在STC12C56,直接下就可以使用!
- //單片機的DES加解密程序,參數(shù)帶入密鑰就能加密解密了,注意密鑰,原 始數(shù)據(jù)和加密產(chǎn)生的數(shù)據(jù)都是8個字節(jié)的。
- //單片機源程序如下:
- #include "des.h"
- //密鑰: B4 31 5B 86 9D 7D FA A2
- //數(shù)據(jù): 1F AD 61 A5 F7 19 77 14
- //DES加密結(jié)果:4C 78 E9 1A F2 DA 9C D3
- unsigned char code initial_tr[64] = //初始置換
- 57, 49, 41, 33, 25, 17, 9, 1,
- 59, 51, 43, 35, 27, 19, 11, 3,
- 61, 53, 45, 37, 29, 21, 13, 5,
- 63, 55, 47, 39, 31, 23, 15, 7,
- 56, 48, 40, 32, 24, 16, 8, 0,
- 58, 50, 42, 34, 26, 18, 10, 2,
- 60, 52, 44, 36, 28, 20, 12, 4,
- 62, 54, 46, 38, 30, 22, 14, 6
- unsigned char code final_tr[64] =
- 39, 7, 47, 15, 55, 23, 63, 31,
- 38, 6, 46, 14, 54, 22, 62, 30,
- 37, 5, 45, 13, 53, 21, 61, 29,
- 36, 4, 44, 12, 52, 20, 60, 28,
- 35, 3, 43, 11, 51, 19, 59, 27,
- 34, 2, 42, 10, 50, 18, 58, 26,
- 33, 1, 41, 9, 49, 17, 57, 25,
- 32, 0, 40, 8, 48, 16, 56, 24
- unsigned char code swap[64] =
- 33, 34, 35, 36, 37, 38, 39, 40,
- 41, 42, 43, 44, 45, 46, 47, 48,
- 49, 50, 51, 52, 53, 54, 55, 56,
- 57, 58, 59, 60, 61, 62, 63, 64,
- 1, 2, 3, 4, 5, 6, 7, 8,
- 9, 10, 11, 12, 13, 14, 15, 16,
- 17, 18, 19, 20, 21, 22, 23, 24,
- 25, 26, 27, 28, 29, 30, 31, 32
- unsigned char code key_tr1[56] =
- 0, 57, 49, 41, 33, 25, 17,
- 9, 1, 58, 50, 42, 34, 26,
- 18, 10, 2, 59, 51, 43, 35,
- 6, 61, 53, 45, 37, 29, 21,
- 13, 5, 60, 52, 44, 36, 28,
- 20, 12, 4, 27, 19, 11, 3
- unsigned char code key_tr2[64] =
- 0, 0, 13, 4, 16, 10, 23, 0,
- 0, 0, 2, 9, 27, 14, 5, 20,
- 0, 0, 22, 7, 18, 11, 3, 25,
- 0, 0, 15, 1, 6, 26, 19, 12,
- 0, 0, 40, 54, 51, 30, 36, 46,
- 0, 0, 29, 47, 39, 50, 44, 32,
- 0, 0, 43, 52, 48, 38, 55, 33,
- 0, 0, 45, 31, 41, 49, 35, 28
- unsigned char code etr[64] =
- 0, 0, 31, 4, 0, 1, 2, 3,
- 0, 0, 3, 8, 4, 5, 6, 7,
- 0, 0, 7, 12, 8, 9, 10, 11,
- 0, 0, 11, 16, 12, 13, 14, 15,
- 0, 0, 15, 20, 16, 17, 18, 19,
- 0, 0, 19, 24, 20, 21, 22, 23,
- 0, 0, 23, 28, 24, 25, 26, 27,
- 0, 0, 27, 0, 28, 29, 30, 31
- unsigned char code ptr[32] =
- 31, 14, 39, 44, 60, 23, 55, 36,
- 4, 30, 46, 53, 12, 37, 62, 21,
- 5, 15, 47, 29, 63, 54, 6, 20,
- 38, 28, 61, 13, 45, 22, 7, 52
- unsigned char code s[8][64] =
- 14, 4, 13, 1, 2, 15, 11, 8, 3, 10, 6, 12, 5, 9, 0, 7,
- 0, 15, 7, 4, 14, 2, 13, 1, 10, 6, 12, 11, 9, 5, 3, 8,
- 4, 1, 14, 8, 13, 6, 2, 11, 15, 12, 9, 7, 3, 10, 5, 0,
- 15, 12, 8, 2, 4, 9, 1, 7, 5, 11, 3, 14, 10, 0, 6, 13
- 15, 1, 8, 14, 6, 11, 3, 4, 9, 7, 2, 13, 12, 0, 5, 10,
