位清零,單片機(jī)串口通信是單工工作的,發(fā)送的時(shí)候不能接收,接收的時(shí)候不能發(fā)送
