查看: 1604|回復(fù): 4
單片機(jī)10秒計(jì)時(shí)程序錯(cuò)誤
ID:884109 發(fā)表于 2021-5-31 18:20 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
單片機(jī)實(shí)現(xiàn)秒表計(jì)時(shí)程序,按一次按鍵,開始計(jì)時(shí),第二次按下暫停,再按則清零。
但是不知為什么,第二次按鍵時(shí),顯示全是0.
#include <reg51.h>
#include <intrins.h>
//共陰數(shù)碼管段選表0~9和-
uchar  code tabeld[]= {0xBF, 0x86, 0xDB, 0xCF, 0xE6, 0xED, 0xFD, 0x87, 0xFF, 0xEF,0x40};
uchar  code tabel[]= {0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F,0x40};
uchar  code wei[]= {0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80};
//uchar hour,minute,second,i;
uchar times=0,second,keyNum=0;
sbit key = P2^7;
void delay();
void display();
void timerInit();
void main(void)
        timerInit();
        second = 0;
        key = 1;
        while(1){
                display();
                if(        !key){
                        keyNum++;
                        switch(keyNum){
                                 case 1:
                                        TH0 = 0xED;
                                        TL0 = 0xFF;
                                        TR0 = 1;
                                        break;
                                case 2:
                                        TR0  = 0;
                                        display();
                                        break;
                                case 3:
                                        second = 0;
                                        keyNum = 0;
                                        display();
                        while(        key & 1 == 0);
void timerInit()
        TMOD = 0x01;
        TH0 = 0xED;
        TL0 = 0xFF;
        EA = 1;
        ET0 = 1;
void delay()
        uchar i;
        for( i = 0; i < 111; i++ ) ;
void display()
        P0 = P1 = 0;
        delay();
        P0 = tabeld[second/10];
        P1 = wei[ 1 ];
        delay();
        P0 = P1 = 0;
        delay();
        P0 =  tabel[second%10];
        P1 = wei[ 0 ];
        delay();
void timer0Int() interrupt 1
        TH0 = 0xED;
        TL0 = 0xFF;
        TR0 = 0;
        times++;
        if( 20 == times){
                 times = 0;
                second++;
                display();
        if(second == 99){
                 TR0 = 0;
                second = 0;
                keyNum = 2;
        } else{
                 TR0 = 1;
ID:213173 發(fā)表于 2021-5-31 21:49 | 只看該作者
給你一個(gè)示例參考
6位百分秒表 仿真.zip (105.21 KB, 下載次數(shù): 6)
ID:917199 發(fā)表于 2021-5-31 23:07 | 只看該作者
建議樓主考慮下這里: while(        key & 1 == 0);
ID:844772 發(fā)表于 2021-6-1 09:59 | 只看該作者
有硬件防抖嗎?你沒有做軟件防抖啊。還有你中斷調(diào)用的display()里有延時(shí)函數(shù),延時(shí)還超過了中斷,
ID:884109 發(fā)表于 2021-6-1 16:23 | 只看該作者
多謝各位指導(dǎo),我再試試
