查看: 1518|回復(fù): 0
ADXL345是怎么來(lái)計(jì)算步數(shù)和判斷運(yùn)動(dòng)狀態(tài)的?
ID:890746 發(fā)表于 2021-6-7 21:38 | 顯示全部樓層 |閱讀模式
ADXL345模塊做計(jì)步器,找到了一段程序但是看不太懂,有大佬教教我,ADXL345是怎么來(lái)計(jì)算步數(shù)和判斷運(yùn)動(dòng)狀態(tài)的啊......
#include<reg52.h>
#include<stdio.h>
#include "delay.h"
#include "math.h"
#include "adxl345.h"
#include "1602.h"
sbit led=P1^4;         //引腳定義
unsigned char ReadAdxl345;                 //定時(shí)讀取adxl345
char dis0[16];                   //串口數(shù)據(jù)顯示
xdata char dis1[16];                   //串口數(shù)據(jù)顯示
xdata char dis2[16];                   //串口數(shù)據(jù)顯示
unsigned long time_20ms=0;           //定時(shí)器計(jì)數(shù)
unsigned char ReportFlag=0;           //數(shù)據(jù)上報(bào)標(biāo)志
unsigned int BuShu=0;         //累計(jì)步數(shù)
float JuLi=0;                        //累計(jì)距離
float KaLuLi=0;                        //累計(jì)卡路里
unsigned char statFlag = 0;//狀態(tài)
void Init_Timer0(void);                   //函數(shù)聲明
void SendStr(unsigned char *s,unsigned char length);
void UART_Init(void);
void SendByte(unsigned char dat);
void BuShuCheck(void);
void main (void)
        Init_Timer0();        //定時(shí)器0初始化
        UART_Init();
        LCD_Init();           //初始化液晶
        DelayMs(20);          //延時(shí)有助于穩(wěn)定
        LCD_Clear();
        Init_ADXL345();          //清屏
        if(Single_Read_ADXL345(0X00)==0xe5)        //讀出的數(shù)據(jù)為0XE5,表示正確
                DelayMs(5);
                DelayMs(3);
        led=1;
        while (1)         //主循環(huán)
            if(ReadAdxl345==1)   //定時(shí)讀取adxl345數(shù)據(jù)
                        BuShuCheck();                        //檢測(cè)步數(shù)
                        sprintf(dis1,"B:%04d J:%4.1fm ",BuShu/2,JuLi);        //打印
                        LCD_Write_String(0,0,dis1);//顯示
                        sprintf(dis2,"%7.2fcal ",KaLuLi);                   //打印
                        LCD_Write_String(0,1,dis2);//顯示
                        if(statFlag == 0)//站著狀態(tài)
                        {LCD_Write_String(11,1,"Stand");}
                        else if(statFlag == 1)////躺著狀態(tài)
                        {LCD_Write_String(11,1,"Lie  ");}
                        else if(statFlag == 2)//跑著狀態(tài)
                        {LCD_Write_String(11,1,"Run  ");}
                        else if(statFlag == 3)//走著狀態(tài)
                        {LCD_Write_String(11,1,"Walk ");}
                if(ReportFlag==1)        //2s
                        ReportFlag=0;
                        sprintf(dis0,"*B:%04d",BuShu/2);        //上報(bào)步數(shù)
                        SendStr(dis0,7);
                        sprintf(dis0,"J:%04.1fm",JuLi);                        //上報(bào)距離
                        SendStr(dis0,7);
                        sprintf(dis0,"K:%07.2fcal",KaLuLi);                   //上報(bào)卡路里
                        SendStr(dis0,12);
                        {SendStr("Stand#",6);}
                        {SendStr("Lie  #",6);}
                        {SendStr("Run  #",6);}
                        {SendStr("Walk #",6);}
                        SendStr("\r\n",2);
        static unsigned char ErrorNum=0;           //變量定義
        static unsigned char NormalNum=0;
        static unsigned char CheckNum=0;           //變量定義
        static unsigned char shuNum=0;
        static unsigned char ceNum=0;
        static unsigned int remBuShu=0;
        ReadAdxl345=0;
        ReadData_x();
        CheckNum++;//檢測(cè)次數(shù)
        if((temp_X<650)||(abs(temp_Y)>400))       //查看正常次數(shù)
                led=0;                        //呼吸燈
                ErrorNum++;        //記錄次數(shù)
                shuNum++;//豎直狀態(tài)++
        {NormalNum++; ceNum++;led=1;} //呼吸燈//側(cè)著狀態(tài)++
        if((NormalNum!=0)&&(ErrorNum!=0))        //                        從角度判斷走了一步
                ErrorNum=0;
                NormalNum=0;
                BuShu++;
                JuLi=(float)(BuShu/2)*0.45;          //計(jì)算距離
                KaLuLi=JuLi*70*0.832;                 //卡路里計(jì)算 走路 距離*體重*系數(shù)
        if(CheckNum>=20)
                if((ceNum!=0)&&(shuNum==0))
                        statFlag = 0;//站著狀態(tài)
                else if((ceNum==0)&&(shuNum!=0))
                        statFlag = 1;//躺著狀態(tài)
                else if((ceNum!=0)&&(shuNum!=0))
                        if((BuShu - remBuShu)>=6)//跑著 一個(gè)周期大于3步
                        {statFlag = 2;}//跑著狀態(tài)
                        {statFlag = 3;}//走著狀態(tài)
                        remBuShu = BuShu;//記錄上次步數(shù)
                CheckNum=0;
                ceNum=0;                //清空計(jì)數(shù)
                shuNum=0;
        TMOD |= 0x01;          //使用模式1,16位定時(shí)器,使用"|"符號(hào)可以在使用多個(gè)定時(shí)器時(shí)不受影響
        TH0=(65536-20000)/256;                  //重新賦值 20ms
        TL0=(65536-20000)%256;
        EA=1;            //總中斷打開(kāi)
        ET0=1;           //定時(shí)器中斷打開(kāi)
        TR0=1;           //定時(shí)器開(kāi)關(guān)打開(kāi)
void Timer0_isr(void) interrupt 1
        time_20ms++;
        if(time_20ms%5==0)
                ReadAdxl345=1;
        if(time_20ms%50==0)
                ReportFlag=1;