- 3, 13, 4, 7, 15, 2, 8, 14, 12, 0, 1, 10, 6, 9, 11, 5,
- 0, 14, 7, 11, 10, 4, 13, 1, 5, 8, 12, 6, 9, 3, 2, 15,
- 13, 8, 10, 1, 3, 15, 4, 2, 11, 6, 7, 12, 0, 5, 14, 9
- 10, 0, 9, 14, 6, 3, 15, 5, 1, 13, 12, 7, 11, 4, 2, 8,
- 13, 7, 0, 9, 3, 4, 6, 10, 2, 8, 5, 14, 12, 11, 15, 1,
- 13, 6, 4, 9, 8, 15, 3, 0, 11, 1, 2, 12, 5, 10, 14, 7,
- 1, 10, 13, 0, 6, 9, 8, 7, 4, 15, 14, 3, 11, 5, 2, 12
- 7, 13, 14, 3, 0, 6, 9, 10, 1, 2, 8, 5, 11, 12, 4, 15,
- 13, 8, 11, 5, 6, 15, 0, 3, 4, 7, 2, 12, 1, 10, 14, 9,
- 10, 6, 9, 0, 12, 11, 7, 13, 15, 1, 3, 14, 5, 2, 8, 4,
- 3, 15, 0, 6, 10, 1, 13, 8, 9, 4, 5, 11, 12, 7, 2, 14
- 2, 12, 4, 1, 7, 10, 11, 6, 8, 5, 3, 15, 13, 0, 14, 9,
- 14, 11, 2, 12, 4, 7, 13, 1, 5, 0, 15, 10, 3, 9, 8, 6,
- 4, 2, 1, 11, 10, 13, 7, 8, 15, 9, 12, 5, 6, 3, 0, 14,
- 11, 8, 12, 7, 1, 14, 2, 13, 6, 15, 0, 9, 10, 4, 5, 3
- 12, 1, 10, 15, 9, 2, 6, 8, 0, 13, 3, 4, 14, 7, 5, 11,
- 10, 15, 4, 2, 7, 12, 9, 5, 6, 1, 13, 14, 0, 11, 3, 8,
- 9, 14, 15, 5, 2, 8, 12, 3, 7, 0, 4, 10, 1, 13, 11, 6,
- 4, 3, 2, 12, 9, 5, 15, 10, 11, 14, 1, 7, 6, 0, 8, 13
- 4, 11, 2, 14, 15, 0, 8, 13, 3, 12, 9, 7, 5, 10, 6, 1,
- 13, 0, 11, 7, 4, 9, 1, 10, 14, 3, 5, 12, 2, 15, 8, 6,
- 1, 4, 11, 13, 12, 3, 7, 14, 10, 15, 6, 8, 0, 5, 9, 2,
- 6, 11, 13, 8, 1, 4, 10, 7, 9, 5, 0, 15, 14, 2, 3, 12
- 13, 2, 8, 4, 6, 15, 11, 1, 10, 9, 3, 14, 5, 0, 12, 7,
- 1, 15, 13, 8, 10, 3, 7, 4, 12, 5, 6, 11, 0, 14, 9, 2,
- 7, 11, 4, 1, 9, 12, 14, 2, 0, 6, 10, 13, 15, 3, 5, 8,
- 2, 1, 14, 7, 4, 10, 8, 13, 15, 12, 9, 0, 3, 5, 6, 11
- unsigned char code rots[16] =
- 1, 1, 2, 2, 2, 2, 2, 2, 1, 2, 2, 2, 2, 2, 2, 1
- unsigned char code bit_msk[8] =
- 0x80, 0x40, 0x20, 0x10, 0x08, 0x04, 0x02, 0x01
- unsigned char DES_Encrypt_key[8];
- unsigned char DES_Decrypt_key[8];
- unsigned char sub_keys[16][8]; //sub_keys[16][8]
- unsigned char main_key[8];
- /* Module title: des */
- /* Module type: des main rutine */
- /* Author: YXH */
- /* Date: 2012-07-13 */
- /* Last changed by: YXH */
- /* Functional Description: Encipher and decipher 64 bits string */
- /* according to a 64 bits key string */
- /* The string format is shown below */
- /* input parameter 1: pointer to 64 bits input string */
- /* 2: pointer to 64 bits key string */
- /* 3: boolean if false indicating enciphering */
- /* if true dechiphering */
- /* 4: pointer to a 64 bits output string */
