查看: 1389|回復: 0
如何修改MCU程序才能實現(xiàn)數(shù)據(jù)加減,要有上下限,超過之后蜂鳴器會報警?
ID:923677 發(fā)表于 2021-5-29 18:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
怎樣才能實現(xiàn)數(shù)據(jù)加減,要有上下限,超過之后蜂鳴器會報警,各位前輩幫我看看要怎么改。
用OLED顯示兩個屏,第一個屏顯示個人信息,第二個屏顯示電機狀態(tài)、速度和溫度
#include <reg51.h>
#include "delay.h"
#include "oled12864.h"
#include "key.h"
#include "motor.h"
void screen1();
void screen2();
void key();
void motor();
void display();
void alarm();
unsigned char flag=0,speed=50,num=10,banji=1901,key_mode=0,wendu=30,key_num=0;
unsigned char code ch1[]={0,1,'#'};//名字
unsigned char code ch2[]={2,3,4,'#'};//
unsigned char code ch3[]={5,6,'#'};//班級
unsigned char code ch4[]={7,8,'#'};//學號
sbit bee=P3^6;
        OLED_Init();
        DC_Motor_Init();
//        OLED_Clear();//顯示清屏
                        display();
//                  OLED_Clear();
                        key();
                  motor();
void display()
        screen1();
        screen2();
void screen1()
  OLED_Show_stringChinese(0,0,ch1);//ch1姓名
        OLED_Show_Char(0,32,':');
        OLED_Show_stringChinese(0,37,ch2);//ch2
  OLED_Show_stringChinese(2,0,ch4);//ch6學號
  OLED_Show_Char(2,32,':');
  OLED_Show_Num(2,36,num,4);
void screen2()
        OLED_Show_String(0,0,"status:");
        OLED_Show_String(2,0,"speed:");
        OLED_Show_String(4,0,"wendu:");
        OLED_Show_Num(2,8*8,speed,2);
        OLED_Show_Num(4,8*8,wendu,2);
        motor();
void key()
        if(key1_scan()!=0)//key1_scan切換
                key_mode++;
                key_mode%=2;
//                key_num=0;
                OLED_Clear();
        switch(key2_scan())
                        case 0:break;
                        case 1:OLED_Show_String(0,7*8,"runing ");break;
                  case 2:OLED_Show_String(0,7*8,"stop");break;
        switch(key3_scan())//按鍵
                case 0:break;
                case 1:switch(key_mode)
                                                case 0:switch(key_num)
        case 0:break;
        case 1:speed+=1;break;
        case 2:speed+=10;break;
        }break;
                                                case 1:switch(key_num)
        case 0:break;
        case 1:wendu+=1;break;
                    case 2:wendu+=10;break;
        }break;
                                        }break;
        switch(key4_scan())//按鍵
                case 0:break;
        case 0:break;
        case 1:speed-=1;break;
        case 2:speed-=10;break;
        }break;
        case 0:break;
        case 1:wendu-=1;break;
                          case 2:wendu-=10;break;
        }break;
                                        }break;
void motor()
//        flag=0,1,2;
        switch(flag)
                case 0:ENA=0;TR0=0;break;
                case 1:TR0=1;DC_Motor_Run(1,speed);break;
void alarm()
        if(wendu>50)
                bee=1;
        else if(wendu<20)
                bee=1;
        else bee=0;