- /* msb lsb */
- /* bit bit */
- /* addr !1st 8th! */
- /* addr+1 !9th 16th! */
- /* addr+7 !57th 64th! */
- void des(unsigned char *plain_strng, unsigned char *key, unsigned char d, unsigned char *ciph_strng)
- unsigned char a_str[8], b_str[8], x_str[8];
- unsigned char i, j, *pkey, temp;
- for (i = 0; i < 8 ; ++i)
- if (key[i] != main_key[i])
- compute_subkeys(key);
- i = 7;
- transpose(plain_strng, a_str, initial_tr, 64);
復制代碼- #include "STC12C56.h"
- #include <stdio.h>
- #include "TM1620.H"
- #include "des.h"
- #define FOSC 11059200L //System frequency
- #define BAUD 57600 //UART baudrate
- unsigned char code key_tab[]={0x05,0x51,0x80,0x01,0x05,0x51,0xFf,0xFF}; //密鑰
- unsigned char code plain_tab[]={0x11,0x22,0x33,0x44,0x55,0x66,0x77,0x88}; //明文
- uint times=0;
- uchar RxdBuff[8];
- uchar Uart_DES = 0;
- uchar n;
- void UartInit(void) //57600bps@11.0592MHz,開啟波特率倍速
- PCON |= 0x80; //使能波特率倍速位SMOD
- SCON = 0x50; //8位數(shù)據(jù),可變波特率
- AUXR &= 0xBF; //定時器1時鐘為Fosc/12,即12T
- AUXR &= 0xFE; //串口1選擇定時器1為波特率發(fā)生器
- TMOD &= 0x0F; //清除定時器1模式位
- TMOD |= 0x20; //設(shè)定定時器1為8位自動重裝方式
- TL1 = 0xFF; //設(shè)定定時初值
- TH1 = 0xFF; //設(shè)定定時器重裝值
- ET1 = 0; //禁止定時器1中斷
- TR1 = 1; //啟動定時器1
- ES = 1; //Enable UART interrupt
- EA = 1; //Open master interrupt switch
- void Delay200ms() //@11.0592MHz
- unsigned char i, j, k;
- i = 9;
- j = 104;
- k = 139;
- do
- do
- while (--k);
- } while (--j);
- } while (--i);
- void main()
- unsigned char cipher1[8]; //密文緩存
- UartInit();
- Display_num(1,BAUD/10000%10,0);
- Display_num(2,BAUD/1000%10,0);
- Display_num(3,BAUD/100%10,0);
- Display_num(4,BAUD/10%10,0);
- Display_num(5,BAUD%10,0);
- Delay200ms();
- Delay200ms();
- Init_TM1620();
- des(plain_tab, key_tab, 1, cipher1);
- ES = 0;
- for(n=0;n<8;n++)
- SBUF=cipher1[n]; //回應發(fā)送者以成功接收
- while(!TI);
- TI = 0; //手動清零發(fā)送中斷標志位
- ES = 1;
- while(1)
- times++;
- if (times%10==0)
- Display_Bit(1,0x80);
- else
- Display_Bit(1,0x00);
- if(Uart_DES == 1)
- Uart_DES = 0;
- void Uart_Isr() interrupt 4
- ES = 0;
- if(SBUF==0xA5)
- // uchar n;
- RI=0;
- // while(!RI);
- // RI=0;
- //Uart_len=SBUF; //接收數(shù)據(jù)長度
- Uart_DES = 1;
- for(n=0;n<8;n++) //開始接收數(shù)據(jù)
- while(!RI);
- RI=0;
- RxdBuff[n]=SBUF;
- for(n=0;n<8;n++)
- SBUF=RxdBuff[n]; //回應發(fā)送者以成功接收
- while(!TI);
- else{
- SBUF=0x0E; //回應發(fā)送者接收失敗
- while(!TI);
- TI = 0;
- RI=0;
- ES=1;
復制代碼
